Drilling Technique- Enlarging an existing hole
LG63
This is one of those topics where I’ve thought to myself many times “there has to be a better way”. When drilling out an existing hole in steel, say .030 to .060 oversize, how do you avoid the bit plowing into the edge of the hole and inevitably pulling the bit in at such a fast rate that you can’t control where the bit goes. More often than not I end up with a new hole that is off of the original centerline and a bit with a broken edge. I’m referring specifically to using a hand drill, in a drill press it doesn’t seem to be as much of a problem. I had this problem this past weekend when I was trying to drill out a 5/16 hole to install a thread insert. It wasn’t practical to use a drill press so I knew I would have to be careful but the new hole still ended up about .020 off the original position. I know .020 doesn’t sound like much but when you are trying to match an existing bolt pattern it just as well be a mile.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Usually in doing that, you need a way to center the hole, fasten it down rigid, then have a controlled way to open it up. A hand drill won't cut it. You normally need a mill to do it. One other way is to take another piece of metal, have the proper size of drill bushing put in, clamp both parts down solid where they won't move and your drill bushing will be your guide. If you have any machine shops around, they should be able to do it for you for a minimal price.
L
LG63
Large countersink bit and make a light countersink before drilling - usually helps center the bit.
I'll definitely try this next time. Any thoughts on preventing the bit from self-feeding at such a fast rate? Are there special bits for this?
A_Pmech
IL
In those situations I use a reamer, a core drill, or I dub the drill.
As mentioned, a countersink slightly larger than the drill diameter and at a steeper angle than the drill will help it start on the same location.
Bruce Lancaster
The conical multi-sized drills (Uni-Bit, some name like that) feed into hole pretty neatly because they have tapered ramps between the size steps.
I once used one (turning it by hand) to greatly enlarge the hole in a thin plastic protractor to fit on a shaft. I went from around 1/3 up to maybe about 3/4, using numerous small increment steps on 2 sizes of drill, and when I was done I tested the setup and found it to be still concentric within what I could read.
Tim The Tool Man
Lehigh Valley, PA
This:
A_Pmech
IL
what do you mean Dub the drill ?
Reducing the rake angle of the cutting edge. That reduces the tendency to self-feed. It's also commonly done for drilling materials such as brass where a high rake angle tends to result in poor cutting performance.
Alchymist
Central PA
He's only enlarging .030" to .060" - way smaller than the steps on one of those.
Grinding the angle at the tip of the bit determines feed rate - sharper the angle, more rapid the feed:
GRX
MD
Good posts. My thinking exactly.
Loads of great drill bit info in this thread:
www.garagejournal.com/forum/showthread.php?t=135850
L
LG63
Thanks for the input. Doesn't sound like there's any silver bullet when drilling by hand. Next time I'll for sure countersink first, use a 135 deg bit, and try to hold my mouth right. I checked on 140 and 150 deg bits but they were all carbide and expensive.
RCStocker
Indiana, California, Australia
There are pilot drills that have a round cylinder point the size of the hole you are drilling.
They have a 1/4" lead or more. The pilot keeps the drill from walking and the next step had a flatter angle and cuts the whole to the size required. I have a bunch of them. I got them 40 years ago when I was given a small machine shop. I don't know where you buy them now. I have seen end mills stepped down and I have turned drills on the lathe to cut down the shank and the pointed end. You can take a drill and make your own pilot drill. You just need to know how to sharpen your tooling and know the proper speed. You need to feed it by hand but it can be done. I have done it.
A counter sink works very well. If you take small steps drilling the hole larger it will not walk as far. Small steps works much better. You might need to go to a number or fractional drill bit but there are in between sizes. You can even step it up with a Metric bit to get to the size you want. Changing the point angle on the drill can also work well but you need to know how to sharpen bits buy hand. It is not hard. It takes a little practice but I use a regular 8 inch bench grinder all the time to sharpen bits. I have a $800 commercial sharpener and 2 drill doctors but I never use them. Just get a good scale and make sure both flutes are the same length Whey they are you know you are centered. I have a Starrett scale with the drill angle attachment but I seldom use it. I had an old time teach me how to sharpen bits when I was a kid and it really has helped me through the years.
A magnetic portable drill works great if you can get it mounted. As stated you just put a metal rod in the hole and chuck it up then flip the magnet lever. This works great for a drill press and vice as well.
Now I will need to look up pilot drills. I know someone must make them these days.
justanengineer
Motor City
If you dont have the ability to offhand grind the drill point angle down a bit, I would suggest seriously increasing your speed and decreasing your feed rate to almost nothing. Quite often a very light touch will keep the drill from grabbing.
If youre going quite a bit oversize, my favorite tool to help things get started on center is a good old fashioned deburring tool.
theknurl
SoCal
when enlarging a drilled hole.....with a drill press, mill or BUX drill
fold ~6-8 layers of cloth into a square larger than the existing hole
center the drill with it off.....now place the square over the hole and and turn the drill on and drill away:rocker:
the fabric stops any chattering too:thumbup:
1st time i saw it done was 40+ years ago in Swtizerland
PS; don't chamfer it
Alchymist
Central PA
Read the OP, he's doing this by hand. No drill press, no mill.
bad_idea
Pasquotank, NC
Some good input in this thread so far. I am surprised no one suggested an air drill though. I have a heavy duty 1/2" air drill at work and it allows more finesse in my opinion. Air drills don't grab like an electric does, they stall instead of taking you for a ride. I find it is easier to focus on lining up the bit when I am not worrying about the drill taking me for a ride! High rpms and very little feed rate is easier too, if it does grab, it will only stall. Less broken bits that way too.
L
LG63
Good idea. I don't have an air drill but I think I could use a cordless drill/driver with the clutch backed off to accomplish something similar.
L
LG63
Reamers have been mentioned several times but the reamers I've used will only remove a few thousandths and they really need the rigidity of a drill press or mill. I looked around the Enco website at different reamers but didn't find anything that looked like it would work. Are there special reamers out there that will cut say .030" in a single pass and can be used by hand?
