Driver Bit Cases
aburkhardt
Lancaster, PA
As is the case (pun intended) with many (most?) on this forum, i collect and hoard infinitely more tools that i perhaps need. Don't tell my better half.
That said, i picked up another 30+ piece Dewalt driver bit set, because it was 0.02 cents off, and i can't help but comment that the method that Dewalt uses to hold the bits is, by far, the worst of those I've encountered.
Comparing to another Dewalt toughcase from 5+ years ago, which has not been improved upon, a Makita gold bit set, and several Milwaukee sets, the dewalt yellow cases require you to slide the bits in at almost a negative angle, pass the first set of stiff rubber, then lift upward until you slide into it's final resting place. As a product development engineer, this is maddening.
Given that i'm a weekend warrior, and use my bits more frequently in and around my home, what are some better alternatives to storing driver bits for easy access?
In addition to the big box sets, i've got a plethora of loose bits from Wera, wiha, PB Swisster, #2's from KC Tool, and some other orphans.
What's your favorite storage system/method?
JBH
I like Felo’s bit boxes the best. I use those and the red PB Swiss bit strips for randos. The black Wiha tin cans with foam inside work well too.
kctyphoon
Jersey/Staten Island
If you just wanna make your life easy. Just buy one or two of these $4 organizers, and throw everything inside.. sometimes easy is better than pretty.
https://www.homedepot.com/p/Husky-6...rganizer-Clear-and-Black-THD2015-03/301959981
I had pictures of the ones i have at work.. but anyway - if you pull the dividers out on one long side, it’ll hold normal size drill bits, and then you still have up to 3 separate compartments to keep driver bits separated.. I HATED the dewalt driver organizers.. even the Milwaukee can get annoying sometimes.
What’s nice too, is with those husky storage bins being clear, if you have multiple ones you can easily see what’s inside without opening them. They are nice and small, and hold up very well. I have 3 on the bucket truck at work just getting banged around inside a utility door with other hand tools. None have broken yet.
Actually here - when they were newer.. they come divided into 6 compartments .
woody 73
The Great State Up North
I like the GJ ask a question get an answer...:thumbup:
A
aburkhardt
Lancaster, PA
The PB Swiss "bitblocks" look to fit the bill, but unfortunately they're inflated to $11+ on amazon. They're more reasonable from Count-On Tools, and possibly Toollady, the usual suspects, though. Guess i'll just have to add some more items to the cart to justify shipping ...
Shane6377
HDX small parts organizer from Home Depot. They are a double sided parts organizer with removable dividers. Works great for drill and driver bits. Under $10 too. That's my go-to portable option.
I drill 1/4" holes in a 1x4 for storage inside the toolbox.
Danglerb
SoCal
Link to seller still in China, but via USA ebay, same 5 pcs 10 or 12 slot less than $2: http://www.ebay.com/itm/5pcs-Hex-Sh...-Head-Storage-Case-Deck-Durable-/192748069956
Been using these cheap direct from China bit strips and then whatever box or case they fit in. Bits are a tight fit so they would be too fiddly for anyone swapping bits all day but good for keeping bits organised.
Five strips for £1.31 ($1.70)
https://www.ebay.co.uk/itm/5-pcs-St...Holder-/192762139272?var=&hash=item2ce184d288
Joe Mamma
.22 ammo plastic cases.
I like the white CCI 9mm ammo trays that come inside the cardboard box of 50 rounds. Bits fit loosely (so they can easily be pulled and put back), but they still stand up.
Different brands have different size and shaped cutouts (even for the same caliber), so anyone considering ammo trays should experiment.
Joe Mamma
Rarified27
Between PA and NJ
Joe Mamma
The ones I use are from the non-brass blazer stuff. I put them in a deeper clear plastic case and it works pretty well.
rick carpenter
Huntsville, East Texas
I use clear Plano/Flambeau/Ozark Trails fishing lure boxes from Academy. Shallower than the Husky boxes kctyphoon has, but with several different sizes. You can only adjust the compartments lengthwise though.
Biomed
Minnesota
I like the ammo case idea but are the .22 ammo holes large enough to actually fit a 1/4" (0.25") bit? Ammo cases are readily available and cheap. I was going to order a few today but I'm just not sure the bits will fit. Anybody actually doing this?
If the bits won't fit in a .22 ammo case I'm sure there are other ammo calibers that would work.
I really like that Wiha box in Mr. Lemon's post but I don't think Wiha sells those in the US.
mr.lemons
UK
Doesn't have to be a Wiha box. Any Bosch, Makita or even an Altoids tin will do. I used to keep bits in a box similar to the ammo cases but specifically made for bits. Knocked it of my bench a couple of times with the lid open and the bits went everywhere. That's why I started using the strips.
Biomed
Minnesota
I guess I will try this one more time...
Are the holes in a .22 ammo storage case actually large enough to accommodate a 1/4" (0.25") hex bit? Is anyone actually doing this or is it just an idea someone had?
BFHtime
How about some pictures. Really need pictures in this thread.
Shane6377
This is my toolbox solution. Scrap 1x4 cutoff with 1/4" holes drilled about 1/2" deep. Works good inside the drawer and can easily be taken out if needed. The only downside is there is no retention so if you drop it your picking up a lot of bits!
My portable case is an HDX double sided small parts case from Home Depot. I've been happy with it.
Joe Mamma
My guess is that people are just laying the bits down in the plastic rectangular boxes that often come with CCI 22 ammo, with multiple bits in a single rectangular box. This is after removing the dividers with the individual cutouts (holes) for each cartridge.
I would love to be shown that my guess is wrong.
b-man
Biomed
Minnesota
A 1/4" bit won't fit in a .22 hole. I just tried it in a CCI plastic case.
Thank you!! That's what I thought.
There are some really weird ammo calibers so it should be possible to find an ammo storage case that would work.
