aburkhardt
As is the case (pun intended) with many (most?) on this forum, i collect and hoard infinitely more tools that i perhaps need. Don't tell my better half.
That said, i picked up another 30+ piece Dewalt driver bit set, because it was 0.02 cents off, and i can't help but comment that the method that Dewalt uses to hold the bits is, by far, the worst of those I've encountered.
Comparing to another Dewalt toughcase from 5+ years ago, which has not been improved upon, a Makita gold bit set, and several Milwaukee sets, the dewalt yellow cases require you to slide the bits in at almost a negative angle, pass the first set of stiff rubber, then lift upward until you slide into it's final resting place. As a product development engineer, this is maddening.
Given that i'm a weekend warrior, and use my bits more frequently in and around my home, what are some better alternatives to storing driver bits for easy access?
In addition to the big box sets, i've got a plethora of loose bits from Wera, wiha, PB Swisster, #2's from KC Tool, and some other orphans.
What's your favorite storage system/method?
