Drywall thickness for 24” stud spacing
TimberMan
I need to decide if I should go with 1/2” or 5/8” drywall for my barn which has 24” stud spacing and 19.2” ceiling joist spacing. (edited to correct ceiling spacing typo)
Let me you your thoughts!
Thx
mike93lx
Richmond, VA
29.2? You mean 19.2, correct? Never heard of 29.2
If it is actually 29.2, you should use strapping.
For the walls, 1/2 is fine at 24oc
nora45
With 24” wall studs and 19.2” ceiling joists, I’d definitely go with 5/8” drywall. It’s stiffer and sags less, especially on ceilings, plus it's more durable overall. Worth the extra cost for long-term strength.
pcmeiners
Working with Sheetrock for over 60 years. 5/8 type X is fire rated, hides issues with beams bowing, far easier to tape, less sanding, far superior to 1/2" except for the extra cost/weight, especially with 24" on center studs. May give you a lower insurance premium.
atch
Columbia, Missouri
1/2" on ceiling with joists 24" OC is guaranteed to bow downward between joists over time. And not much time at that. I know from actual experience.
All ceiling drywall that I've done in the past 30 years has been 5/8" with joists 16" OC. Never a problem.
Scotto
South Jersey
Working with Sheetrock for over 60 years. 5/8 type X is fire rated, hides issues with beams bowing, far easier to tape, less sanding, far superior to 1/2" except for the extra cost/weight, especially with 24" on center studs. My give you a lower insurance premium.
I'm curious, how is it easier to tape/sand? Thanks!
pcmeiners
With 5/8" the Sheetrock does not show the bowing in the beams nearly as much as 1/2" so there is less work in covering the seams (taping) and less overall waviness showing up when painted. With 5/8" the screws do not pull in the Sheetrock nearly as much in when there is a beam with a bow which is concave. If I were to do an entire home or garage in Sheetrock all surfaces would be covered with 5/8".
"1/2" on ceiling with joists 24" OC is guaranteed to bow downward between joists over time. And not much time at that. I know from actual experience." :thumbup:
micromind
Fernley, Nevada, about 30 miles east of Reno.
I guess it depends on the climate.....around here, it's pretty dry most of the time. I've seen hundreds of sheets of 1/2" on walls and trusses spaced at 24" and have yet to see any of it sag at all.
The house I built 28 years ago and still vivid often has 1/2" and 24" walls and trusses and the walls/ceilings are still flat as can be.
BillK
Beautiful Southern Maryland
I was going to say the same thing but only from my own experience. My house was built in 1978 and the ceiling trusses are on 24" centers with 1/2" drywall and they are fine.
PCustoms
VT
Only downside I've found is door/window jambs are sized for 7/16 sheathing and 1/2 drywall.
Nothing a little finish carpentry can't fix
Bert_
NW Iowa
On walls, I have come over to to the group that says 5/8 always, and that's in a house. 5/8 is so much more solid.
