I'd run 5/8 if going direct to joists. To do 1/2, you'd want to strap at 16oc. Check the bottom plane of the joists for flatness before you start.typo on the ceiling...yes it is 19.2
I'm curious, how is it easier to tape/sand? Thanks!Working with Sheetrock for over 60 years. 5/8 type X is fire rated, hides issues with beams bowing, far easier to tape, less sanding, far superior to 1/2" except for the extra cost/weight, especially with 24" on center studs. My give you a lower insurance premium.
I was going to say the same thing but only from my own experience. My house was built in 1978 and the ceiling trusses are on 24" centers with 1/2" drywall and they are fine.I guess it depends on the climate.....around here, it's pretty dry most of the time. I've seen hundreds of sheets of 1/2" on walls and trusses spaced at 24" and have yet to see any of it sag at all.
The house I built 28 years ago and still vivid often has 1/2" and 24" walls and trusses and the walls/ceilings are still flat as can be.
With 5/8" the Sheetrock does not show the bowing in the beams nearly as much as 1/2" so there is less work in covering the seams (taping) and less overall waviness showing up when painted. With 5/8" the screws do not pull in the Sheetrock nearly as much in when there is a beam with a bow which is concave. If I were to do an entire home or garage in Sheetrock all surfaces would be covered with 5/8".
