Ductless air conditioner benefits over window unit?
honda1998civic
South texas
Ductless air conditioner benefits over window unit? I’m not see any less draw in amps so I’m wondering what the benefits are on ductless ac versus window unit? Is it simply just because you can now keep the window closed instead of having it hang off the window or is there more benefits? Let me know what you guys have experienced. I’m seeing more ductless ac is why I’m asking.
Milton Shaw
Ductless are normally a lot more efficient than window units. Also the noise is much less inside. Also some have provisions to have an external thermostat to keep the air temps more even than thermostats on unit itself. Also they don't obstruct windows for view and emergency exits in case of fire.
metlmunchr
All the above, plus the ability to modulate both the fan speed and the amount of cooling (or heat) delivered to the space as opposed to a window unit that's either on or off. Another feature is "dry mode" where the unit acts as a dehumidifier, and does so without adding heat to the space like a typical dehumidifier does.
In follow mode, the unit is controlled by the temperature at the location of the remote rather than by the temp of the air entering the unit. If the space temp is satisfied, the condensing unit will shut down while the indoor fan continues to circulate air, and if the space temp rises, the condensing unit will restart at minimum capacity and ramp up to whatever capacity is required to maintain the setpoint.
In addition to modulating the capacity to less than the nominal output, most units can also go to an output greater than the stated nominal capacity, and they can do this in both cooling and heating mode.
Re the amperage draw, in my experience with a couple Pioneer units I have, they don't actually pull anything like the max amperage as stated in the literature. For example, I have one 9K BTU 120V unit in a den. The literature shows a max of about 13 amps. If I set the thermostat such that it's calling for max cooling, and let it run long enough to be fully loaded (3-4minutes), it will be pulling about half that as measured with an amprobe. In normal steady state operation where it is maintaining the room temperature, it typically draws about 4 amps which is less than the draw of a 5K BTU window unit it replaced.
I don't know for a fact, but can only assume that in Asia where all these units are made, it may be common to state max amperage based on the draw as the compressor starts rather than steady state full load amps as is common in the US. I've never checked the starting amperage, but with an inverter starting the unit at minimum speed, a current in the range of twice the running loaded amperage would be reasonable.
CarterKraft
DFW
Things are changing.
I just put this in my 30x40x14 metal building with vinyl insulation.
I am beyond happy. I had it installed in a Saturday afternoon (including framing the "window") for $699 + wiring $100.
Has "smart" controls and energy monitoring. The only negative so far is no heat option at this time even though this unit has heat pump functions in the schematic/manual.
rpcraft
Waco
Usually its a noise and efficiency improvement. It's also not having the window hogged up by a unit if you like to bird watch or have a portal to the outside, but I did see a youtube video the other day where a fellow took a window unit and set it up outside and just essentially relocated the controls with a switch and Tstat to inside, changed the packaging some on the unit to blow through a vent you could place into his window, and then his concept was essentially a mini split without the hassle and expense of a full blow installation. The other benefit is if your window is small (that is my problem) you can repackage the bigger unit and weather proof it and just let it rest outside with the ducting in your window. It's something I have considered but still weighing what I want in regards to fit and finish. My window is behind a lumber fence, and I have a huge tub I could put over the unit to disuade weather, but not sure if I really want to junkify my setup that way, lol.
bonneyman
Desert SW
Originally designed for special applications where AC is desired but the building isn't set up for it. Like historical buildings - you can't be knocking holes in walls and installing soffets in such places.
But they've taken off, and have a large variety of styles and features that make them a viable alternative to window shakers. One good thing is people yank out their old window units and dump them on the curbside for pick up. Where I can drive by and snag them. Most of the time they just need cleaning and minor repairs. Have one such unit cooling my shop and another in reserve!
