craigibc
Boiler friends,
I am in the NorthEast and my boiler started to act up this week and it is a pretty big issue.
Basically what is happening is it warms up and then the boiler does not fire and it cools down.
So I remove the cover protecting the control panel and wiring and when I shake a wire it fires up and starts running again.
I have boiled it down to the wire from the vent damper to the control board. If i touch the wire coming from the damper it fires and then warms up. It will then cool down and if I go back to the basement and fire it again it will do the same thing.
I check to make sure the Taco valve is calling for heat and also the damper is working correctly as well.
I am trying to figure out if the control board is bad or the wire is bad or something else that I am not aware of.
https://www.parts4heating.com/Dunkirk-240009076-2012-HYDROLEVEL-CTRL-MODULE-p/240009076.htm
Thanks for your advice!
Craig
Craig
