Durable cabinet paint
AA7483
South Jersey
Got some metal cabinets on Craigslist for my shop and want to paint them. Looking for suggestions on something that will hold up.
driz
Northern NY
Epoxy primer with polyurethane 2part ( hardener)auto paint not so pricy online
KenC
oklahoma
If you find a color you like, the best bang for the buck will be implement paint from a farm supply store . Comes in tractor colors, but you can mix different colors to tint to your liking. Add white to lighten colors, blend blues and greens etc. Hardener available to help gloss and speed dry time.
Reds, oranges, blues, green, yellow, white and gray commonly available
A
AA7483
South Jersey
Doesnt need to be perfect. Just want it to look decent and not chip every time I touch it. Easy and inexpensive is good too. Id love to just use a rattle can. Any reason not to?
Marctrees
TX/LA border - Toledo Bend
Doing what you want to do I would use a roller.
Basically, on anything flat and simple, usually a roller works best.
Least mess, less expense.
Proper surface prep always applies.
Marc
4xdog
Santa Fe, NM
I have probably a half dozen half-used spray cans of Majic implement paint from Tractor Supply here now. I've had miserable luck with using the cans more than once, sometimes twice. Despite my efforts to clean the nozzle after using, they seem to gum up so hard I can't get them to spray again, or if it does, it's an awful drippy flow that's no good anyway.
The implement paint itself is OK. I wouldn't rate it head-and-shoulders above a typical RustOleum, but certainly OK. It tends to be slow drying, which one would like to assume means they dry harder for it.
If you go with implement paint, at least this brand, I'd avoid rattle can and go with roller, as suggested by Marctrees.
jonshonda
Wisconsin
clean well with tsp, stuff all surfaces, clean again, paint. If you don't give the paint a nice scuffed up and clean surface, it wont stick.
bwringer
Indianapolis
Pick a brand and a color that will be easy to get in the future for touch-ups. Rustoleum High Performance enamel is what I usually use; works great and available just about everywhere.
A
AA7483
South Jersey
Only reason I was thinking rattle can is bc it would be easier to do the inside shelving etc. I wonder if I should even bother with inside.
Marctrees
I assumed only the exterior.... Only you can decide how important it is to do interior... just be aware IF you do anything more than wash out the inside, it will make the job take 3 x longer., + .
Marc
A
AA7483
South Jersey
Just wondering what the general process was. If you guys tend to do the inside or leave it be. Honestly I'm not really concerned about it.
A
AA7483
South Jersey
I wouldn't be against leaving it unpainted. Obviously it would look nicer but then Id be pissed off when it started to get chipped up from use. The only concern is some surface rust on the inside that wouldn't be dealt with if I didn't paint. How about spraying them with an inexpensive hvlp sprayer from home depot. Would the paint need to be thinned?
fasteddie
If you're talking about large tin cabinets with doors as opposed to rolling tool chests then I would agree with the roller advice. For that you will be limited to an alkyd oil based paint, Rustoleum, Valspar etc. They are slow drying, more accurately slow curing. At least 2-3 weeks to a month to reach full cure during which time it will be soft and you could scratch it off with a fingernail so if you go that route, I wouldn't paint the shelves. You can add Valspar hardener but you would have to be fast with the roller, hardener is really intended for spraying but I have brushed it thinned with naptha. That concoction will dry on your brush as you are painting. The hardener will give you the most durable finish but it contains isocyanates which is toxic when sprayed or on prolonged skin contact so rubber gloves and a good organic respirator and it's best done outdoors.
isb cornbinder
I have had great success with RUSTOLEUM. No primer necessary. Just make the surface to be painted clean and grease free.
Some before and after pictures and other pictures.
The engines were srayed with a MAC small paint gun.everything else was rattle can RUSTOLEUM.
McCharley
The Rustoleum Hammered finish paints can be applied with a rattle can. They're very tough and cover extremely well. The hammered finish completely hides any brush marks (it's cheaper to apply with a brush or roller). Note that it is nasty stuff, thinned with xylene, so wear a respirator and resign yourself to throwing away any paint brushes or rollers you use.
killahog
Morrow County Ohio
I picked up couple cabinets for $5 each, It was a good reason to buy a spray gun and learn how to use it. I picked up the paint at Tractor supply
A
AA7483
South Jersey
Looks awesome man. What did you thin the paint with? Looks awesome. Any difficulty with the sprayer?
killahog
Morrow County Ohio
I chose this thinner because it is Mineral spirits based, I watched a few you tube videos on using the sprayer all well reading the included instructions that are helpful . I have only used it a few times so I am not really someone who should be giving advice but the method I used for determing if the paint was thin enough is I would mix it and when the paint would start fall off my paint stirrer (Is that a word ) in 2 separate lines I felt it was thin enough . I did spray the insides account there was a little rust I had to clean off. If you search the my posts I started a thread that was commented on with several helpful reply’s .
fasteddie
If you decide on spraying, wipe the entire surface down with mineral spirits or paint thinner (if it's really dirty, wash it with detergent first). Scuff the surface up good with an electric pad sander or Scotchbrite pads. Wipe it down again with alcohol to remove the dust. I would thin with naphtha, it will help it flash faster and reduce the chances of dust or bugs settling on the wet surface. If you have rust spots, sand them down smooth and hit the spots with rusty metal primer. There may be a window of opportunity in which to topcoat the primer, read the can. Usually within 1 hour or after 48 hrs.
driz
Northern NY
I did not prime it.
No need to prime if ya scuff till the gloss is gone. Bare spots you should but not a deal killer. Just remember that enamel stays soft on the inside for days so be careful bumping into it with hard things for a month or so. Setting it out in the hot sun helps speed things along too. Nice job,,
driz
Northern NY
To anyone else thinking about buying a cheap gun that really works hit Harbor Freight. Their PURPLE GUN. Is not bad at all. Get an air pressure regulator that fits on the gun too while you’re there as HVLP guns are finicky about pressures. It’s not up to show quality finishes ( though I bet a pro painter could pull it off) but really is a decent gun. If you graduate to a nice gun keep that one for shooting primer.
Just remember to disassemble and clean it after you’re done. Not 3 hrs later either but as soon as you’re done spraying, like 10-15 minutes. That’s critical with hardened paints. They just start to get sputtery and sticky if you don’t and it’s hard in my experience at least to ever get it right :lol_hittiagain.
There’s ideas showing how it’s best simply done on utube.
gahrajmahal
Cincinnati, Ohio
In my experience the HF purple gun is a throw away. Poor manufacturing does not let you disassemble it multiple times to clean it. Flushing it with lacquer thinner is about as good as it gets, but at $9.99 on sale it is not too much to take. The savings over multiple spray cans make this a bargain, plus it is faster and you can use a better product. ( I do like rustoleum hammered paints though).
No air compressor in your shop yet? Buy the HVLP sprayer from harbor freight for excellent spraying of cabinets with either enamels or latex.it comes with three different tip sizes. You must thin the paints though. I sprayed kitchen cabinets with factory finish results. I also sprayed the underside of our deck with exterior latex. It allows you to spray without the typical runs when using a Wagner or piston type sprayer in tight quarters.
Bretny
Dutchess county NY
I have had really good luck with rustoleum shot through a cheap HF HVLP spray gun.
This is ny old drill press that i shot. That color is the same as electrical pannel boxes and a stocked color at homedepot.
nes999
IL
I was getting pretty frustrated with majjic paints. They seemed like it was a very soft paint. Then I painted a hitch and forgot about it. Well I finally remembered that I rattled canned it I re assembled it and threw it into duty. That paint just wouldn't chip.
I now know the trick is paint and forget. Its not convient at all however if its not a high use item or you have time to wait its a great option.
I painted the bed on my mule 2 years ago and even with dumping rock and such its holding up Well. Granted that's another project I painted, got busy, and forgot I painted.
Sent from my VS988 using Tapatalk
A
AA7483
South Jersey
These are the cabinets. Just cleaned them with tsp. Thinking if I decide to do the inside I can sand just the shelves and skip sannding the inside wallls. Then just shoot the inside with an hvlp. The walls should see little wear but will give a uniform look.
A
AA7483
South Jersey
I'm going to spray them this weekend. Going to use acetone to thin the Rust-Oleum I'm going to spray with. Ratio advice?
svrider
USA
For spraying, Rustoleum states to thin with acetone up to 15%. I've thinned significantly more before to get a good spray pattern. I'd start with 6 paint : 1 acetone and test spray pattern with your gun. Good time to figure out gun settings as well.
Also, if you don't want to sand the interior walls do yourself a favor and at least scuff the interior with a scotch brite pad. Only takes a few minutes and will help the paint stick.
One more piece of advice, close garage doors and keep cars away while painting. Rustoleum overspray drifts pretty far and stays wet so it sticks.
Good luck.
Bunk
Alexandria, VA
Rust-Oleum themselves say:
Air Atomized Spray: Useful for many Rust-Oleum coatings. Thinning to proper viscosity is
important and usually requires 10% to 15% of the appropriate thinner. See product label for
more specific information. Avoid overthinning. Use minimum air pressure necessary for good
atomization. Several passes may be needed to achieve recommended film thickness.​
I've used their Professional High Performance Enamel before to good effect. The SDS sheet has this to say about application:
APPLICATION
Mix thoroughly to ensure any settled pigment is redispersed
before using. Thin material, only if necessary,
with acetone. For brush or roller, thinning is not normally
required. For air spray, thin up to 1-½ to 2 pints per gallon.
Do not thin with gasoline, lacquer thinner, turpentine, etc.
For airless spray, thinning is not normally required.​
Works out to ~4:1 ratio paint to thinner.
svrider
USA
APPLICATION
I've also had good luck with their "professional" line. Sprayed a few gallons of it through a purple Harbor Freight gun thinned 5 paint : 2 acetone.
I was surprised to see they recommended less thinner for the standard "stops rust" product line. Honestly I don't think it's that critical. I've used various ratios between 5 paint : 2 acetone and 5 paint: 1 acetone. Never any trouble, just see how it shoots through your gun.
I never felt the need to spray more than 1 coat. 1 nice, thick coat worked just fine since this stuff doesn't flash like automotive paint.
