Above 1200 Sq/FT Eastern Washington Workshop - Building 2
rvieceli
Illinois
Looks great.
Steven I know things are getting cozy in your main spot. Is this place close enough to maybe move some roughing out operations there or will just be a spot to off load some storage?
Ron
slodat
Central-ish, WA
Looks great.
Ron
Thanks, Ron! Time will tell of course. Once the basement is painted and I can move things down there I’ll see what makes sense in the main shop area. It still needs the second half painted. Lots of work in this one.
slodat
Central-ish, WA
Ahhhh. Big sigh of relief. The Kilz was bought in 2020 when I started the major work upstairs. I keep the building well above freezing, but you still never know with 4 year old paint. What made me nervous was it was still wet to the touch yesterday. Then my buddy @cycle61 suggested opening the door and putting the fan in the doorway to get some air exchange. I'm happy to report the first coat of Kilz is nice and dry. I feel like I got pretty good coverage out of the first coat.
The wood in the ceiling is obviously going to really soak up the paint. It did.
Even if it were left like this, it's an enormous improvement from what it was like just a couple days ago. I'm going to go ahead and do a second coat of Kilz Original. It is almost double the price the last time I bought it. My recipe with both buildings has been two coats of Kilz Original followed by a good top coat of semi-gloss latex. Going to continue that here.
slodat
Central-ish, WA
Second coat of Kilz Original went on today. I sprayed it rather heavy in the areas that needed better coverage. Initial looks are great. It's drying like it should. Plan is to spray the topcoat tomorrow. This is looking really good!
Second coat was definitely a good idea. More to follow.
slodat
Central-ish, WA
Looks good! I can only imagine how bright the space will look like when there is good lighting in there.
:beer:
It looks like this..
It’s not lost on me that this is the time to do the floors, and that it would be REALLY nice if they were ground and expoxied. It’s storage… that’s what I keep telling myself.
slodat
Central-ish, WA
Like I said, it’s storage. I have a very important client order that I’m expanding into this building for. Timeline is super tight, and I have a lot to do in order to make it. This storage room is already really nice. Maybe someday, but I seriously doubt it. I’m already pushing my luck time wise.
I’ve already got every single penny I can muster in between the two shops and all the machinery.
rvieceli
Illinois
Steven did you replace the man door with something wider for better access? Is that in the plan?
Ron
slodat
Central-ish, WA
I have the flooring tiles in the main bay of the main shop. While they were (and are) the best solution for that ****** floor, I won't be using them agian. Good ole bare concrete for me. Heavy things need to be dragged across the floor sometimes. Pretty floors are nice, but not where I'm moving heavy stuff and working with metal all day errrry day. And, this is storage.
If anyone is volunteering to come grind the floors, dinner is on me!
PugetDude
Superstition Mountains, AZ
Ron, not yet. At some point I do plan to put some form of rollup door in. Ceiling is 8' so it will be less than that in height. It could turn out I don't need one though. Time will tell.
Rollup door can be mounted on the outside of the building with a rain hood so you don't lose any headroom.
slodat
Central-ish, WA
Made some progress over the weekend.
A lot of the stuff that goes in the storage is moved. It gets put away on shelves as I go through it. I'm rather confident nearly all of it will fit on the shelves with some space to spare.IMG_5758.jpeg
While I'm far from impressed with the latest shelving from Lowe's, this did turn out well.
Two units back to back. Holds all my foam and a lot of packaging supplies.
The upstairs is now a game of tetris to get everything moved to the painted end so I can paint the other end of the building. Then I can work on raising a roll up door opening so I can move a press brake(s) in.
PugetDude
Basement looks fantastic!
Is it a partial lower floor, or will you add columns to support a brake that large?
I was wondering the same thing. :unsure:
But, looks like Slodat has it covered.
When I was working we put some press feed equipment (10 Metric Tonne capacity) on the fourth floor of an old industrial building in Hong Kong. First time I ever saw it installed anywhere but on a ground floor slab. They moved the factory a couple of years later when the Guangzhou started opening up.
slodat
Central-ish, WA
The 8’ brakes weigh around 14,000 pounds. They get a lot heavier when you go to 10’. My plan is to add an 8’ brake when the time is right. I’ve definitely considered the floor load over the apartment. Don’t want a bad day! This is why the powder coating and assembly will be on that end of the building.
slodat
Central-ish, WA
Having the windows open made all the difference getting the paint to dry. Second coat of Kilz went on quick and coverage was really good.
Top coat first thing in the morning. This has been a very long time coming! I am happy to say I’ve sprayed the last of the Kilz Original that I currently have planned. 66 gallons of Kilz in this building. All the smells and evidence of the gross and grime are gone. Clean, fresh, bright white. As it should be!
