Recently I got a case of the ol tennis elbow and got a taste of what my future holds in terms of the loss of strength. Anyway I noticed that inserting air fittings is now more difficult. Aside from removing all the pressure from the line and then cranking the regulator back up once everything is attached I figure the only option is to look for some new couplers.
A while back I've seen the Stedlin posts on here and thought that I would go that way but when I went to order a few I saw their website down. There's another post on here about whether they are in business or not, I called that number but couldn't hear whomever was on the other end due to the amount of background noise. Thinking that perhaps they were on the production floor I called it again later to not get an answer. Based on that I'm thinking it's a no go.
Prevost seems to be another brand mentioned quite often but unless I am wrong it's only really designed to make the decoupling process go easier. I've had good success with traditional Milton fittings in the past but again inserting the item into a coupler was a bear. As I'm looking for something that will make the coupling easier (and hopefully decoupling also) I thought I'd post and see if there is anything out there that I may be missing. As background I only am looking for something for personal use, this isn't something for my profession or a production shop.
