Educate me: What's this socket adapter?
70Mach1
Pics.
70Mach1
There aren't any markings on it that I can see. I'll take some measurements.
70Mach1
Ok, it measures for a 3/8 inch ratchet to 1/2 inch hex socket. Thanks for the replies. On my shelf of interesting stuff it goes.
bonneyman
Desert SW
How about an adaptor for using old style hex drive sockets with a modern ratchet? I find hex drive sockets for cheap, and with such an adaptor use them on all the beater jobs.
engineer2
Chicago burbs
Why the detent, then?
So you don't lose the plug?
You are correct, it could be for old-timey sockets that were hex drive. I've got an old set that came with large allen wrench to drive the sockets.
fartymarty
Fort Worth
Pics.
I have a set of sockets that included that adapter. I bought these in 1967 from a local motorcycle shop. I needed them to work on my first motorcycle which I purchased from an Aldens catalog. A Kawasaki 85cc JT1 with ugly maroon/cranberry paint and whitewall tires. My first metric tools set, ....OK second set, since a small set came with the bike. Made in the USA, but no info on who made them. I think the set is only missing one piece that was a socket with a 1/2 hex on both ends to connect the 1/2 hex handle to the 1/2 hex straight blade screwdriver tool/short extension. 20 mm through 13 mm.
PugetDude
Superstition Mountains, AZ
Maybe the 1/2 hex straight blade screwdriver tool/short extension is intended to fit one of the sockets?:headscrat
New or used? While Indestro, and cheaper outfits like Oxwall and maybe a few others made hex drive well into to 50's, it's unusual. Also, I don't know if your adapter has it, but you see those flakes at the bottom of the square opening of the OP's socket? That is from cold-broaching, which was replaced by hot-broaching in the 40's. Usually those flaky residuals were knocked out or jammed up against the inside with a punch pin during the manufacturing process, but you often see that step skipped.
fartymarty
Fort Worth
New or used?
Mine was sold to me as new, in '67.
...Also, I don't know if your adapter has it, but you see those flakes at the bottom of the square opening of the OP's socket? That is from cold-broaching, which was replaced by hot-broaching in the 40's. Usually those flaky residuals were knocked out or jammed up against the inside with a punch pin during the manufacturing process, but you often see that step skipped.
Mine appears punched, or jammed against the inside, that is if I understand what you are saying.
I'm sure it was, for sure it was supposed to go in the missing socket with a 1/2 hex (female) on both ends which would make it into a short bulky extension. There may have been a stamped steel/assembled funky ratchet with a hex opening that the extension fit into as a drive for the sockets. I don't remember having one, but to be honest back in the 70s when I was making not more than minimum wage and still insisted on racing motocross my tools were all mutipurpose devices that frequently saw the business end of a hammer as punches and seal drivers or what ever was needed at the time. Certainly a flimsy stamped ratchet would not have survived long in those days. I'm sort of surprised that I still have what I have of this set.
70Mach1
OP here. Thanks for explaining about the broaching. I was wondering about the material inside, and this clears up the mystery.
fartymarty
Fort Worth
To attach a box wrench to a ratchet for more leverage?
Where would the socket go?
A double box ended wrench. A variation on the old '2 wrench' cheat.
Like Old Man Roger...I don't get it.:headscrat:headscrat:headscrat
....below is what I came up with, but how is that useful in any practical way?
The double wrench would be of some leverage value for certain sizes, but would they include something for that limited usefulness?
This tool was correctly identified in post #3, then redundantly correctly identified in post #'s 8, 9, 13, and confirmed in posts #12 and #24. It is a hex-to-square drive adaptor. The 3/8-inch drive female square opening goes on the end of a 3/8-inch square drive ratchet. That leaves the 1/2-inch hex drive end to be inserted into the 1/2-inch hex drive sockets for turning.
fartymarty
Fort Worth
Well, OK, sure just bring us all back to reality...dude we were trippin' :pimpflash...what a buzz kill. :lol_hitti
(jess mssin' witcha Lug'z, you are of course quite correct.)
lis2323
Post 9 did not “redundantly correctly identify” the item. It AGREED with post 3 correctly identifying it.
Redundancy is overrated. [emoji2]
lis2323
In that case, it's a flux capacitor. (And I need to recalibrate my sarcasmometer...)
Agreed. Sorry for lumping you in with the redundancy! :)
I realize it was an overnight and an apology is redundant, but appreciated. [emoji1]
