Hey all, looking for suggestions for heating (electric) a pole barn with 19' ceilings.
The main shop space is 30x40. There is a storage mezzanine in the last 15' of the 40' depth wall. So a 30x25 space with 19' ceilings and a 30x15 space with 10' below and 8' above the mezzanine.
Current plan is to save the cost of running gas and install some solar panels to help offset the cost of electric heat.
Insulation- will have R-21 in walls and R-49 in attic space.
Location- Western Colorado, temps in the teens is fairly common in winter and drops to single digits and a bit below at night on occasion.
Usage- Not frequent use in the winter. But hope to be able to heat things up for occasional use of shop space and workout space. Primary space used will be under the mezzanine.
Complicating factor- there is a connecting tractor garage space with a 4 foot opening that opens up to 17x22 space with 15' ceiling sloping down to 8'.
Current thought- I'm thinking about installing electric infrared radiant on the ceiling under the mezzanine because that is where the work bench and workout area will be located. Also planning to install an electric unit heater in the high ceiling area to occasionally heat the entire space.
I have been told mini splits don't make much sense due to the ceiling space or are otherwise cost prohibitive to get the necessary BTUs.
Would greatly appreciate thoughts, ideas, heater recommendations, etc.
