Well, you've seen the math in this guys situation. I don't think anyone is arguing that in a lot of scenarios NG or LP are the way to go. Just not in this guys situation. Or Mine, or Auto_Techs. I think we're just saying, "Hey, consider it because it might work just fine for you."
Which is because like 90% of posts are from guys saying exactly what you are, GAS IS THE ONLY WAY TO GO! When in reality...maybe, maybe not. There's obvious gray areas that need to be accounted for.
I believe resistance baseboards and hydronic baseboards are very different types of heat.
You’re absolutely correct and I tried to take this into consideration. For human purposes it’s best to keep “electric” heat close to the ground(or near any cold draft or Windows). Hot air rises. Down Circulation keeps the air comfortable. Most electric heaters have a fan to direct thermal Air if not baseboard.
Efficiency of the heat is one thing, efficiency of the building it is another thing. The available sources of heat need to be Waighed by the customer , with efficiency knowledge.
I have about 450 square-foot shop/Garage that is attached by two walls and the ceiling. The two exterior walls, One with garage doors garage doors are R9 and the other exterior wall is R12.
I like to keep my shop at 70°F, the outside temperature today is -11°F. The 81°F differential I am running 95% NG, and 5% electric. At my main job that I’m using NG, I just keep the thermostat always at 70°F.
My other shop only has electrical and Wood heat. I don’t keep that shop to operational/Working temperatures. First thing I do is turn on the lights and then 2=>5000W Electric heaters, then I lite the woodstove and usually walk around the property for half hour. Within an hour the woodstove will maintain comfortable working temperatures. The shop is very well insulated with R20 walls and R50 attic.
Electric heat and wood heat is very dry (and very efficient). Electric heat is considered high efficiency with a high expense. Wood heat is dependent on your free source. for a sudden change in heat to metals, looking for moisture in shock of cold, Electric, wood, high-efficiency gas are your best heating sources.
Below is my heating situation for Home shop. 5000 W heater and 30,000 BTU NG
