PCMusicGuy
So I received my electric hoist (Northern Tool brand) and opened up the control pendant and motor box to see how it worked. As best as I can tell, it is a single phase induction motor with some kind of momentary switch for control the rotation.
Above is a picture of the back side of the switch with the up/down buttons on it. The red switch is an emergency stop which cuts power going through the switch. From the switch's perspective, pushing the up button connects pin 1 to pin 5, and pushing the down button connects pin 1 to pins 2 and 6. You can see that pins 3/4 and 6 are always connected with the design.
I've not been able to locate a schematic for the hoist or the JDNN LA137 switch. That said, From what I can see pins 5 and 6 go to the motor and these are what controls the direction. Pin 1 is where the 120V comes in from the plug. The neutral is wired directly to the motor.
I would like to source another momentary type switch that I can put on a wall plate to provide additional control to the hoist instead of only using the pendant. Would anyone be able to provide some insight as to where I could find such a switch or to how this hoist's control might work?
Thanks.
Thanks.
