Electromagnet?
kooldino
South Jersey
I could find some use for an electromagnet in my toolbox. There are times that I need to clean up shavings, and using a regular magnet is a hassle to constantly clean off.
Any advice?
Patz
Norway
How about one of these?
I have also seen other (better) types of this tool, but i can't remember where.
Patz
Norway
How does it work?
Basically just a permanent magnet attached to a rod inside a tube.
When you push/pull the rod the magnet moves inside the tube.
You pick up chips with the magnet at the front. When you pull the magnet back the chips are caught by the plastic ring, and as the magnetic field decreases, they fall off.
OccupantRJ
Eastern North Carolina
Put the magnet in the finger of a rubber glove, pick up shavings, remove magnet from inside glove, shavings fall off. You'll have to upgrade the idea from this. We use shop vacs for shavings every day at work, but they are devoted to this. They have the 2-1/2" hoses.
bgott
Houston, TX.
Stick a regular magnet in a plastic bag. When you need to clean off the magnet, pull off the bag.
ourkid2000
Nova Scotia
I see where you're going with the electromagnet idea but the thing is that once you remove the power, the residual magnetism that results will still be present and you'll still have the same sticking problem.
I like this idea: "Stick a regular magnet in a plastic bag. When you need to clean off the magnet, pull off the bag"
K
kooldino
South Jersey
Great tip! That should definitely work.
dps
I do similar with plastic bag, but use rigid container instead. I have a doughnut sized magnet that just fits in the bottom of a cottage cheese container that I can hold comfortably and wave over the area, then stand over trash and remove magnet momentarily.
A nicer version is found in old-fashioned hardware stores for buying nails by the pound out of the bins.
