Emergency/backup lighting for shed?
PCustoms
VT
Working on a shed, will have power (while thread about it).
Would like to have some sort of remote backup lighting for when the power goes out. Maybe a light outside the door and one inside.
Edit: light should come on when power goes out.
Not looking for the world's cheapest no name solution, but also not looking to spend hundreds on commercial fixtures.
P
PCustoms
VT
Battery powered lantern?
Flashlight?
I'm looking for a wired solution that comes on when the power drops.
Lithonia has some remote heads that would work, cheap enough too, looking for a controller/battery now.
P
PCustoms
VT
There are some flashlights that plug in and turn on automatically when they lose power.
Also, cheap "EXIT" signs with lighting would work.
I just saw some 12v LED bulbs with screw bases. No name Chinese, but honestly checks all my boxes (even has a remote).
I could use a cheap porch fixture and a screw base inside.
N_Jay
12v Edison screw base are RV bulbs.
You could build a battery box with a relay AC powered so it comes on if the power goes out
sparky 1971
Central Iowa
This may be way too simple of a solution for Garage Journal, but if it were my shed and I wanted emergency lighting inside and outside, I would use something like this inside:
or this:
And since it's remote capable, I would use it to run one of these outside:
You need a box with 120 volts for the inside and a low voltage cable run from there to the outside fixture location.
P
PCustoms
VT
or this:
Ouch on the price, but that's exactly what I want. Found the remote lights earlier, just had not found the main box yet
sparky 1971
Central Iowa
jlv03
SE IA
Maybe something simple like a standard lightbulb with a battery?
P
PCustoms
VT
Thank you!
This appears to be the name brand version of something I posted above. Much more comfortable have a GE branded device plugged in 100% of the time then some random brand.
