Do I need to pull a ground (THHN/THWN) if using EMT if the first metal box is grounded with a green ground screw?
I think I prefer to pull one though. So at each box the ground wire needs to ground the box and receptacle, right?
also, where it is coming in the first box through the garage wall, (romex) is it acceptable to just wrap the ground wire around the ground screw without cutting it before going to wire nut. Saving some space.
