penright
Was the comment directed toward the OP or @Zippercat and me or both?If I do something like that I make sure it doesn't miss the intent. There is a good reason for most of the rules.
As far as drilling screw holes for mounting, I could see where it could be an issue. If the screw head rub on wires, but that could be the same thing with existing mounting holes.
I can see according to letter of the law creating a mounting hole would be modifying it. My question is were do you find state if it is field modification or not. I have seen electrician use a punch and make a hole in metal box for conduit. I guess that would be an example of being listed for field modification.Unless it's listed for field modification, modifying it makes it unlisted.
Bottom line, I am not worried, I am using flat head screws to hold my boxes. Just like most of my questions on here are about education.
