EMT LB Body Through Wall To Panel
atvkid4eva
Cleveland, OH
I am running some 1” EMT for a welding circuit. I am to the point where I need to pass through 7/16” plywood and then go up and into the bottom of my sub panel. I’m thinking that a LB body is best for this to pass through the wall and it will give me a spot to pull the wires. What would you guys recommend I do behind the wall? Flexible conduit of some sort? I would prefer to not remove the plywood if possible. Let me know what you guys would do to make this as clean as possible. Pics below for reference, I have not drilled the pass through hole yet. Thanks!
jeepxj
if it was me:
I'd use a 4x4 surface mount box. that would let me get a bigger access hole into the plywood that would be hidden by the box.
I'd cut the vertical section of surface mount lower a bit to keep it out of my sight line. bring the conduit into the side of the 4x4 then use a blank plate when all done.
from the back of the 4x4 surface mount box i'd use flex. either smurf or liquid tight.
i'd drag a bonding ground in the smurf tube/LT to the box/conduit just to be on the safe side.
a photo journey:
or
jeepxj
Flex won't work as the radius is too tight. I use telephone 90's like this.
depends on wall thickness. i took that wall covering to be a pole barn so at least 6x6 if not 8x8 depth plus 2x girts.
LXCam
So you add a coupling and a ****** to the male side and to the LB.
Then you cuss like a muthaFr getting that last #8 in and around the radius.
jeepxj
I like this a lot. Simple, no need for buying a bunch of extra conduit or figuring out fittings. Two NM clamps, 4' of romex by the foot, a box and a cover.
also you can snap the romex connector into the panel from the inside. much easier on the fingers.
Max
Georgia
I just install the clamp on the wire, feed it up to the panel and use my manly fingers to install the nut from inside the panel.
That is a clever approach. I am sure I’ll use that down the road - thank you. :)
sparky 1971
Central Iowa
mike93lx
Richmond, VA
I'm famous for dropping out of the bottom of the panel with romex to a single gang box, then putting a Raco 187 over the single gang and running EMT from there. The size of the single gang hole makes it a lot easier to get a hand in there and grab the cable.
The tales of your accomplishments are known the world over
cmandp
New Jersey
Reading to write into the eletrical install tricks memory bank for future use. I plan on running EMT in the garage once we get a new feed and subpanel installed.
Norcal
It's a method I have used myself, works great.
Another twist, used a Bell WP extension over a spare conduit & box to run conduit for a welder, little nicer looking then the four square extension.
Jim greengo
Behind my house
if it was me:
a photo journey:
or
I'd probably do a 4 11/16" box,easier to get that 1" pipe into it,and still have room for wires.
