End mill question
1982fxr
Phoenix
Are these new?
Firebrick43
West central Indiana
The right three look new or properly resharpened. The left one (same one holding in your hands???) looks like it may have had made a light finish pass or two made with it or it maybe just lint on the corners and camera angles
1982fxr
Phoenix
Backstory: I'm not a machinist. Got them from a retired machinist who said they were new. Looked new to my eyes and I didn't see witness marks on the shanks.
Sold those exact 4 on ebay. Packed them real good. Buyer started a refund and sent this message and this one picture.
"Just received and opened this package today. These end mills are used, not new. The cutting teeth are broken and the edges of the flutes are chipped."
1982fxr
Phoenix
I'm looking close at some others. I can't get my camera to focus up close but I think I agree with you guys. I see tiny nicks here and there on a couple.
I'll try pics again when I get to work and have better light.
If these are nicked up like my first pics appear to indicate, do they have any value?
whateg01
doo dah, kansas, usa
Value? Yes. How much? Depends on the price and what it would cost to have them sharpened and how much the size difference would matter to you. Also depends on the brand. If it's a $20 EM from Amazon, they would have to be almost free, imo
1982fxr
Phoenix
They are the Accupro part # pictured above.
badmatt
America's hat.
That’s MSC pricing.
Likely those end mills are around $30 a piece new from a machine shop supplier.
It’s whatever the market will bear at this point. The influx of cheap tooling for hobby machinists is astounding. So these may be a tough move - depending.
whateg01
Fwiw, I don't think any have been sharpened since the coating on the bottom appears untouched. I missed that you were selling them, or had sold them. I would also return them for not being "new".
Just for fun, I pulled this sheet from the web from a sharpening service. $21 each to hit the sides and ends.
hpmachining
Are these new?
No, all 4 show signs of wear on the cutting edge of the flutes, so if you sold them as new you should refund. FWIW, I haven't used that particular model, but I have used this Accupro end mill to rough the perimeter on thousands of these aluminum parts, 2.0" axial D.O.C, .05" radial D.O.C at 130 I.P.M. To be clear, I used one end mill to cut thousands of parts and it's still going. I find them to be high quality, made in U.S.A end mills. That being said, I don't generally buy used end mills, but they are still in decent shape. They are selling new for ~$45 (sale price) on MSC which is a decent price for a quality 1/2" carbide AlTiN coated end mill, so price accordingly.
RoninB4
Under My House
They were removed from the Accupro individual containers and kept in bulk in a shop bin.
-The individual containers, if I understand what you're calling them, are to prevent the cutting edges from one EM coming in contact with another. Cutting tools like end mills, taps, reamers, etc. should not be allowed to contact others because chipping of the cutting edges is possible/likely, especially with carbide. The only thing a cutting edge should contact, besides your fingers, is the material it is supposed to cut. Bulk storage without some protection is almost a guarantee of chipped edges, doesn't matter whether it's been used or not. A simple test of fingernail along the cutting edge usually finds a nicked/chipped edge.
dr_clyde
Holland, MI
They look used and re-coated.
Coatings in new or like new condition are not a valid indicator of whether a cutter has been re-ground as they typically will re-coat high performance cutters. I know because I have several regrinds that are re-coated.
Why don't you measure them?
Re-ground cutters will be less than their nominal value. With a 4 flute it's easy enough to check with a standard micrometer. Just measure across the flutes for the largest value. If it matches the nominal diameter, they're not re-ground, but if they're a few thou less (anywhere from .005" and up) they've been re-ground.
Even if they are "new" they're chipped and damaged from banging around in the drawer outside of their box or wax coating. I personally don't want to buy chipped end mills, especially for new prices.
whateg01
The don't appear to differ in diameter from the shank to the end, but that could just be the photos. None of the em I have had sharpened got recoated. Is that something you have to pay extra for? Or a special request?
Sweetcorn
North Central Ohio
Those are commodity endmills in standard lengths. They're Accupro on top of that.
Its not worth the time and expense to resharpen and/or re-coat those.
I absolutely agree with the buyer who said they are used. The cutting edges are chipped. I would initiate a refund to him.
While they still may be serviceable enough for jobs where the surface finish isn't critical, they won't perform as a new mill.
dr_clyde
Holland, MI
It costs extra, so you do need to request it. Not to mention there are LOTS of different coatings, so you would need to communicate what you want when you get a re-sharp cut.
It’s also hard to tell by eye if it’s been sharpened unless they are grinding a lot to take out chips or something. It only takes a few thou to sharpen an edge, any more is wasteful.
dr_clyde
Holland, MI
Looking at those pictures again those cutters definitely look used. The coating is worn along the cutting edge consistently and is chipped and polished where it’s worn.
