Engine crane, HF 1ton or 2ton ?
NY outer borrough.
I need to get another crane soon, my old one is still busted and I needed a second one anyway. So which should I go for? Is the 2 ton model significantly stronger than the 1 ton ? Are there any coupons available for the 2 ton model ?
finn
The UP, God's country
Look at the boom length. Smaller cranes don't extend far enough to be useful, and may not have enough lift arc to get something high enough to slip it in a truck bed.
Get the bigger lift.
unslow1
Illinois
I've seen coupons for $179 for the 2ton. $99 for the 1 ton. Check the HF coupon thread.
Hemmings has the 1ton $99 coupon.
ibedayank
Columbia TN
can use something made to lift heavier weight to lift something lighter but can't use something made to left less then what you want to pick up!!
CGarcia
Houston, Tx
I just picked up the 2 ton. Its on sale for 199, used a 25% off coupon, so 150 out the door. It doesnt really take up any more space than the 1 ton, so I didnt even consider the 1 ton.
GRX
MD
QFT (quoted for truth)
Vegaman_Dan
Pacific, WA
Not sure how you got away with that one since the 25% coupon excludes those very lifts. You got a good sales clerk indeed.
plain garage
Go for the 2T if space/clearance allows. It folds up into a 32" x32" footprint, but the legs need 6" height for clearance.
trpearcy
Western PA
I'd say get the 2 ton. Heavier duty=lasts longer.
Also with the bigger one you'll basically be able to rest assured that you're not near the limit, at least with light duty and medium duty vehicles.
yfzjim
I got the 2 ton as well with the 25% off as well. There is not an exclusion on the lifts...
BDT/NWMN
Erskine, Mn
I agree; at that price, the 2 ton is the true winner... The 2 ton rating is with the boom all the way retracted.. Fully extended; it is rated for 1000 pounds...
I really wouldn't want less than that if working on a full sized vehicle.. That extra $51 for the better crane is money well spent. :bowdown:
Jason280
No question about it, go with the 2 ton model...and make sure you get the folding version.
sz0k30
Don't even consider the 1 ton. There are 2 things to keep in mind:
1. The weight capacity. You don't want to have any concerns when you've got a big block and trans at full extension.
2. The boom extension length. On some cars even the 2 ton extension isn't really long enough. Like my buddy's 1970 Pontiac Grand Prix.
In my area the HF stores won't accept a 20% or 25% off coupons on top of "Super sale" items.
redwrench60
East Tennessee
Don't bother with the one ton hoist. It's useless as man *****, the boom length as everybody has mentioned is too short to reach most engines center points and with the boom fully extended it only lifts 500 lbs. I say again......useless as man *****.
NY outer borrough.
Okay cool. The Excalibur crane I have has been long enough for everything I ever needed. I never considered that the 1tons would be shorter.
