edcantu9
2005 Escape V6 3.0. Engine shuts off at first stop light every morning.
Starts back up without issue. Drives normally the rest of the day.
I have plenty of diagnostics equipment. And can track live PIDs.
I smoke tested for vacuum leaks. None found. Vacuum levels are normal during idle and drive.
Fuel trims are excellent.
Fuel pressure is normal before startup and after prime and during driving.
Engine cooling systems are normal.
Fuel injectors are without fault.
AIC shows no fault. Voltage changes according to throttle.
CPS shows to fault. Voltage changes as well.
The truck only shuts off at the first stop light every morning. I looked at all data and nothing seems abnormal to me
Any suggestions?
Any suggestions?
