Engine Specialty Tools
Ed in Virginia
Montpelier, VA
@d42jeep -
Your model 600 K-D valve spring compressor appears to be held together with two cotter pins, if I am seeing things correctly.
The unit shown on Alloy-Artifacts appears to be held together with two "wing screws".
The one I picked up yesterday is held together with two very mangled cotter pins.
Which begs the question: Alteration by previous owner? Production change? :unsure:
I'll bet there are more than two copies of this one among the membership. Curious as to what the others look like.
Not a great shot for comparison, but maybe this snip from a 1950 K-D catalog may help: 1758811787760.png
^ The photograph image and the drawing in the 1950 ad look like "wing screw" to me.
I'll have to find some new cotter pins for this one after it's done soaking... I think this batch of Evaporust is getting tired- it might take a few days, but I'll be gone, so no big thing.
A
Ayrhead
Ontario
Three Valve Spring Lifters: a Sunnen, a Bluepoint CF-49, a ClarkFeather Mfg. CF-12 and a ZIM Valve Spring Compressor.
Ducky
Southeast, Alaska
A K-D 912 Valve Spring Compressor.
Oh boy, this tool brings back memories. Back when I worked at a marina in the 70s/80s I used that tool along with some 1/4" rope to change out the broken valve springs on a bunch of Mercruiser 470/485 motors. If you were lucky you did just the springs, if not you had to pull the head because the valve hit the piston. Good times.
A
Ayrhead
Ontario
Well, thankfully I only display these tools in the back of my 1962 Chevrolet Corvair Rampside Pickup Truck at cruise nights. They never actually get used…
Ed in Virginia
Montpelier, VA
K-D 380 Ford overhead valve spring compressor
Ed in Virginia
Montpelier, VA
K-D 503 Self-centering Valve Grinder with box
Ed in Virginia
Montpelier, VA
K-D 900 Valve 'Hi-Offset' Valve Spring Lifter
Ed in Virginia
Montpelier, VA
K-D 917 valve guide retainer (keeper) remover
Ed in Virginia
Montpelier, VA
K-D 920 Valve Guide Puller Kit with 917 and 918 tools, and 923 adapter for 6-cyl engines.
These are gold to folks who still like to wrench on flatheads with tools from that era.
  • K-D 923 Adapter for 920 Service Kit for Ford 6 cylinder - close-up of part number.jpg
Ed in Virginia
Montpelier, VA
K-D 925 Valve Guide Replacing Tool
