Spudland_Dave
EPIQ Workbench Build
I've been holding out on you guys...the past few weeks I've been working on what I dub my "EPIQ Workbench" for good reason...she will be rocking an EPIQ Drawer.
Bench is constructed of 3" Square Tubing Legs, 4000lb Pallet Racking Cross Beams...lower shelf designed so I can easily pick up & move the bench with my pallet jack. NOW its time to mount the drawer....just taking some measurements (measure 3x cut/drill/grind & weld once kinda guy). So I noticed the slides are mounted at an angle on the drawers...now, in my pea brain, I assume the other side of the slides gets mounted at a similar angle so the drawer sits level...now is my thinking correct? So when you open the drawer you essentially pull it "up hill" and the drawer stays level the whole time.
Secondly...EPIQ owners...do your drawers self close? just thinking with as much rake as the slides have, a fully loaded drawer must close VERY Easily if not by itself?
