First, thanks for view this thread. I've begun the floor finishing process and I fear I have a problem.
Outline:
Area - 2200 sq ft.
Slab - 68 days old, vapor barrier, moisture test completed before application
Prep - diamond grind
Product(s) - Legacy Industrial Epoxy Primer, SD Premium Epoxy
Application Temp - 81 degrees F
Humidity - 51%
Application:
Helpers - 3
Epoxy primer - mixed as directed, rolled on no issues (to my knowledge) waited 7.5 hours, no fingerprint.
Epoxy (SD Premium) - Mixed in three gallon increments as packaged. Mixed in new, clean 5 gallon buckets. A new and clean bucket was used for each batch/mix. Mix was pre-measured. Mixed thoroughly (4-5 minutes with mixer purchased from Legacy).
Epoxy was dumped in a ribbon(s) as directed, spread with 1/8" squeegee, and backrolled with 3/8 nap lint free roller.
The problem:
When we were applying the epoxy, we noticed some darker streaks in the light gray color. These streaks ran parallel to the direction the squeegee was used. Since these streaks didn't appear until moving on the the next section, we assumed the epoxy was beginning to "flash". We were all thrilled with the results as it was "instant pretty" taking only about an hour a 15 minutes to apply.
The results:
This morning before mixing the first coat of Urethane (HD322), the floor was checked to insure it was ready for the next coat. The time since application was 9 hours (temp and conditions above).
What we have found is that 1) significant outgassing has occurred 2) The epoxy has not cured in the darkest of these "streaks".
Outgassing - I can live with this unless somebody here tells me it will hamper performance. Also, I'm thinking that the HD322 with some anti slip in it will help it blend in.
Cure - This is my main concern. As I write this, my help and I are sitting at McDonalds waiting/hoping it will just take these spots a little longer to cure.
Questions:
1)It has now been 11 hours, some of these streaks are tacky enough the just a little bit of color comes of on my finger when I gently wipe. I think it's gotten a bit better over the last couple of hours. Will it cure?
2) The vast majority of the floor cured. These streaks are anywhere from 20-30' long and seem to match the width of the roller. Many of the streaks have cured. Given that it's been more than 12 hours, what will I have to do to the floor for it to take the urethane if the epoxy all cures?
3) What did I do wrong? I can't imagine that it needed additional mixing as these "streaks" are not uniform across the floor, but only appear in length. Example, much of the same batch cured just fine.
Your input is needed.
Thanks,
Reflex
Outline:
Area - 2200 sq ft.
Humidity - 51%
Application:
Helpers - 3
The problem:
The results:
Questions:
Thanks,
Reflex
