raymon1717
- Joined
- Sep 15, 2006
- Messages
- 17
If I wanted to do a second coat of Epoxy-Coat, what type of prep is required?
raymon1717 said:If I wanted to do a second coat of Epoxy-Coat, what type of prep is required?
snorvet said:My first coat had a lot a air bubbles that hardened. So I waited a few days
and rented a floor sander and sanded the floor with 20 grit. Then I applied a second coat of Epoxy-Coat. Everything worked out ok
raymon1717 said:OK, thanks. I was hoping it could be done with just sanding. Did it remove alot of the first coat or just scratch it up so the second could adhere? I assume then you just swept out the dust. Did you wash at all with water?
69lkmno said:You can just sand it. Check out the link below.
snorvet said:The sanding smoothed down the bubbles, scratched and dulled the finish, but didnt grind through the epoxy. I just vacuumed and swept the dust - no wash.
