I looked into their product line a few months ago (got to keep up on the marketplace!) and my notes indicate that for their base epoxy "Mix 2 parts "resin" to 1 part "hardener" by volume"
For their polyurethane clear it looks to be 1:1.
That's what my notes show, other than some price stuff, but to be safe, you should look for verification on the product containers or their included instructions.
Can't you use the mix stick and back out the ratios? If they say fill to "X" with part A, and then the fill mark for part B is half the height of that for part A, the it would be 2:1. BTW since they sent a calibrated mix stick, and didn't send a scale, the ratios are likely in volume, and most mixing ratios, at least for consumer end users, are in volume, not weight.
If you're not positive 100% about the mixing ratios, you shouldn't mix 'em.
