Welp, my floor has been drying for 1.5 days now and looks great. I wish I would have sprayed the entire floor with degreaser, because there were a few random spots (absorbed oils undetected at the surface?) where the epoxy separated (like soap with oil does) and didn't want to stick. Back rolling after 10 minutes minimized the problem to very small separations and the flakes and nonskid blend it right in. Also, we had a huge amount of Part B leftover, and ran shy of part A by one cup
. Rich did a follow-up this morning with me on the application, and I mentioned this to him. At first he said that there should be a perfect 2:1 quantity of parts A and B. But I explained that I wasn't alone in this phenomenon, and that if it were truly 2:1, that even if I wasn't astronomically precise with the marks on the stick, there should not be 2 inches of part B leftover and a shortage of part A... I plan on scraping out and disposing the remaining epoxy and measuring how much water each container holds. Rich said that it does seem odd and that he'd check up on it. Hopefully this can be solved for future DIYers, as it degrades the perception of quality for the company. If not, I'm sure if you're careful with your measurements, even if you're missing 1 cup of Part A at the end and have ample supply of part B, then a 1:1 mix works just fine, it just reacts allot faster and doesn't cover as much area. However, if you have more Part A than Part B, only use up to a 1:1 solution. I'm afraid that if there is more part A than B, it will not react/cure completely, and you'll have one sticky mess. I also recommend pouring the epoxy 6 inches or less from the starting wall, unless it's a ledge (where epoxy can overflow). This saves time by not having to use the cut-in brush on that wall, and gives the edge a nice, consistent look (and no brush-strokes!). If you can't back roll perpendicular to the squeegee (b/c of not having spike shoes, etc.), then do it parallel, just back roll it twice each session to even it out. I didn't have spikes, and just back rolled twice whenever it called for it, and it looks great. One last tip, don't apply it at night if you have moths/bugs flying around (unless you're too lazy to wake up early in the morning to beat the summer heat, like me).
This new floor coating is part of a larger DIY garage renovation project. I've applied knock-down texturing to the walls, painted them, stained the utility room floor and interior garage foundation walls before applying the epoxy-coat. Putting up freshly painted trim today. I bought lumber for shelving, which I'm going to stain today and install tomorrow. I should have some pics coming by tomorrow or the following day.
