Great looking garage!
For the people asking about longevity, GB70's 4 year old floor installation still looks great and has no issues.
I did it in a garage I had 3 houses ago.
I would not do it again. I had trouble with rows of tiles shifting from the force of the tires. I think I used an inferior glue. I would recommend a better glue if VCT is used where cars will be parked on it. Maybe an epoxy type glue. However, this increases the cost.
Applying epoxy on them is something I did not do. But, I would be concerned with yellowing if white tiles were used. And, I like the black/white checkerboard combo. You could look into other non-yellowing clear coatings.
Roger55,
Inadequate preparation and substandard materials will sabotage anything. Posting that you would not use VCT because you had a problem after using cheap glue is like posting that you won't use epoxy because you didn't prep properly and ended up with hot tire lift. The OP also pointed out that there are no posts about yellowing of the box store Rustoleum and Quikrete clear epoxies. I just did a search and confirmed the same. No offense intended. You have a lot of great posts, but your experience with VCT seems irrelevant and your concerns about yellowing seem unfounded for the products in question.
Well, my hopes for possibly doing this in my garage are shot. I contacted Armstrong, maker of VCT tiles, asking them which series they thought would be best for a light-use garage application (I used epoxy in the shop garage, but for the parking area, I thought VCT would look slick). Their response:
Redshift,
I emailed Armstrong a while ago and requested samples of the same tiles GB70 and ATLM used and the safety zone rippled tiles, stating it would be for a residential garage. They sent the samples, but also sent a similar but much shorter legal email response. It sounds like the lawyers have gotten more involved and Armstrong has chosen to beef up their self protection from potential lawsuits. Since the majority of their revenue is commercial, I think they're more worried about homeowner DIY stupidity, lawsuits, and keeping up with thousands of different residential building codes than losing a few dollars through lost home project sales. I personally trust real experiences of others with identical products over lawyer jargon.
im thinking about doing this in my detail shop but i dont know if it will hold up. the amount of traffic that i have on my floor each day is alot more than if you moved your car in & out of your garage a few times a day.
what is the durability of this stuff? can anyone tell me? ive read about people using 2 layers of tile then sealing everything with a few layers of clear.
AndrewBigA,
Armstrong VCT is a commercial grade tile, used by Walmart, grocery stores, Sears, and other high traffic areas. Okay, Sears might not be high traffic anymore, but you know what I mean. If the traffic in your detail shop is just cars driving in and out and people walking around and cleaning, VCT will work well and so will the other 3 popular garage flooring materials. If you choose VCT, there is no benefit to installing 2 layers.
ATLM,
Good job, and thanks for the detailed informative post.
