Hey everyone.
Our garage floor is pretty evenly pitted throughout the entire surface. I like the look of the epoxy flooring options.
I am still in the research phase of the project, but what is the best way to approach this pitting prior to applying epoxy?
- Should I use a concrete resurfacing product to resurface the floor prior to the epoxy coat, followed by some grinding to smooth the surface over? Is that typically the best approach?
- Instead, could I just rent a grinder and smooth the existing pitting over with that? My only fear is that a lot of the pits are ~1/8" deep so I would need to take off quite a bit of material.
- I assume that this pitting would show through if I applied the epoxy coat directly.
What is the best approach to get the floor ready for an epoxy coat?
