Epoxy floor cleaning
10PreRunner
I have an epoxy floor in my garage with a heavy flake in it. The installer said not to use a soap to clean the floor because I would never get it all washed up because of the flakes and it would get slick when it got wet the next time. Whats the best thing to use to clean my floor? Thanks for the help!
Shea
California
1/2 cup of ammonia to 1 gallon hot water works well. It won't leave a film or streaks on the surface.
CJseven
Southeast Missouri
I too have been wondering what to mop my new floor coating with. I have to clean my new floor for the first time. :) I rented a scissor lift to do my lights and wiring, it was wet and rainy the day I brought it home and left a bunch of tracks on the new floor. :)
Armorpoxy
We have found that Simple Green also works well to clean epoxy floors. A Magic Eraser can help with stubborn marks and such.
Flnole78
Did you put a topcoat over the epoxy and flake? Seems like if you did you could use whatever tip clean it as long as you rinsed it. If not the ammonia and water mix should do it.
TJMtl
Montreal
I just got epoxy and flake in my garage as well, will try simple green and water when I wash it for the first time.
