Above 1200 Sq/FT Ernie's Place
drivesitfar
Storm: if you go in you USER CP and click on LIST SUBSCRIPTIONS all the threads you post on show up so when a new post on one of them gets posted it pops up on the top of the list. also the ones you haven't read stay in bold print until you do.
another good option i've found in the USER CP is I can view the latest post first so if I'm following along on a thread I can see the latest posts first. also there is a setting where you can see 100 posts per page instead of I think 10 posts per page is the default when you join.
i'm still learning about a lot of things and if I can pass on anything that might help I usually do.
here's a knife my son in law gave me that he received from a handy old friend of his made out of an old RR spike. you'll need a forge and probably an anvil, but you now have the grinder to make one for yourself.
TylerRNEMT
Pendleton, IN
Contrary to your moniker…those are some good ideas, thank you! I already have North Carolina, but do not have Virginia. Appreciate the consideration!!
And speaking of plates…her family came over this past weekend to celebrate Christmas and the in-laws found this at an antique shop and thought I should have it:
20181215_162012
Evidently during war-time when resources were scarce some states used pressed soybeans to make their license plates. Pretty neat and happy to add it to the collection!
Scrolling through your post and found this pic of the Illinois plate from 47!! My great uncle was a civil engineer in Illinois during that time frame and my grandpa happened to have some of those plates in incredible condition also!!
I have them hung on my work bench... I have a 46' , 47', and 48'.
You can see them a little bit in this pic top left on the pegboard.... I’ll try and get some better pics
rattle_snake
Chandler, AZ
Nice work on the grinder Todd. I like the color too. You're going to really like having the machine when its done, big time saver.
jh1990
Awesome thread. Wished I knew about it earlier. Love the belt grinder. I'm working on one as well. Just about to weld the tracking post to the frame.
Also those fireball squares are awesome. Been a lifesaver on this project.
StormcrowAz
Phoenix, AZ
Drives – Thanks for the tips and that’s a pretty cool knife. I don’t have a forge (yet) but do have a section of railroad tie I sometimes use to hammer things on. I also still have a few of those railroad spikes laying around and might have to see what I can do with one. Put it on the to-do list…
Tyler – Cool collection of old plates and that looks like a nice work-space you’ve got there. Thanks for stopping by!
Jh1990 – Thanks! You should start a build thread!
Farty – Nice plate and sure, join on in! Looks like your plate is in good shape and has a few less holes than mine. ;) I wouldn’t have thought soybeans would hold up as well as they have for this long.
Been pretty busy lately so only small steps towards completion of the belt grinder. Wanted to make some knobs for the tracking adjustment, table, and tooling arm holders. I’m not much of a wood-worker, so stuck with metal. Used some of the same 3/8 plate as the rest of the grinder is built from. Started with the tracking adjustment knob. Scribed the outline and drilled some holes.
20200111_071348
Some work on the portaband:
20200111_091722
Cleaned it up with a flap disc and die grinder. Welded a nut to the backside and good to go (besides paint)
20200111_102613
Bought some material for the new table. 3/16 plate for the top and 1.5” square tube, .125” wall, for the legs. Put the top on the Workmate to check placement. Will need to notch the back to allow for motor clearance in horizontal mode. Added a 4’ LED light above which helped a ton. Also had to move the drill press over a bit and the bench grinder to a different location entirely.
20200112_104501
I also had a cord reel hanging right about where the drill press is now, so had to relocate that. Added another outlet and hung it between the man and roll-up door.
20200107_181612
I changed the oil in the Tacoma a couple weeks ago and noticed a small oil leak at the drain plug. I’ve read some positive things about the Fumoto valves and thought I’d give it try. Easy install and looking forward to seeing how well they actually work.
20200110_165224
losdudes
Colorado
I've had a Fumoto valve installed on my 05 Duramax for several years. I have had no leaks at all. It had a small cover for the ****** but it disappeared. The only issue I have is it takes much longer to drain the oil than before.
drivesitfar
Storm: it's nice to see you found a decent spot to set up your newly built belt grinder and that new part you made for it looks great.
keep up the great work!!
zmotorsports
Northern Utah
I've used the Fumoto valves on my last coach with a CAT engine and my current one with a Cummins ISL. Flow seems to be a bit slower but it's nice to not worry about thread degradation. I use a snap ring around the lever on mine to avoid accidentally bumping the lever but I doubt it would ever be an issue as I didn't have any problems on my last coach.
StormcrowAz
Phoenix, AZ
Losdudes – Thanks for your input and glad to hear it’s been trouble-free for you. Seems to have taken care of my leak and I have no problem leaving it on the lift for an extra few minutes while it drains. Will probably use that time to do the undercarriage inspection. Thanks for stopping by!
Drives – Thank you! I’ve got three more of those to make, just a tad bit smaller. Stopped with this one, though…when I realized how much easier it would be to make if, you know…I had a belt sander. ;)
Mike – Again, good to know they are working out for folks. Not sure if it’s a recent addition, but this one came with a little plastic clip that you need to physically remove in order to actuate the lever. I certainly appreciate the feedback, thank you!
Been a slow couple of weeks, progress-wise. Between a quick out of town trip and then getting sick, not much has been happening in the shop. I was able to get some stuff done this past weekend, though.
Wired up the VFD for the grinder. I purchased a couple extra switches (forward/reverse, and the main on/off switch) specifically for this unit. They were really expensive for switches, I think…but they did include everything needed to install it including the extra wires with connections attached, wrench to tighten it down, dust-cover boot, and little zip-ties. Plus it came with instructions even I could understand. You pay for convenience, I suppose. Also, I was only able to get one of the liquid-tight fittings to work. The VFD only had one 3/4” hole with two 1/2" holes. The 12/3 cable was just too big to make it work, but the 12/4 fit just right in the bigger hole. Ended up using a regular EMT fitting which seems to be just fine, keeps incidental tugs from putting stress on the interior connections but may not be technically “liquid tight”. It does appear to be plenty tight to keep metal dust out, and since I’m not hosing this down or taking it for a swim, I think it should be ok?
20200202_102756
After a bit of fiddling, tweaking, and with the addition of a couple shims…managed to get it running fairly true. That done, I adjusted the table holder to make sure the work surfaces would be perpendicular to the platen.
20200202_102745
A quick test with a scrap piece of angle iron and everything seems to work fine. Next step is to work on the table and get it safely supported. Time to break out the toys!
20200202_131015
Notched the table-top for motor clearance and got frame cut and tacked together. Hopefully I’ll have time/energy during the week to burn it in and clean it up.
20200202_164323
I’m still on the fence about putting casters on it. Kind of concerned about stability with such a narrow (24”) table. My parts bin is similar in depth, probably weighs a lot more, and haven’t had any difficulty with that. So maybe my concern isn’t warranted. I really like having things mobile if possible. I guess I can always change it. As a friend told me once: “You do have a sewing machine for metal”.
rattle_snake
Chandler, AZ
Todd,
The issue I see with the grinder base is that you are showing off how useful your fancy fireball fab squares are. While this project is a good use for them, it has made others including me jealous leading to more tooling purchases. So I blame you for having to order a set of GMW squares.
Finallygotit
Tucson, AZ
Todd,
Todd is just another wonderful enabler......just like the rest of us.
:beer:
StormcrowAz
Phoenix, AZ
Justin – I can only take partial credit. I caught the GJ bug at some point and am just spreading the disease. I do say, though, that the fabrication squares are more handy than anticipated. I had to use The Google on “GMW” (assuming it’s Genuine Metal Works) and am thinking you are trying to get even with me by showing me more cool tools. I’m now almost convinced I need to build one of those neat fabrication tables with all the holes in it. I just need to find me some ¾” plate, a mag drill, and, and, and…
Dan - Need….more….tools…. :)
Slodat – I think we all are! ;) Thanks for stopping by!
Been busy, seems like lately it’s been multiple things at once.
My brother-in-law had some issues with his 2006 Charger. Said it was shaking really bad at stop lights but smoothed out when driving. Put it in drive, foot hard on the brake, and gave it a little gas. Sure enough the motor jumped up on the driver side. Bad motor mount. Had him get both the driver and passenger side, just in case. Very little clearance and was only able to get to some of the bolts from the top and some from the bottom. Glad I have the lift. After finally freeing the part there wasn’t any one spot big enough for it to pass through. Had to remove the airbox tube and two heat shields, one attached to the motor mount itself and then one for the exhaust manifold, in order to gain the necessary clearance for removal and replacement of the new mount. Installing the new mount was fairly easy, but then I spent 15-20 minutes trying to get the heat shield re-attached to it. After a bit of frustration I checked the passenger side mount (identical) and found out that the manufacturer didn’t bother threading the holes in the casting. So I had been trying to thread a bolt into a solid hole. There was just enough room to fit a tap, but no tap handle. Ended up using a tiny wrench on the end to tap the two holes. I really didn’t want to remove and replace that mount again. After spending four hours getting the driver side replaced, we called it a night.
20200208_173307
Did some more (enjoyable) work on by friends Scout.
The original clutch set-up on this vehicle was purely mechanical, levers and pivot-points and such. He chose to go with this master/slave cylinder set-up. The new master cylinder fit nicely in the hole where the original clutch rod passed through. The bottom flange we were able to bolt-through for attaching, but the top flange matched up with the top radius of the box it’s mounted to, so welded a stud there instead.
20200211_164523
Made a new bracket for the slave cylinder, which will attach with two of the bolts that mate the transmission bell housing to the motor.
20200211_164554
Made progress on the new steering set-up. Had to make another puller for the steering wheel. Simple yet effective.
20200209_104909
Need some more parts to finish so that’s still pending.
Also, since we replaced the floor plans we decided to scrap the old seat base and fabricate something new. Making new framework and plan on putting in a lockable, under-seat storage drawer/compartment. The old base was bent sheet metal welded to the floor. The new one will be bolted through the floor and removable. Here’s the start of it:
20200211_164441
I did manage to make some small progress on my own stuff. Stitch welded the grinder table frame to the top.
20200208_092633
Of course the belt sander feet bolt holes line up perfectly with the frame, so needed to drill through the top and the square tubing. I didn’t like the thought of the bolt sticking out below the frame, figure if I store stuff under the table or use a chair to sit and grind things, something (knees/arms) may catch on that exposed nut/bolt. Thought it would be neat to recess the bolt-through locations. Notched out a section and welded in some C-channel. Did not think this would compromise strength too much for what this table is for. And once again, while I thought I was being cool…I turned out to be the fool. I did not anticipate that little bit of welding would warp the table, especially with all the other framework in place. I was wrong. I stuck some half inch tubing in the middle and clamped down the edges, which helped flatten it out some, but there’s still a slight convex bow to the top.
20200211_164306
If I put it top-side down and stand on the frame it flattens out OK, but it’s still a little bit bowed. At this point I’m not sure what to do. Was thinking if I cut a small slit in the square tube between the notches it would be easier to bend it perfectly flat. But then I’d have to weld that up, so not sure how well that would work, even with clamping things down well. I don’t want to go and make a bad situation worse. Also thinking that since the bow is minimal and can be flattened with some small force, that maybe when I put the legs on and put the cross-bracing between them it will force it back to flat. I’m probably over-thinking things, considering this is just a table to put my grinder on and it doesn’t need to be a surface plate by any means. It still bothers me.
This also makes me reconsider the new welding table I wanted to make. Originally planned for a solid-top surface, but now thinking a fixture table with all those 5/8” holes would be nice, too.
drivesitfar
Looking like you are pretty busy. in case it starts getting a bit warm in your shop please send some dry weather and heat up my way.
in case you haven't seen some of my threads where I talked about building a welding table here are a few of my favorites you might consider if you are building one fairly small that you want to move around. Before I had to move out of my shop i was going to build two of these a bit smaller (63x28) cause I owned 2 nice pieces of 3/4 inch steel plate that size. one option I was thinking since space is always an issue was to use them like saw horses if i was going to build a trailer or something else fairly big instead of having a 5x10 table taking up all the free space in the middle of my shop.
how do you like the belt sander and would you have done anything different if you built another one besides maybe using a belt sander to build one?
icecactus
Could you run few beads on the opposite side so it pulls it back flat, then grind off the welds? I have done that on a few occasions and it seems to work good.
rattle_snake
Chandler, AZ
Even cutting some of the existing welds on the inside will help. Next time consider drilling a hole and doing a plug weld. For a thick plate, a tab/slot style connection is the way to go to prevent surface warpage.
StormcrowAz
Phoenix, AZ
Drives – Warm and dry thoughts sent your way. It’s supposed to be in the low 70’s this weekend. A perfect time to get outside and enjoy some QST.
Regarding the welding tables…those you pictured are pretty close to what I had in mind. I’ve done my fair share of perusing the different welding table threads, both here and on the Welding Web. I especially like the bottle-jack wheel set-up and will most likely utilize that in my build, one of these days… I think a 4’ x 6’ would be good for me. Originally wanted just a flat top, no holes, as the thought of nuts, bolts, and little parts falling thru the holes does not appeal to me. But now I’m starting to think the clamping and set-up advantages may outweigh those concerns. Maybe some more magnetic trays or just plain being careful of where things are set.
Can’t say, yet, as I would do anything different with the grinder build itself. The table it will reside upon, well that’s another story. So far I have resisted using the grinder, partially due to not having a stable platform to use it on, and partially to give me motivation to finish the project in its entirety. I’m sure I could rig it up on the B&D Workmate and it would work ok, but then there’s a risk of that “temporary” set-up stretching out for an indefinite period of time. So until I get the table complete, here it (sadly) sits
20200212_182921
Icecactus – I have read about that trick, or maybe even just taking a torch and heating up certain areas to straighten it back out. My concern is that I lack the practical experience to pull it off, and would most likely end up making it worse somehow. If this was my main work/welding table I would be more worried, but considering the sole purpose is to just have a solid place for the belt sander to live on, I think this imperfection is something I can live with. Lessons learned. Thanks for stopping by and commenting. I checked out your thread and looks like you have a nice set-up there.
Justin – As my great-grandmother used to say: “you live, and you learn”. Next time I will definitely do things differently. In retrospect I should have built the frame first, and then attached the top. Not sure why I decided to do otherwise, seemed like a good idea at the time. It certainly won’t happen that way again. If I end up getting a thick plate for my main welding table, I would drill and tap holes for attachment to the frame itself. Seems general consensus on the best way to get it done without warping concerns. I think I need to do some more reading on the pro’s and con’s on going with a pre-made Certi-flat type kit or getting the plate and investing in a mag drill (yay, more tools to get!) and DIY.
So made some headway on the belt grinding table. Decided to live with the slight bow to the top and push forward with the build. Cut the legs and supports:
20200212_181846
Lots of clamping and tack welding followed
20200213_173522
20200213_190339
Hauled it over to what will eventually be its final resting place and it’s surprisingly flat and steady on the ground.
20200213_192401
And this is where the evening came to a bitter end. Somehow I miscalculated the grinder location in relation to the motor clearance notch at the rear of the table. The mounting holes I drilled in the table are off by a few inches. :mad: Fortunately the framed-out notch is the right size and in the right location to allow for the horizontal grinding mode, but I’ll have to drill new holes and fill in the old ones. I really don’t like rework. :(
20200213_192318
20200213_192306
icecactus
Thanks!
Regarding the welding table. I started out messing around with woodworking and have noticed a fundamental difference between welders and woodworkers. A workbench for a woodworker is a tool itself...whereas the welding table is more like a wood workers assembly table, except with a steel top. The certiflat is a lot like a wood workers workbench...you can clamp all over the place in 3d. I would highly recommend one over a simple flat steel topped table. Just my $.02
I have both a certiflat and a buildpro with the slots. I like both. I found a good deal on the buildpro, but I wish I had the buildpro MAX table without the slots. The holes are no problem. The slots stuff drops into, but it does have some advantages. When I am using it as a general purpose table I put a couple pieces of MDF on them. Then its like a normal workbench. The reason i use a couple and not one big piece of MDF is that I can slide them around and expose some holes to drop a clamp into.
Sander is lookin good!
StormcrowAz
Phoenix, AZ
Icecactus – I have seen the Certiflat stuff and just looked up the Buildpro. Very nice but I think I’ll probably end up making my own (eventually). Difficult for me to swallow the cost of the pre-made units. I like the multiple MDF idea for topping the table, thanks!
Another busy weekend and was able to get some stuff done in the shop. The belt sander is coming along nicely, started with welding up the table frame. Of course the good looking welds (for me, anyways) are on the bottom, out of sight
20200215_084225
In the tooling section here there is a thread on sanding discs. A bunch of folks recommended the resin fiber discs over the flap discs. Figured I would give it whirl, it was only a few bucks to invest in the backing piece and some sanding discs from Harbor Freight. I realize the HF quality isn’t up to par with the likes of 3M and such, but should get me a good idea on what it’s all about. Started by roughing the welds on the grinder table.
20200215_091226
And then followed through with a final touch-up using the flap disc
20200215_091622
After using it throughout the weekend, my overall impression is that the resin fiber is OK. Probably more impressive with some quality discs. I still think I prefer the flap discs, though. I like that they do both metal removal and give a nice finish without having to swap grinders around.
Anyways, back to the grinder table…having the top just stitch welded on the inside of the frame wasn’t sitting right with me, so figured I’d just throw some evenly-spaced tacks on the outside for good measure. I think I can justify getting more clamps, this is just about all of what I have.
20200215_101801
And of course I couldn’t just leave it be. Figured while I was there might as well just fill in the whole thing.
20200215_114346
Filled in the mistake-holes bolt-holes and re-drilled good ones. This time with acceptable alignment.
Horizontal mode
20200215_134559
Vertical mode
20200215_134631
That done, it’s time to add the casters. Cut out four squares from the notched section of the table top. Welded the corners together to facilitate drilling all the plates at once.
20200215_141047
And finally…the very first real-use of the grinder! Weld removal, squaring up the sides, and corners rounded.
20200215_145137
20200215_145444
Plates welded and casters bolted on. The set-up is now mobile!
20200215_155615
Next up is to make a permanent home for the VFD. Salvaged some more trailer-tongue C-channel, welded a couple studs on the bottom and nuts on the top for mounting. Welded the whole thing to the table top.
20200216_105929
Finally a weld that doesn’t **** too bad that’s in plain sight and doesn’t need to be hand-finished. ;)
20200216_105937
VFD mounted up. Still need to figure out cable management.
20200216_111441
And to wrap things up…a friend stopped by with his new ride. He won this from a local radio station contest. As he said: “Not bad for just sending a text message”. 1979 Z-28 - The radio station installed a nice stereo and gave it a new paint job, otherwise it’s a low-mileage, all-original vehicle.
20200216_170309
20200216_163743
Of course we had to throw it on the lift and poke around a bit.
20200216_160732
That’s all I have for now. Still need to finish a few more items on the grinder table, but it’s getting closer to paint-time and calling it good.
drivesitfar
Storm: great looking table for your cool belt grinder. now you've got it ready for business and I bet your some of your projects will be a lot easier now that you have it.
pretty nice car your friend won.
enjoy your weather.
StormcrowAz
Phoenix, AZ
Dan – Thank you, sir!
Losdudes – Yep, that’s the radio station. (he tossed it there when getting out of the car, it’s not stuck to the seat) And thank you for the compliment!
Drives – Thank you, and yes I am happy to have it functional! Definitely enjoying being outside in the shop the past few weeks. Not entirely sure, but seems like it’s already time to heat things up. Supposed to be in the 80’s this week… Thanks for stopping in and posting!
StormcrowAz
Phoenix, AZ
Knocked a couple more small things off the belt grinder to-do list.
Made a few more adjuster knobs from left-over 3/8” plate. Scribe, drill some holes, slim it down on the porta-band, a little bit of die-grinder work, and finally get to use the new belt sander to smooth it out.
20200222_102303
Welded in some all-thread
20200222_113501
Final grind and installed on the grinder. Still need to paint them but haven’t decided on color yet.
20200222_131516
Did some quick, down-and-dirty, fabrication for belt hangers. Did not even paint them, out of sight and out of mind sort of thing. Plus rust is practically non-existent here.
20200222_154223
Belts hung, close by but yet out of the way. Turned out decent, I think
20200223_093205
20200223_093151
I broke a blade on the porta-band when trimming those adjuster knobs. Replaced it with no problem, but I’m getting a suspicious feeling that this tool isn’t long for this world. I’ve abused it pretty regularly since I got it. Has to be 5+ years now. Considering this is one of the older Harbor Freight units, before they introduced the latest Bauer line, and I think it was around $60, it’s hard to complain. Thinking about investing in a real vertical band saw as a replacement.
20200222_105346
drivesitfar
Storm: your belt grinder is looking even better and looks like it will serve you well.
if you can't find a nice old metal bandsaw or a good wood one that you can put a DC motor (treadmill motors work great) with a switch you might look for or buy a new Milwaukee *********** bandsaw to replace your cheap HF one. i've had mine for years and it's cut some heavy old steel and I haven't had to change the blade yet.
another new product I found that works a lot better than some is the diablo sawsall blades work WAAAAAY better than the milwaukee, dewalt or other brands that wear out on one cut.
take care and even though it's getting dryer up here I still need some of your heat.
cheers
StormcrowAz
Phoenix, AZ
Drives – I was thinking of a new Milwuakee, they seem to be the good one to get. But that’s $300 and then another $150 for the nice Swag table. Was thinking it would be nice to get something a little bigger. I bid on an old 14” (I think) Walker-Turner a week or two ago but someone else had deeper pockets than me. I really don’t like the auction/bidding thing. Anways…this kind of leads me into:
I couldn’t help myself. Way more than I need, but just plain wanted it.
20200228_165248
Rockwell Model 20 Vertical Band Saw. It needs some TLC and a couple parts (upper blade guide bearings and some stuff to do with the variable speed system) to get running again, so it’s another project. Just what I needed. But…it should be pretty darn nice when cleaned up and functional. I hope.
The guy I bought it from (Craigslist) forked it into my truck, and the digital readout on the forklift said 1140 lbs. Probably right around 1k minus the pallet and box of parts there. Getting it home was no problem, plenty of heavy duty straps kept it solidly in place. Getting it out of the truck was another matter entirely. Called a friend and with some very much non-OSHA approved methods, managed to get it to the floor using the Mohawk. Made a quick rolling platform from some plywood and Harbor Freight moving dollies.
20200228_212240
Nifty little material chart with suggestions on blades and speeds and such.
20200228_213418
12 and a half foot blade!
20200301_150312
Rockwell 2hp, 3 phase motor. I’m thinking about trying a digital phase converter for this one. Unlike the VFD for the belt grinder, I don’t need to control the speeds on this beast. It has a high/low gearbox plus a foot-operated speed control for each gear. Just need something to convert from single to triple phase.
20200224_153755
Still not sure what to think about this (other than I might be in a bit over my head, at the very least outside of my comfort zone of knowledge), hopefully my Google and You Tube skills are on par.
20200228_213817
20200228_213844
Large table, nifty old lamp (missing the socket/wiring) and chip blower. Also note the missing blade guide/bearings.
20200301_150255
Inside the lower cabinet. Looks like the foot pedal moves a cam which may spread plates that the belt rides in between, changing RPM? I’ve got a box of parts with what appears to be the plates and a cast part of some sort
20200301_150245
20200301_150556
The chip blower/pump thing looks pretty neat, would be cool if it works.
20200301_150230
I suppose the first thing I need to do is hunt down a manual for this thing. A quick search shows some similar models available on Ebay, haven’t had much time to delve into it yet.
20200301_120624
drivesitfar
STORM: OMG you blew that old HARBOR FREIGHT saw you had out of the water bringing home that BEAST. I hope your back and the saw are ok since that must have been interesting to say the least getting it out of your truck's bed without a fork lift. WOW!!
I hope you get the wiring and the repairs fixed cause i'd like to hear how that BEAST runs and cuts your metal. and maybe it will cut wood too?
I found a couple Milwaukee *********** bandsaws up here on Craig's for $100-150 but if I had the space and the power i'd love a huge bandsaw like the one you found and brought home.
pretty soon you'll be a full on fab shop.
nice find.
StormcrowAz
Phoenix, AZ
Dan – Thanks! I have a feeling this saw is going to be a relatively long-term project. Working on it here and there as time/motivation allows.
Drives – Yes, it’s a beast indeed. It has a two-speed gearbox and an adjustable belt system for a wide range of speeds. I’ll need to source some of those pre-made blades for metal and wood.
Icecactus – Thanks! By the way…really dig that pallet stacker you picked up. I’ve almost got myself convinced I need a small forklift…
TomcoPDR – Thanks for stopping by and checking out my stuff. Good to know others are enjoying it!
Well…it’s been almost a month since my last posting. Wish I could say I’ve made leaps and bounds on project progress, but unfortunately that’s not the case. Not sure how the days/weeks moves by so quickly sometimes. It’s certainly an even crazier world out there than usual.
Before all the TP started disappearing I took a 4-day Tactical Shotgun course. It was not only fun, but educational, too.
20200307_154207
The nearest hotel accommodations are a half hour away, so I opted to camp outside the front gates (they leveled out a section of desert for those wishing to do so). This cargo trailer is another project I’d really like to spend some more time/money on to make it nicer. Insulation, wiring, indoor shower, etc. It’s still on the list…
20200307_190621
The A/C unit for the basement has been out for several months now, maybe longer. Haven’t used it since last summer. HVAC buddy of mine came over and did some diagnostics and advised it’s probably the blower motor. So I pulled it out and ordered a replacement motor and a new capacitor as well. Just got both replacement parts and hope to get it up and running tonight. Don’t want to wait until it’s 110 out.
20200316_155557
20200316_155902
Did manage to make some more progress on my friends Scout.
Got the motor in
20200315_160044 by TODD W, on Flickr
Finished the seat base and drawer. I was originally going to bend up a drawer but decided to try something different by making an exoskeleton and just tack in panels instead. The desire for a decent fixture table is really growing on me.
20200321_141659
Seat base installed. Left it primed so he can color match to whatever interior scheme he decides to go with.
20200323_150917
20200323_150933
20200323_150954
It’s not aesthetically perfect, but it’s structurally sound and super-stout. Won’t really see much of it anyways with the seat on there. I did add a locking tab for the drawer, so if he decides to take the top off and go to the lake or where-ever, he can lock up valuables in the drawer and be confident it won’t get stolen.
There’s only one or two minor fabrication odds and ends left to do on his Scout. He plans on towing it back to his garage this weekend where he can finish putting it together and get it running. Looking forward to getting the space back and also doing a deep-clean of the shop.
StormcrowAz
Phoenix, AZ
Well my friends Scout has left the shop, so I’ve got some space back and “extra” time to work on projects. Seems like I’ve been all over the map working on little things here and there, getting distracted easily I guess. I should probably actually finish a project before starting another one…
So I’ve been using an old Coleman six-pack cooler as my quench bucket for the grinder and thought it would be nice to have a more permanent (metal) solution not easily susceptible to melting. Also thought it would be neat to put it on a swing arm attached to the table underneath the belt sander.
Made the swing arms out of the same 1 ½” square tubing as the table. Wanted the hinge side that attaches to the table tapered slightly to give it a bit more range of motion. Sounds good in theory, at least.
20200407_171125
20200408_163518
20200408_164033
I bought a piece UHMW rod to act as pivoting spacer so there wouldn’t be metal-to-metal friction going on. Never used the stuff before but had read something about it at some point, can’t rightly recall now. Cut up a couple slivers and drilled a hole throught the middle. 20200407_170552
Seems to work ok so far. Still need to figure out the tank mounting plate and then bend up/weld a small tank.
20200408_174741
Another friend of mine picked this fire extinguisher cabinet up from where he works. Someone ran into it with a cart or forklift or something so they were going to toss it out. Not in bad shape at all. Of course by the time I was done with the last screw I realized it was crooked. I think it will be a nice addition as soon as I straighten it out. :mad:
20200408_173925
StormcrowAz
Phoenix, AZ
Visited the mother-in-law up north. She had her well pump and all the pipes replaced and asked if I wanted any of it. Free metal? Sure! 420 feet of pipe that’s still in good shape, for the most part. I’m sure I’ll need it for something in the near future.
20200411_103856
Ran into some crazy weather on the way home. Everything was hunky-dory on the way up, but it must have stared snowing/raining just before leaving the cabin as it quickly turned into some slushy ice and snow. Saw this similar/same situation played out three separate times in the space of a mile or so.
20200411_133213
As soon as it started looking a little ugly I slowed down a bit to put some space between me and the guy ahead, but I guess the guy in the car behind me didn’t think it was a good idea because he rear-ended us. Following too close or not paying attention, I don’t know. Fortunately his car was low enough, and my truck big enough, that he missed the tailgate and bed full of pipes and kissed the trailer hitch. Put a nice square-ish hole in his bumper and left a flake or two of his paint on my hitch. Hard to see the hole in his bumper in this picture, but that’s the guy behind me. Not sure what was going on with those other two trucks…why one is facing the other way and making an attempt to be towed? As we crawled by it looked like the guy was trying to figure out how tie a knot in the strap wrapped around the receiver…
20200411_133623
Fortunately I had four wheel drive, decent tires, and I’m sure several hundred pounds of steel in the bed helped with traction, so we made it home without additional incident. We went from a snow flurry to sunny and mid-70’s within a brief span of time and distance. Kinda nutty.
Got back to the shop and side-tracked once again on another quick project. The bathroom sink had been draining pretty slowly, and after tearing apart the plumbing it looks like the Go-Jo was gunking up in the p-trap. So I switched to regular dish soap and had been keeping it on the tank lid which was getting pretty gross.
20200412_151909
Grabbed a piece of aluminum and put a couple bends in it with the press. Clamped it to a section of pipe to heat and bend it to shape.
20200412_151843
So now I have an easy to clean, rust-free, soap holder and shouldn’t be dripping grease and grime onto the toilet.
20200412_152256
Of course the wife comes out, sees it, and says: “Oh, that’s funny. They sell those on the internet for like $10”. Huh…go figure…
losdudes
Colorado
20200411_103856
20200411_133213
20200411_133623
20200412_151909
20200412_151843
20200412_152256
That snow and ice looks just like our weather in Colorado, 70's on Saturday, yesterday in the teens, gotta love spring.
drivesitfar
STORM: I thought you'd be in about 100 degree heat by now and you are posting pictures and stories about driving in the snow. :headscrat
glad the accident was only and issue for the guy that thinks brakes or 4 wheel drives can STOP AS GOOD IN SNOW.
even though your bride could find a soap holder for $10 I doubt it would be stainless and i'm sure you will smile more than a little every time you grab that bottle of soap.
so the other soap clogged up the P TRAP?
i'm happy to hear your friend's jeep is gone from your garage/shop cause i'm sure liking watching stuff you build and create out there and now you've got some space to build something big.
pipe maybe build some scaffolding in case you need to do any work on yours or your relative's homes?
carry on and i'm sure you won't be driving in snow again for a while.
StormcrowAz
Phoenix, AZ
Madone si – Thanks for the visit and comments, much appreciated!
Losdudes - Yeah, we don’t spend a whole lot of time up north when the weather is unpleasant. Typically we’re driving around on flat, dry ground. Evidently those people were used to the same thing but didn’t think to slow down. Thanks for stopping by!
Drives – Well not quite 100° yet…but it’s supposed to be in the low 90’s this week. And yes, it’s only a couple/few hours drive to go from the desert to mountain pines. Crazy, right? I love Arizona.
And yes - the GoJo citrus hand cleaner works great, but I did read somewhere else (probably in another thread here on GJ) that another person experienced some clogging issues using that product. When I replaced the supply valves a while back I took the p-trap apart and noticed that a lot of the hand cleaner goo had indeed settled in there. After cleaning it out I noticed my sink slow-drain problems went away. I switched to regular dish soap (Dawn) as that seemed to be a fairly common solution without the associated clogging issues. So far so good, time will tell…
Scaffolding is a good idea, as I don’t have any. I’ll have to research and mock up some 3D models to see what it would require. Thanks for the great idea! And speaking of extra space and building big stuff…
So this has been in the works for a while now. Our front door has this square-column entry-way thing that had a pergola-type set-up made out of 2x4’s. It provided some degree of shade to the front door.
20191019_121544
I never really thought too much about it until I walked out front to find one of the 2x4’s laying on the ground.
20191019_120754
Turns out that whoever constructed this thing did so directly underneath one of the gutter downspouts.
20191019_120745
So even though it only rains a few times a year, all that water dumped directly on the wood took it’s toll.
20191019_120710
At least they didn’t build this side directly beneath the downspout. Still…
20191019_120701
And I guess I’m an equal part ***** for not bothering to notice what was happening to my own home. Out of sight, out of mind I suppose. But now that I know, gotta do something about it. Can’t have 2x4’s falling on the delivery guys head as he’s dropping of those Amazon boxes at the front door.
So I tore it all out and my first thought was replacing everything as it was, but instead using aluminum 2x4 tubing as the pergola slats and making some sort of aluminum frame-work. That way nothing ever rusts. Then started thinking of why to even stick with the slat concept? Might as well go for 100% shade/rain coverage with some sheet metal roofing. So that’s what I did.
Started out with a large frame made from 1.5” square tube.
20200412_095227
Cut some angle iron up into 1” sections, and drilled holes into one side, and welded them on two sides of the frame. Added some cross-supports for the roofing and a little brace in the far corner.
20200412_151833
With the help of the Mrs., lugged it up on top of the columns. Broke out the hammer drill and installed sleeve anchors to the two sides that had brick to attach it to.
20200415_174657
That left the other two sides against the roof itself unsupported and hanging free.
20200415_174700
20200415_174711
StormcrowAz
Phoenix, AZ
This is where the little brace in the far corner comes into play
20200415_174627
Cut some small pieces of 3/16” plate, drilled holes, and welded those to another section of 1.5” square tube. Mounted that to the existing wood header boards (or whatever those things are) beneath the gutters.
20200418_084716
Cut up some 1” square tubes and connected the frame corner braces together. I love the portability of this dolly welding set-up, not to mention the ability to use either 110 or 220.
20200418_090753
Adding primer/paint always makes things look nicer
20200418_181731
I was going to add more supports to the middle of the frame sections that face the house, but this seems pretty stout and I don’t think any of the winds we face out here will dislodge it.
Adding the roofing sheet panels was easier than expected. Overlapped three panel sections accordingly. Pre-drilled a pilot hole and followed up by self-tapping roofing screws with the little rubber washer on it.
20200419_111418
Snapped a couple lines to make sure I actually drilled into the frame.
20200419_113435
Ran a hose up there to test it out and seems to drain nicely. Whoever put those brick columns up must have thought about this as there was already a pitch of about 2 inches spanning the 8 feet from the columns to the roof.
20200419_113338
20200419_113328
That's it for now. Functionally completed but still have some decorative plans in mind...
drivesitfar
STORM: I bet that idea you just made to shade your front door will be copied by many or maybe you'll have several requests to build that for others. WELL DONE!
just curious are you doing all that steel work outside in the morning cause i bet at 90 degrees that stuff gets mighty hot and could melt your pants and skin right off?
now that you have your garage back I can see many many more projects like this happening cause you have space and your tools you are acquiring are taking your skills to the next level.
I guess if you want to cool off when it's 100+ degrees you just need to head to the mountains to see mom (or mom in law).
cheers
