Above 1200 Sq/FT Ernie's Place
drivesitfar
Storm: thanks for the good words about me and my daughter's wedding chair that was a fun little project that worked out ok. a couple pics to remember if it's ok to post them or just ask and i'll delete them from your garage thread.
until you figure out where and what you want to put in all your cool little organizers maybe buying a couple rolls of green or blue painter's tape and a sharpie will help for temporary. with all of those organizers i bet you'll have a few dry runs at getting stuff in them before you decide on a permanent solution.
great looking unit that is for certain!!!
StormcrowAz
Phoenix, AZ
drives – no worries on posting pics, happy for it to be part of this thread!
Regarding the painters tape…that’s a pretty good idea. I was going to use those little post-it notes in the back of each bin, but the tape sounds like it will be a better temporary solution. I’m stopping by Tractor Supply today after work to pick up my first batch of by-the-pound fasteners. I took one size of each of the plastic bins with me to scoop out the right amounts. Just need to figure out how crazy I want to get with sizes and such. I’m guessing it will be some time before the dust settles and to a working configuration I’ll be happy with. I’m already concerned that I won’t have enough room. If the shop is any indication of how things go…one tends to fill up the space if it’s available!
Had a few good quality hours of working on the gate. Started by dragging out the welder, generator, and cart-load of tools. Funny looking at the cart now, it almost looks empty. Even after spending some time trying to anticipate everything I’d need…still ended up making multiple trips back-and-forth to the shop for more stuff. That cart was packed full for the return trip at the end of the day.
20190210_093825
Welded on the bracket extensions.
20190210_093841
Bolted the bracket to the post side and was able to use the existing slat bolt hole for half of the gate-side bracket. Drilled out another hole and bolted that bracket in place.
20190210_121639
Temporarily wired the arms and solar panel for a test run. Success!
20190210_121748
Oh, the solar panel kit came with a fairly small mounting arm and I wanted it a bit more up and out of the way. I cut a section of 3/16” angle iron, drilled some holes, welded some tabs, and anchored it to the post. Also threw some pigeon spikes up there for good measure.
20190210_130404
Still need to mount the gate locking mechanism, dig trenches for the opposite-side power line and underground sensor, find some decent wire loom to protect what will still be exposed, and figure out how to mount the 10-key pad outside of the gate.
drivesitfar
Storm: great job on the gate. not sure if you have time or how many estate or garage sales there on in your area, but for $50-$100 i can usually fill up a good part of my Honda with nuts and bolts from those sales cause they usually get scrapped. keep your eyes out for new old stock so to speak cause it might cost you an arm and a leg to fill up all those bins with new stuff.
I just realized my daughter's anniversary is next Saturday and it's been 2 years since that wedding.
take care
StormcrowAz
Phoenix, AZ
take care
drives – Phoenix is a big city and there’s always some such activities going on. It’s not something I usually go out and do, but it is a good idea and might be fun for the Mrs. and I to spend some time doing.
In the mean-time, I have spent some time (and money) organizing the bins. First pulled out some of the random hardware, such as these Tapcons, out of the original containers and filed them away
20190212_170831
After one trip to Tractor Supply and getting a small quantity of nuts/bolts, I realized just how many of those trips I’d have to make and gave into the immediate-gratification urge. Bought an assortment package off Ebay of grade 5 SAE hardware. Think in a couple weeks I’ll do the same for a metric assortment.
20190220_134826
It was also time for the 5k oil/filter change and tire rotation
20190218_155423
Made some good progress on the gate opener system. Broke down and spent money on a trencher, and really glad I did, versus pick-axe and shovel.
Got to use the gantry crane for loading and unloading
20190215_165845
Working on the trench for running power to the secondary opener
20190215_174755
Long trench running up the length of the driveway for the buried exit sensor
20190215_180824
Glued all the conduit together and pulled the wiring through. Of course the secondary arm wire length was too short by about 5 feet. Had to pull it back out and soldered in an extension on with some heavier gage speaker wire I had. Not sure why but it didn’t work. It was towards the end of the day and I was wiped out tired and could have made a bad joint. Probably didn’t help that I ran three extension cords out there and did it kneeling in the dirt. So I left it be for the time being and went out and got some appropriate sized wiring (in matching colors) and pulled the whole arm off and drug it back to the shop, cut off the hack-job, and did a proper job of adding the extension on there. Feeling better about that I brought it back to the gate and hooked it up and it still didn’t work. Took a few deep and calming breaths, started looking at the board trying to think of what else might be the problem. Noticed there was a fuse for each of the arms and sure enough, the secondary arm fuse was blown. They were nice enough to include a spare and after replacement everything worked fine. Not sure what blew the fuse and even if I needed to pull the original splice out and re-do it…but I feel much better about the state it’s in now. Just need to install the electric lock, clean up the wiring, and fab up something for the wireless keypad.
Also, don’t remember if I mentioned it, but during the last monsoon storms a bunch of shingles let loose from the roof and I’ve been dealing with insurance and trying to find an affordable roofer to replace the whole thing. It looks like it was the original roof from 1990. I was pretty close to just doing it myself but fortunately got a recommendation from a friend that worked out.
Glad it did, I wasn’t looking forward to hauling all that material up there. Right tools for the job and all:
20190220_120423
It took a six man crew all day Saturday to do the tear-off and install. I can’t imagine how long it would have taken me to get it done. But now it is and happy to have it (hopefully) leak-free.
20190223_121604
StormcrowAz
Phoenix, AZ
Ok, so the gate opener has been functional for a solid week now and have not experienced any issues. Next up is to install the wireless keypad for friends and such on the outside of the gates. Originally I had thought to make a post of sorts for drive-up and enter your code type of thing, but the optimal location for that didn’t really pan out, so figured I’d just attach it to the gate column and everyone else will just have to suffer and step out of their vehicle to put in their code. I know, I'm a horrible friend for inconveniencing everyone so. Anyways...since the keypad housing is plastic and the buttons some sort of rubber, I was concerned with the Arizona sun taking a toll on it in short order. To prolong the keypad life a bit I cut a piece of aluminum and riveted it to the box as a lid of sorts.
20190302_154154
20190302_154203
Here it is mounted to the post
20190305_155240
20190305_155249
Not sure how I get side-tracked so easily with other projects, but it happens. In this case I started working on a long-awaited water tank for my CPAP. Kind of a silly thing, but the machine humidifier thing only holds a few ounces at a time and inevitably I forget to fill it up and have to get out of bed right before falling asleep. Horrible problems we face, right? Anywho…thought it would be neat to have a larger tank reservoir hooked up to it so I can just open a valve and fill it without getting up. Lazy, yes I know… So picked up an RV 5 gallon fresh water tank and started fabbing up a holder for it.
20190303_135149
20190303_135235
That’s as far as I’ve gotten with that and still need to do some finishing touches to the gate install, clean up the wiring, touch-up paint, and such.
Bob Heine
Boca Raton, Florida
20190303_135149
20190303_135235
Todd, I blame the CPAP (Continuous Positive Airway Pressure) for my AADD (Adult Attention Deficit Disorder). I'm grateful for the machine keeping me alive and giving me a good night's sleep but that makes me more rested and easily distracted. My NAILS came....
The other fix for the humidifier is to move to a humid place like Florida where there is five gallons of water in the air at all times. I have to go, the carbide tooth reciprocating saw pruning blade arrived with the nails so I have to find some branches to trim. Oh wait, the new step drills came as well. What to do, what to do?
drivesitfar
STORM: my bride and I usually take one day a week or in the winter maybe every other week to do a little PICKING at the local sales or shows around our area. sometimes she get's a little (or a lot) bored when i'm stopping to pick up an old vise or tool and i'm chatting with the old (or young) guy or gal there for too long, but we usually end up having a good day and also finding some fun and maybe healthy (or not so) places to grab a bite or dessert.
have fun filling up that cool ORGANIZER and i bet when you do fill it up you'll be able to find something when you need it.
just curious cause I need to make a few patches on my cement style block chimney that looks a bit like the tear out or broken chunk off your gate's support. do you have a good fix in mind or are you waiting like me to see if there is a better fix than just trying to fill it with mortar or cement?
I met a guy yesterday that has a stockpile of EPOXY commercial grade that might do the job so maybe i'll ask him if it might work well as part of the mix in with the matching mortar or cement.
keep up the great work and half the fun in life is doing things you want to do instead of what you have to do so keep the distractions coming and finish stuff as you can or want to.
cheers
StormcrowAz
Phoenix, AZ
Hello Bob – glad to know I’m not the only one easily distracted! :) And technically I’ve got an APAP (Automatic Positive Airway Pressure) machine. A built-in sensor automatically adjusts the level of flow to the mask depending on your state of breathing at any given moment. I like that it starts off at a real low pressure when you first put it on, lets you fall asleep without a lot of pressure right away. Oh, and being a native here to the desert I’m pretty much acclimated to the lack of humidity and happy here. Not sure how folks comfortably live with buckets of water in the air all the time? :) Thanks for stopping by!
cheers
Drives – The fastener project is going to be an on-going thing for a while, I think. Putting the new bulk stuff away is pretty straight-forward 20190309_095342
Determining what I want to do with the onesy-twosy left-over stuff and random fastener odds and ends is another thing I haven’t fully figured out yet. For example I don’t think I want to remove any of those yellow bins to make room for half a dozen staplers, so those might get relocated elsewhere, even though I put them in the “fastener” category that should go with the rest of this stuff.
20190309_095300
Those assortment bins of stuff from Harbor Freight come in handy and are already organized. What to do with those? Still whittling away at the plastic jars full of random junk…
20190309_153956
Regarding the chunks of missing material in the block columns – that was from the previous owner literally tearing out the gates to sell them before they left (grrr…). I don’t really have an answer to the best fix, I had thought about filling in with mortar of some sort but never got that far. I really should have done it before we had the house and these walls painted, but it wasn’t on the priority list at the time. It is an eye-sore and really should be filled in and re-painted. Add it to the list…
I hear ya on the CPAP, have had one for 17 years, can't sleep without it...
Jarhead - I’ve known I had sleep apnea for my entire adult life, but fought doing something about it because of the idea of wearing a mask while sleeping and then becoming dependent upon it. In my younger years it didn’t noticeably bother me, probably due to youthful energy compensating…but now as I’m getting older that’s not the case so much. After routinely falling asleep on the way home from work (while driving) I finally broke down and took care of it. It was a life-changing experience, restored energy levels and alertness that had slowly declined over time. It still ***** being tethered to a machine to sleep, but the pay-off is well worth it. Thanks for stopping by!
Fairly productive weekend – finally finished the automatic gate openers. Cleaned up the wiring and did some touch-up paint work.
Before
20190309_112658
After
20190309_130657
Worked on the CPAP humidifier tank project. Cut a hole in the top of the reservoir for filling and cleaning access. Also made a hinged lid out of aluminum (no rust) and riveted it in place.
20190309_153119
20190309_153757
Also put a little bend at the end to help raise the lid
20190309_153805
Drilled a small hole in the humidifier tank, installed a grommet and the supply tube.
20190310_160206
Installed the assembly next to the bed, you can see the CPAP machine on the window-sill there. The whole thing will be mostly covered up by the curtains, so has a moderate WAF (Wife-Acceptance-Factor). I had to weld an extension arm out to tie into another stud, as the assembly is only wide enough to anchor to the stud next to the window. Didn’t think I’d want all that weight hanging on by one side into studs and the other by only drywall. It was at this point that I realized I didn’t have the right size water supply tubing. The stuff I had is too small for the nozzle at the end of the valve. Another trip to the hardware store… In the mean-time, I put a gallon of water in it to test for leaks and all looked good the following morning.
20190310_162039
drivesitfar
Storm: just an FYI and you can do this or not. I like you have several of the same tool like say for instance in your case the staplers. how many are duplicates and do we really need to keep a spare cause I can't remember the last time I broke a stapler. lost one yes so that might be a reason to keep an extra, but in some cases I have 2 or 3 or 100 extras of some things.
i've got a few bigger chunks missing on some cement blocks on top of my chimney and I'm thinking of repairing and maybe using some epoxy in the mortar or cement mix, but another tip i've learned is to drill in a few screws into the good mortar that will give the new smaller piece something to hold on to that I'm considering doing.
keep up the great work and hope you are enjoying your weather while some of us up here in the PNW are just maybe done shoveling snow for a while.
it was snowing friday, but today looks pretty decent
cheers
StormcrowAz
Phoenix, AZ
cheers
Drives – Good point on the redundancy of tools. I’m a big fan of “two is one and one is none” and being prepared, but I suppose you gotta draw the line at some point unless you want to end up on one of those shows about hoarders. Good tip on the patch anchoring, thank you. I’ll definitely keep that in mind. I’ve heard about that snow stuff…haven’t seen any around these parts, though. ;) Weather here has been fantastic lately, especially for working in/around the shop. Pretty soon though…the 100° plus temps will make it not so pleasant.
Finished up the CPAP water tank project. Nice to finally check that off the list. The wife thinks it’s pretty funny and ironic how much effort I’ve put into basically being lazy. “It’s only 10 steps to fill up the little tank!”. But I’m happy to have it!
20190312_190150
20190312_190209
StormcrowAz
Phoenix, AZ
Great thread
Thanks and thank you for stopping by!
Been pretty busy and time seems to fly by at an ever-increasing pace. Another benefit/curse of getting older, it seems. No major projects to speak of but a lot of little things popping up.
The roofing contractor rolled his trailer over my sprinkler manifold box and broke the fittings inside. He was apologetic (I warned him in advance of the box location but evidently he didn’t pass it along to his helpers, who were the ones that actually ran it over), straightened out the diamond plate cover, and offered to fix the plumbing, but I declined preferring to take care of it myself. I put this together myself a few years ago and am glad I put the threaded union couplers in place, which helped the repairs go fairly quick.
20190406_092604
20190406_092634
I also had to debug the gate opener set-up some more. The motors in the swing arms aren’t strong enough (this brand, at least) to cope with a stiff breeze as the gates act like big sails. Too much wind resistance. I removed the slats and seems to be all good now. Kind of a bummer as I liked the look of the slats, but I like functionality better.
20190330_132945
Took a four-day Practical Rifle course - learned a lot and had a good time.
20190323_164018
Which also inspired me to make some modifications/upgrades to my AR. It correspondingly lightened my wallet a bit, too. Too many hobbies, not enough cash to support them all!
Here’s the Before shot. Colt 6720, bone stock with the exception of an Aimpoint Pro and Pachmayr pistol grip.
20190406_092437
Almost looks like a Magpul commercial
20190406_115435
The After look:
20190406_134723
Added a light, too
20190407_074602
Went a little crazy and ordered an ACOG for it as well. Should be here in a couple of days. Looking forward to zeroing that in and giving it a go.
StormcrowAz
Phoenix, AZ
Went outside the other day to see this. Ventured into the shop but alas…no pot of gold to be found. Not even a bowl of Lucky Charms…
20190416_184933
My buddy with the ’67 Scout is ready to put some time/money into it and asked if we could work on it at my place. The lift makes things so much easier. First he dropped off a new-to-him 304 to replace the tired 4 cylinder. He’s going to take all the accessory stuff off and send the block in for a rebuild
20190409_190740
He also got a new lift kit (springs, shocks, shackles, etc) which include a reverse-shackle kit for the front leafs. Threw it on the lift and started tearing into it.
20190421_173611
Cut the spring hangers off the frame and tacked the new fangs on. Also, those were the hangers I had previously re-located for the axle upgrade and I am happy with the amount of (significant) effort it took to remove them. I’m always self-conscious about how good my welding is, especially when it comes to safety related items.
20190429_162735
Also cut holes in the frame and welded the sleeves in for the reverse shackle.
20190428_170752
That’s all we had time for this past weekend. Been spending a bit of time up north (Happy Jack) at the in-laws place as my wife’s father passed away last month and we have been helping her mom with taking care of a few things. She has a nice garden area and the deer have been taking advantage of the free snacks, so she asked if I could put up something to keep them out. Put in a few fence posts and now need to get some tubing for new fence panels and a gate. Have some ideas for adding a little personalization to it and that’s next on the project list.
StormcrowAz
Phoenix, AZ
Another busy weekend. The parents pulled their Airstream up to our place for a little project.
20190504_071533
The front skylight cover was starting to disintegrate, the Arizona sun can be brutal. They wanted a more permanent solution and decided to go with an aluminum lid. Removal of the old plastic one was easy, it crumbled and fell apart.
20190504_071549
The openers that raise and lower the lid were a challenge all-around. On one of them the hinge part was rusted at the pivot, froze solid, and broke off when attempted to loosen it up. I had some left-over piano hinge which was cut to size and tack welded to this as a replacement, forgot to take pictures of it. Cleaned and lubed them up and they seem to be working fairly well.
20190504_084240
Cut up some old manila folders for a test-fit template before cutting and bending the aluminum sheet.
20190504_104908
Did a test-bend on a left-over piece of the aluminum sheet and glad I did as it snapped clean when it hit the 90° point. I got the aluminum at the metal yard I usually go to and pulled it out of the drop pile. Should have paid a little closer attention to the markings as it was stamped with T6. So thinking it was heat treated accordingly and hardened. Took a torch to the bend areas and while it did cause a little warping it did allow for it to bend without breaking. Riveted it together along with the hand-cranks and re-attached it to the trailer. Not the cleanest sheet metal work out there, but it’s solid, functional, and fortunately not too many people see the top of the trailer. Most importantly my folks seem real happy with it and shouldn’t ever have to worry about it falling apart. They said they paid somewhere in the neighborhood of $140 for that plastic cover which only lasted a couple of years. I spent less than $9 on the aluminum.
20190504_153435
20190504_153511
After that my buddy came over and worked on his Scout some more. Managed to get the rest of the lift-kit installed. Had to cut off and re-position a spring perch on the front axle. Removal and installation of the rear springs/shackles was quick and easy.
20190505_152415
When we finally put in on the ground and let the suspension settle, it became painfully clear that the front end is too far forward unless he is to do some serious fender-chopping. Which he does not want to do.
20190505_152440
The Scout-specific reverse shackle instructions say to mount the front fangs plumb with the front of the frame but that appears to not be case for this application. We came to the conclusion we’ll have to cut off the front hangers, (fortunately they are still only tacked on there, I didn’t burn them in all the way. Just in case!) push them back a couple inches, and re-locate the rear sleeves in the frame accordingly. Kind of a bummer, but at least it’s nothing some time, effort, and a couple new sleeves won’t fix.
StormcrowAz
Phoenix, AZ
A week or so ago it got a little warm in the shop so thought I’d crank up the swamp cooler and it blew a fuse on the digital controller. After trouble-shooting figured out it was the water pump. While poking around I went to adjust the water level in the pan and the float came free.
20190511_133116
Not sure how it rusted through right there. Guessing the plastic float valve attached to the cooler housing leaked and over time rusted through the surrounding metal. Cleaned it up a bit, got the new water pump and a can of evaporative cooler coating. Stuff smells like tar in a can. Anyways, made a quick little bracket to support the new (brass) float valve.
20190511_133038
Bolted it to the cooler, silicone around the edges to keep rain water from collected in between and rusting further, and then gave the inside and outside another coat of the tar-in-a-can.
20190512_080041
Thought I’d put a little piece of tubing to direct water to the bottom of the pan, maybe help avoid splashing and rusting further up, but that didn’t really work so well. The water doesn’t really only come out that downspout but from around the lever mechanism area as well. Oh well.
20190512_080027
Had a buddy come over and added some hardware to his AR15 (sling mount) and fixed his old Crosman BB gun. Tore it completely apart, cleaned, and lubed it. Put it back together (thanks to YouTube) and seems to work OK. Forgot to take pics. My friend with the Scout wasn't able to make it over, so that got pushed out a bit. Another weekend in the books…
rattle_snake
Chandler, AZ
Bummer about the scout axle location. fixable, glad you mocked it up before burning it all in.
More info on the swamp's digital controller. timer/thermostat?
StormcrowAz
Phoenix, AZ
I believe it's a Dial 7624 digital controller. Thermostat, pre-wets the pads, high/low setting, timer. Way more than I need for the shop, but it was on the swamp cooler when we moved into the house and I kept the electronics (just in case) when I scrapped out the old unit.
StormcrowAz
Phoenix, AZ
It’s been a bit since my last update, busy as usual.
The heat is back and while the swamp cooler makes it more tolerable, I’m still jealous of those (*cough*Justin*cough*) with A/C in their garage/shop. Oh, well…I’ll just keep drinkin’ that water.
So I was mowing the lawn and got a little too close to the shops septic clean-out and broke the top of the cap off. Went to replace it and of course it was wedged in there pretty good. Wasn’t able to get enough purchase on it to break the threads free. So I thought I was pretty cleaver by drilling a couple holes in the cap and making a custom spanner to remove it:
20190524_143857
I ended up spinning off the threaded coupler instead. The guy (not me) that originally installed this didn’t bother with glue. Not sure if this is standard practice or not, but I went ahead and replaced it with ABS glue. When mowing I will be more mindful of the deck placement from now on.
20190524_144034
Pulled the engine and transmission out of my buddies Scout. The gantry crane is nice.
20190622_110945
20190622_114622
Worked on the fence panels for the mother-in-law. One long panel section and one gate. Started with the panel. I really dig those Fireball fab block things.
20190526_095109
Went and got a cattle panel from Cal Ranch. $24 for a 16 foot section seemed like a pretty good deal to me and should keep the deer out of her garden. Cut the width to size and fit it inside the panel frame. Also added some half inch square tube triangulation for added strength.
20190701_164134
That being done, I started on the gate. Again, square made easy…
20190624_162739
Rinse and repeat with the cattle fencing. With this gate piece though, I thought to throw in a little art-work as I think she will appreciate it. Decided to go with a tree of sorts (random image stolen from The Google). Chalked the outline of the gate on the ground and then drew said tree. The trunk/branches are 3/8” (I think?) steel rod, bent to shape.
20190629_141214
Cut some leaves out of 26 gage sheet stock I had.
20190629_122211
Ran them across the bench grinder to shape and smooth out rough edges. Also used some of the cattle panel drop pieces for the stems.
20190630_081637
Welded the trunk/branches together, then added the leaves. Once completed welded the assembly to the gate
20190630_122358
The design kind of gets lost in the busy-ness of the gate itself, but plan on painting the trunk/branches white and the leaves bright red, and the gate itself a dark color. Hopefully the light colors of the tree will pop against the darker gate background.
Oh, I also added a latch bar of sorts. I know they sell these pre-made but I was there and figured I’d try my hand at it.
20190701_164053
That’s about it for now, hope to have the fencing project completed this coming weekend.
Bob Heine
Boca Raton, Florida
20190524_143857
Todd, I share your joy working outside in the summer. Air temp in my back yard is only in the low 90s but the ground in the sun is 130. I'm trying to fit a 10-foot umbrella to a hat so the shade follows me around.
If you are anything like me, I rarely learn from my mistakes. You might want to install a flush cleanout plug that doesn't have the big square lug sticking up.
https://www.amazon.com/dp/B00V87BWH4/?tag=atomicindus08-20
Of course you'll need to make or buy a wrench designed for the plug. They sell a cheap plastic one but obviously you can make one from steel.
https://www.amazon.com/dp/B00BDEP9S0/?tag=atomicindus08-20
StormcrowAz
Phoenix, AZ
Bob – Wow, thanks for the heads-up! I will definitely give those a try. Did not even know there was such a thing. I guess I need to get out more!
And yes…summer time…it’s currently 108 as I’m typing this. I’m happy (relatively speaking) if the shop temps stay below 99, with the cooler going. When the monsoons roll in and the cooler efficiency drops it’s plain miserable. Yard work is certainly no fun.
Todd, nice job on the fence and gate for your MIL. :beer:
Dan – Thank you! I am a little nervous on how it’s going to turn out, both paint and installation. Paint will be probably be a week before I can get it finished and it might be a couple weeks before we can head up north to do the install.
rattle_snake
Chandler, AZ
I'll keep my A/C related comments to myself
My septic clean-out wasn't glued either. And had a electrical conduit put in over the top of it.... Then I hit it with the mower.
StormcrowAz
Phoenix, AZ
Justin - I’ve been opening up the shop real early in the morning to ventilate for an hour or two and then starting the cooler. That seems to make things more tolerable. Worked in there the whole weekend and it wasn’t too bad, definitely better than working outside in the sun. Also glad to know I’m not the only one with mower/clean-out issues. I order the flush-mount caps and looking forward to one less thing to worry about.
So the wife was up north visiting her mom this weekend so I had some serious QST and managed to get quite a bit done.
The fender flare on my buddies traveler trailer finally gave up the ghost the last time I borrowed it. It’s attached to the slide-out so there’s wasn’t a solid mounting point to the frame to keep it from flexing in the wind while being towed, so the mounting tab area developed some serious cracking after a couple years of this.
20190706_073824
Here’s where the previous brackets were, to help support the plastic fairing. Not sure if this was my buddy or from the factory, but the aluminum brackets ended up failing, too.
20190706_072420
20190706_072548
So I bought a new fairing piece and had to trim off a piece to fit the slider. Always feels weird to me when you have to hack up a brand new part.
20190706_072304
Removed the old one and installed the new one.
20190706_072329
20190706_102227
Looks real nice, but still leaves that center section between the tires flimsy and susceptible to wind turbulence when cruising down the road. So cobbled this together from some half-inch tubing and angle iron
20190706_093001
Installed accordingly and added some of that 3M double-sided tape between the bracket and fairing. Seems to be pretty solid. Taking the trailer up north today so we’ll see if/how it actually works.
20190706_101749
StormcrowAz
Phoenix, AZ
Another friend of mine had neighbors move out and they left a large pile of trash behind for the bulk pick-up, and he saw this amongst the clutter and saved it for me. Threw a quick mounting bracket together and added it to the shop wall decorations.
20190706_101151
20190706_101453
Finally took care of something that’s been bothering me for a while…when I put up the new garage door opener a while back I installed the safety sensors and one of them is in a pretty heavy traffic area between the garage door and door to the house. It’s prone to getting knocked around by stuff and I’ve already had to adjust it at least once as the flimsy metal bracket gets bent easily.
20190707_115105
After some cardboard mock-ups I went to the scrap pile and pulled out some 1/8” sheet. Time to up-armor the garage door sensor.
20190707_111851
20190707_114741
A coat of Safety Yellow and quick install…it’s a little bit better protected now. Seems kind of silly, but it should do the trick and overkill is underrated. ;)
20190707_194306
Also made some good progress on the gate. A lot of painters tape…taking it off those round bars was no fun.
20190707_193523
Was going to just go brown on the whole back side of the gate, but thought it might be neat to have some more color on the reverse side
20190707_193541
Still need to do some color touch-ups here and there, but overall not too shabby.
bad_idea
Pasquotank, NC
I'm sure your MIL will love the gate. If she is anything like my MIL she will be in church Sunday morning bragging how her NASA scientist SIL made her a fancy gate.
StormcrowAz
Phoenix, AZ
Gate looks real nice!
Just thinking out loud, would aluminum foil work on the bars instead of tape?
Jarhead – hmmm…that would have probably been a lot easier! Not sure how much foil costs, but I know that blue painters tape ain’t cheap. Will definitely file that away for future masking projects, thank you!!
Bad_idea – Hah, maybe so! At the very least I hear she’s planning on some Texas-sized French toast for breakfast and grilling some steaks for dinner! Tentative plan is to head up in a couple weeks for the install. Looking forward to the cooler weather up there on the mountain.
And speaking of gates and fence panels. Finished welding up the flowery touches to the larger panel section. Poor planning and estimation on my part resulted in running out of primer half-way through painting it this weekend. Will pick up some more and finish it up this week hopefully. Monsoons are supposed to be creeping in, so will probably bring the gantry back into the shop in case it rains.
20190727_111113
Small but satisfying victories. Happy to have more lawnmower-friendly clean-out caps installed (thanks Bob!)
20190727_130558
So our neighbor’s fridge went out and last weekend and the Mrs. and I went and picked up a new one for her. Could have just thrown it in the back of the truck, but I do have a cargo trailer and a dolly, which entails a little bit less heavy-lifting (read – I’m lazy) so figured that would be the better way to go. Which it was, until one of unsecured gates caught an errant gust of wind and blew it in between the trailer and truck as I was pulling it back into the yard. My fault for not paying enough attention. Fortunately it did not touch the truck at all, somehow. It did wedge against the trailer and scuffed up the diamond plate on the front, nothing major though. Biggest issue was it crushed the end of the gate. Forgot to take a picture before I started tearing into, but here it is after I cut out the last horizontal bar and removed the wood pieces.
20190727_102429
Of course I didn’t have a replacement piece of 3/4” square tubing in my pile that was long enough, so had to weld a couple pieces together.
20190727_101805
Another occasion where the portable welding set-up and ability to run it off of 110 comes in handy. In retrospect I guess I could have pulled the whole gate off and took it into the shop. Doing this in the shade would have been less of a heat-stroke inducing project. Oh well, I never claimed to be smart and definitely don’t work for NASA. I think I did mention the lazy thing though…
20190727_103913
In the end it doesn’t look too horrible. Not perfect by a long shot, but it keeps the dogs in and the wife happy.
20190727_110900
My buddy has been making good progress on his Scout. Cut out the front frame cross-member and radiator support (moving them forward for the V8 swap), pulled the fuel tanks to clean out and coat them. Currently cutting out the floorboards for replacement, here’s an action shot:
20190727_124606
StormcrowAz
Phoenix, AZ
Despite the oppressive heat I managed to finish up the fence panel.
20190803_183639
20190803_183647
And thus loaded up the cargo trailer with the panel, gate, and everything else I thought I would possibly need and headed up north.
20190809_191529
Here’s the garden area before we started in on it. The fence posts I had come up a month or so ago and cemented in place.
Panel side
20190809_191436
20190809_191442
The gate side
20190809_191512
In-process action shot
20190810_101051
Panel installed
20190810_101531
Gate hung
20190810_101405
Drove in a couple of the heavy-duty T-posts and welded sections of that cattle panel between the archway and fence posts. Primed, painted, and good to go. Should keep those pesky deer from munching on her flowers.
20190810_143810
20190810_143834
20190810_143846
Ah, and this is my solution to the gate latch. 3/16” piece of plate I drilled at home and brought some of that rod with me and made the “loop” after lag-bolting the plate to the shed.
20190810_143911
All in all it took from about 8am to 3pm to finish everything up. Her mom was very happy and said it was way more than she was expecting, so I’m happy with that. The neighbors came over and chatted a bit and said they needed some fencing put in at their place, oh, and some handrails on their porch steps, too. Said he was serious, so I’ll put together some estimates and see what they say.
drivesitfar
Storm: looks like you might be going into the gate biz. nice work on the new gates for your MIL and I'm guessing with that awesome garden (can't believe the deer don't eat that?) she's a pretty decent cook so I bet you were fed well after you arrived and then again after you finished installing the gates.
WELL DONE SIR!!
StormcrowAz
Phoenix, AZ
Dan – As always, thanks for visiting and positive words of encouragement!
Drives – Thank you! And yes..I woudn’t mind the outside-of-work, work and a little bit of extra pocket change. I really do want/need a new air compressor. I think mine is on its last legs. And yes, her mom did manage to adequately replace all those calories burned during the install. Steak for dinner and Texas-sized French toast for breakfast. Yummy!
My trimmer has been having intermittent idling issues and finally just stopped running altogether. It’s about 5 years old with not too many hours on it. Figured it was time to take apart the carb for a good cleaning. Really only needed to take one plastic access panels off, but wanted to see how everything worked, so took it pretty much all apart.
20190803_115113
Tiny little carb! Took it all apart, cleaned it, and put it back together. Wasn’t too dirty and didn’t see anything glaringly wrong with it.
20190803_121223
Put everything back together and fired it up. It runs now, but of course I must have missed something on assembly, as the business end doesn’t rotate any more. Go figure. Time to take it apart again and see what I did wrong.
The Mrs. is going to another craft show, putting up a table and selling her wares. She asked if could make some sort of stand and sent a couple picture examples. It’s this weekend so I threw this together in a hurry. Not really proud of it as it is pretty crude. No time to sand and finish because she’s leaving tonight. Lessons learned, though. I forgot I had a perfectly good router to put those shelf slots in and used the jig-saw instead. It works but not the best fit. The wood is the cheap 5.5” x .75” and is not very consistent. Might spend a bit more and get better material for the next one.
20190826_171154
This picture has a few things going on…We drug her mom’s quad back down to the valley with us to have some new tires put on it. Got those changed out and it’s ready to go back this weekend (while I visit the Mrs. at the craft fair). Maybe I’m just so used to doing metal fabrication that woodwork seems awkward and always messy. I can see why dedicated wood-working folk get some of those sawdust collection systems going. That stuff gets everywhere. I also really should do something with that table saw. It’s an old Craftsman and given to me by a friend. The framework is barely holding on to the cart itself and there’s no belt tensioning left in this set-up. It’s always a low priority on the to-do list, mainly because I hardly do any wood work. It is one of those things that’s hard to replace when needed, and on those few occasions when I do use it…I’d rather not have the thing fall apart while that spinning wheel of death is ramped up to speed.
20190826_171218
StormcrowAz
Phoenix, AZ
Oh, almost forgot...we have a new addition to the family. This is Asher. He's a rescue. Anatolian Shepard mix of some sort. 9 months old. The rescue lady said someone turned him in because they couldn't afford to keep him. :(
Super sweet and loving personality. He's already hung out with me in the shop, even in this heat.
20190817_074030
Finallygotit
Tucson, AZ
20190817_074030
Way to go Todd; a new shop dog! And a good rescue to boot. Looks like he still needs to grow into those feet.
Unfortunately my shop dog does not look long for this world. :(
:beer:
StormcrowAz
Phoenix, AZ
:beer:
Dan – Sorry to hear about your pooch. I can certainly empathize. We’ve lost 3 of our pups within the past 10 months and also have another that is 20+ years old and visibly slowing down. Little bundles of joy and heartache rolled up into one.
I enjoy all the projects!
This was an awesome read. Nice shop, Storm!
sean and Vicinity – Thanks for stopping in and checking out Ernie’s Place! Appreciate the feedback and comments!
Was another hot working weekend. 106° plus and for some reason I thought it would be a good time to do yardwork before working in the shop.
Had to replace the battery in the 2500. Not too bad, other than how much these batteries cost now. I’m convinced the sealed batteries are the way to go, even though they cost more. Tired of cleaning up battery acid and corroded parts.
20190904_180748
Also finally broke down and bought a new set of ratchets. The ones that came in the Craftsman mechanics set I bought in 1998 have seen better days and I’ve just been dealing with the worn-out mechanisms for a while now. Along the way and over the years they seem to have multiplied in the drawer somehow. This is what I pulled out of the big toolbox:
20190907_095206
Shiny new and smooth action. Hopefully they will last a while, too.
20190907_095353
Placed them on the pegboard for my most-used items. I know a lot of folks don’t like the pegboard but it suits my needs just fine. Oh, I also picked up a set of Tekton screwdrivers a while back as well. Similar to the ratchets, the original Craftsman drivers seemed a little tired.
20190907_095931
Helped my buddy out with his Scout a bit. Working on fitting the V8 in there. Had some clearance issues with the exhaust manifolds and the firewall, so had to break out the cutting wheel. Just so happens it’s right where the e-brake cable comes through, so will have to address relocating that as well as patching up the holes.
20190907_121359
20190908_073824
Figure we’ll replace the floor-pans once we’ve got the motor/trans where we want them. It’s been handy to not have them there while working on fitment.
20190908_073810
And last but not least my new buddy keeping me company in the shop!
20190907_134248
drivesitfar
STORM: looks like you are keeping busy. as far as ratchets I haven't used my tools nearly as much as most members especially on my cars, but I really save the wear and tear on my ratchets when I use breaker bars and my Ryobi 18v impact wrench especially on the rusted ones. I rarely if ever spray Kroil or PB blaster on rusted bolts, but it might also be a good idea and let the spray work in a bit before you attempt to use your tools. that said ratchets will wear out and most of the older ones might have a repair kit to install so you can keep your favorite.
I'm guessing as we get back to fall type weather your heat wave might be over for the year and it's probably about room temp in your garage now? or is it still HOT?
cheers and keep up the great work!!
StormcrowAz
Phoenix, AZ
Drives – Busy, yes. Sometimes more so than I’d care to be, but such is life. Regarding the ratchets – I did look into the rebuild kits, but went with the shiny new tools instead. Wanted to try the larger tooth count as it seems like there is a lot of to-do about them. So far they are living up to expectations and I don’t regret the purchase. I tend to stick with what I know and make what I’ve got work, even if it isn’t all that great. Lately I’ve been thinking on this and of why, when there’s newer and better options out there that are relatively affordable. We all pay for our experience in one way or another. Oh, and the PB Blaster is my go-to for nuts/bolts that are even suspect of giving me a hard time. It is of my opinion that most things, and situations, are greatly improved by an appropriate amount of lubrication. ;)
The weather here has finally broke and highs have been in the mid-90’s, which I’m afraid to admit has been really nice. Able to work outside and in the shop without risking a heat stroke. Time to buckle down and get some of those items off the To-Do list, and there’s quite a few…
Thanks for checking in and dropping a line!
Apologies in advance, it’s story time.
So it’s been an interesting couple of weeks. Two weeks ago today, got up early in the A.M., started the shower and heard the toilet “burp” a little. Last time that happened the main line to the septic tank clogged and flooded the laundry room, which is the lowest point in the house. We have a finished basement which is where the main bedroom, two bathrooms, and the laundry room reside. Sure enough, it’s happening again, but this time noticing it right away prevented it from being too much of a mess. Fortunately we have the shop bathroom as a back-up, as it has its own separate system. Last we called a plumber and they ran a snake down the clean-out in the front courtyard and cleared it without a problem. This time it didn’t go so smoothly. Kid showed up right after I got home from work and proceeded to get his line stuck in the pipes. Evidently the line got a kink in it, wedging it in there. He had ran it out all the way, so he wasn’t able to push it in farther to wiggle it around, much less pull it back out. He ended up having to call another truck in to attach another line to the original to push it further in before being able to pull it out. What normally should have been a quick fix ended up taking the entire evening. Because it was such a fiasco they ended up running their camera down there to see what’s going on, only thing they could tell was it looked like maybe there was something going on with the baffle in the tank and the water line was too high. Advised I call the septic folks.
It’s late Friday night, and of course all of the septic companies we were recommended are closed until Monday. So no using any drains in the house until then. Again, very thankful there’s a working bathroom in the shop, even if it’s a slight inconvenience to make the walk out there when needed. I was also glad I added a sink to the bar-b-que island, as that’s where we ended up doing the dishes. That little amount of water just drains into the rocks on the other side of the wall.
Anyways, Monday rolls around and I took the morning off to make sure things go smooth with the septic folks. I should have known better. They get there, have the county plans to the system, and it also turns out these guys serviced the shop septic some years back, before we moved in. All good news to me, seems like a good start. So the fun begins, whereas the previous homeowners put a courtyard over the septic tank. Had to pull up pavers and poke and prod to find the lid. Had some difficulties (this is the theme for the day) finding it, so broke out this sonar gadget to help find it. That’s when they realized it’s a basement house. Oh. Asked if I had a pump in the basement. Nope, sure don’t. Gravity fed, so that means the tank is below the basement level. Which is why their sonar gadget won’t work. So more poking and prodding and the finally found what they thought was the riser lid. I learned a lot of new plumbing (****) terminology that day. They dig down a couple feet and run into a metal lid, maybe three feet in diameter, which was attached to something by four bolts. Of course being buried in the earth for many years the bolts aren’t exactly in the best condition. Out to the shop I go to retrieve sockets, ratchet, and impact. With some persuasion was able to get the bolts out, pull the lid off, and to everyone’s surprise it’s not a riser, but a 10 foot hole in the ground.
20190917_071933
Oh, forgot to mention that the previous owners also put in an irrigation box on the other side of the courtyard and ran the water line right over the top/middle of this lid/opening. Yay.
At this point the guys weren’t sure they should even being going down in this hole to pull the tank lid off. Understandable safety concerns regarding gas build up in the confined space and what-not. They were really nice and decided to give it a go. Back to the shop for ladder retrieval. Guy climbs down there and inspects the tank lid. It’s concrete. It won’t budge. He says these lids are prone to deteriorating on the inside of the tank due to moisture and gases and often seals itself to the tank. They use plastic lids, these days. There’s a solid ring on the lid for lifting, maybe if he had a come-along to pull it up? Back out to the shop (noticing another re-occurring theme?) for come-along and a length of chain. Place a large metal pry bar over the hole and winch on the lid. Doesn’t even budge. Some head-scratching, staring into the hole, and finally one of the guys goes to the truck and grabs a large corded Makita demolition hammer tool with a shovel-type bit. Back in the hole and he goes to town on this lid. Sometime later, and with a whoop of joy he manages to break the lid free. Wraps the chain through the hoop on the lid and climbed back out of the hole. Took the two of them (I might have helped a little) to pull that lid out of the hole. And sure enough – “*******’s full, Clark”. So they confirmed it needs to be pumped. What I didn’t know, and I learned a lot about my septic system this day, was that there’s two lids to these tanks. The other one is a few feet away. In the courtyard. Under pavers. So rinse and repeat with the other side, but at least we know what we’re getting into this time. The bolts to the other metal lid are more stubborn (of course) and had to make another trip to the shop for a hammer and chisel to just break the head off. Another stuck lid, more jack-hammering, and grunting effort to get the lid out of the hole.
20190917_092826
So they proceed to pump out the waste, back-wash, and re-pump out both sides of the tank. While doing so they notice that the baffle going to the leach-pit was loose. Turns out who-ever installed it didn’t bother gluing it in, so they fixed that, too. They also noticed that a root was growing into the tank, between the main drain line and the tank itself, through the seal there. Great. I opted for new plastic lids, not wanting to deal with the concrete lid fiasco again. They advised it was optional, considering the giant metal lid was keeping anything from getting down there to begin with. Makes me feel better having it there, for some reason.
Oh, did I mention the previous owners thought it was a good idea to plant a Palo Verde tree almost directly over the tank? Not only that, but another tree a few feet away on the other side of the courtyard. Smaller roots had grown over each lid under the pavers. Not too difficult to remove now, but still a problem.
20190917_095012
So they thought the trees “might” be ok, considering the depth of the tank. But obviously it’s already causing problems and I’d rather it not cause more. So sooner rather than later I’m going to cut both of those trees down. The Mrs. is really bummed because she really likes the trees and the shade they provide there.
So they pumped the tank, buttoned everything back up (except the pavers, they don’t do that) and supplied me with small packet of free enzyme treatment and a hefty bill for their service. What I thought was going to be a pretty basic tank pumping turned into an all-day ordeal. And now I gotta cut two full-sized trees down and figure out some sort of replacement shade for the courtyard.
In the mean-time, while regularly using the shop bathroom I noticed the toilet was developing a leak from the tank to the bowl. Albeit a small leak, but pretty much running constantly. It still had the old-style big ball float set-up. I got a newer style replacement and while in there noticed the tank gasket was deteriorating upon touch, turning into black clouds of rubber in the tank. Figured I’d replace that seal along with the spud gasket, which was heavily cracked, not sure how it was still sealing anything. The supply valve to the toilet wouldn’t close all the way, no matter how tight I got it…so got some new quarter-turn valves as replacements. While I was at it, I might as well replace the ones to the sink as well, considering those were of the same vintage. Figured it was kind of like freezer plugs on an engine block – if one is leaking odds are the others aren’t too far behind. Also figured it would be easier to replace those valves if I just pulled the sink out, which it was, but because I’m an idiot I broke the drain pipe going into the wall. So now have figure out how to effectively fix that as well.
20191003_165613
Seems like I’ve been dealing with quite a bit of crappy things lately.
On the bright side, make some more progress on my buddy’s Scout. Fabbed up and installed new motor mounts. Original ones were 3/16 bent plate, nothing complicated. Figured we’d do something similar, maybe with some extra gussets and triangulation to compensate for the bigger motor. Sent him on down to the metal yard to pick up some material and he came back with 3/8 plate instead. “Your truck is going to weigh a little bit more now”. Plenty stout and hopefully it holds.
20190921_161449
20190921_161458
I’m all typed out now.
drivesitfar
Storm: yes i bet 90's is a heckuva lot nicer than 110's - 120's so best of luck getting all this work done before next year's heat wave or maybe a flash flood or two this winter.
sorry I don't have time to read all your post now, but i'll read it later. looks like you are busy doing STUFF and good for you for fixing it right.
yep those motor mounts should maybe be stronger than the frame now. nice work!!
