shortykorte
Probably, she’ll be in the cart following the curber……with the whip.Are you going to make that sweet lady do curbing?
Willie, she volunteeredAre you going to make that sweet lady do curbing?
Laura calls it "Supervision"Probably, she’ll be in the cart following the curber……with the whip.![]()
It might take me a few more days to get going on this project as I still need to find a water reducer additive for a price that won't break the bank. I found what I want in Orlando but I need arrange another stop to make it worth the drive to mouse town.I’m looking forward to seeing how this goes. I didn’t know you could get those machines
in a diy version. Good luck with the project.
Jay
Did you find a name anywhere?Before we went on the search for cement yesterday, we started out by going to a yard sale that I had seen advertised on FB for an old coal forge and I wanted it. We got up early and were the first ones to the sale and I bought the forge for $100. We left the sale and stopped at an out of the way cafe for breakfast. Right after we sat down there was a man going from table to table asking people something and everyone was shaking their head no. He got to our table and asked if we owned the white truck in the parking lot with the forge in it. I told him yes and that I had just bought it. He asked me if I wanted t sell it and I told him no. He asked how much I paid for it and I told him, he said I could double my money and he would give me $200 and I declined. After we finished eating he came back and offered me $300 for it and I again declined. We finished our coffee and were leaving and as I walked past his table , he stopped me and offered me $400. I declined again.
When I got home I unloaded my new to me coal forge. I need another project like I need a hole in the head but this was just one thing I always wanted. Someday it will look and operate like new again.
I have some info, I will find it and then send you a pmNo name that I can find. The blower housing castings are 556 and 557 for left and right. Its a pretty small blower operated by a wooden handle attached to a crescent gear by a metal link, driving a flywheel via a one way clutch and a leather belt.
Having never seen a blower drive like this is why I wanted it in the first place.
I have been spraying all of the fasteners and moving parts on the forge with PB Blaster several times per day for the last week. I will continue to spray it for at least another week before I put a wrench to any fastener to try and take it apart. So much for the forge project.
It looks like to me there is a missing bolt, just to the right of the circle there is a place for another bolt. The one missing is the main load bearing (tension) bolt when the hitch is loaded, the failure point is in line with what I would expect if the other bolt were missing.What's up with that hitch? I remember you had a previous issue,but don't remember the details. Seems like an odd thing to break...wonder if you got one made of junk steel?
JB
Definitely a missing bolt. There isn't even a witness mark where a bolt had been.
No Jeff, my clutch is also a ratchet type by the back and forth motion comes from the up and down motion of the handle attached to the arc gear segment.Rmack here are a couple of pictures of my Canedy Otto Blower. It takes 2 belts to run the blower, one pulls one direction then the other pulls it the opposite, inside the hub is a ratchet mechanism. Does yours have that also?
I have a jug of ATF/Acetone here in the shop but I was never thrilled with the results I got from it.Not a huge fan of the PB Blaster. Kroil is much better, but it's expensive, and you have to order it. I'd recommend a 50/50 mix of acetone and ATF. Supposed to be superior to Kroil, but I'm not so sure about that. Whatever the case, both are significantly better the PB.
Until I can get to NAPA to get some, I'll keep using the PB, It's better than nothing.Toss that pb and buy some CRC Knocker loose. Works better than anything I have used, and isn't overpriced like Kroil.
Good hitch, bad truck. My truck spent the first 13 years of its life in a coastal town where the roads flooded with salt water every moon tide. Guys that live where they salt the roads every winter probably have better trucks than I do.What's up with that hitch? I remember you had a previous issue,but don't remember the details. Seems like an odd thing to break...wonder if you got one made of junk steel?
Spot on JB. the front two fasteners are bolts with nuts that were supplied with the new hitch. The rear fastener was an OEM bolt that went up into a captive nut on the frame.It looks like to me there is a missing bolt, just to the right of the circle there is a place for another bolt. The one missing is the main load bearing (tension) bolt when the hitch is loaded, the failure point is in line with what I would expect if the other bolt were missing.
JB
The picture doesn't show it but there is an old witness mark from the bolt when I originally installed the new hitch. I did torque every bolt to spec and I'm surprised that I was able to as there wasn't much left of the captive nut for the OEM bolt. I reworded the fracture in the hitch and made backing plates for the new bolts and nuts the replaced the missing OEM bolts. .Definitely a missing bolt. There isn't even a witness mark where a bolt had been.
That is a nice piece Mack.
Mac, I know nothing about the right way to make garden curbs. The ones I've seen have the low side toward the lawn and the high side toward the garden. I thought the low side was where the mower wheels go so the grass is an even height and you can run an edger on it. Seems like the high side keeps the garden mulch from spilling into the lawn. Kinda like this curb:
