ESCO jack stands - keep or return
palsor1
Austin, Texas
Hey guys,
After reading overall good reviews here and on a few other sites, I ordered 4x ESCO jackstands. The material quality seems good but the manufacturing is a little questionable. I attached pictures of the post from each jack stand. As you can see, none of them are straight. That said, I’m no t sure how much it will affect their ability to get a good stable safe setup under my car.
What do you guys think? Keep them or return them?
Andy
wkndwarrior29
NorthEast
I don't think it will affect stability - you can always try and see? I love my esco stands.
Sent from my XT1650 using Tapatalk
vssjim
McLean Va.
I would think they should be square as a basic quality need and check, i would call and complain. No different than a jack stand that doesn't set flat and rocks another basic.
Billythekid1
Y buy stands like that I don't see where the strength comes in mabe I'm missing something?? Deff make a call
Ole Slewfoot
Freedom, CA
That's only half the stand shown. I like the 3 leg design. I have some real similar ones made from plumbing pipe, but I think My tops are still straighter.
alberto
Hmmm, I'll have to check mine. I agree that for the price they should be close to perfect. That said, there's enough slop built into the bottom piece (on purpose) that I doubt there's any issue with its function.
WittHay
Surrey, BC Canada
Is the bottom receiver, welded perfectly vertical or is it welded at a slight angle. Maybe put the 2 pieces together and then see how it looks.
helterskelter
They're perfectly functional. I would just use them. Mine are a little out of square as well.
GasNSteering
Zoo Jersey
Replace. Maybe they are knockoff's?. There should have been jig welded for precision and should be plumb, level, square, etc.
The Tool Tyrant
Bonita, Ca. (San Diego)
That just ********, plain and simple. Poor or no quality control, they should be ashamed and embarrassed to send a POS like that out the door!
I just returned a receiver style Warn winch mount back for the very same reason. The 6" long 2x2 tube was 3/8" out of square with the mounting plate.
WTF...what ever happened to having pride in your work or product?...corporate greed at its best
Return them with a brutally truthful note.
vavet
Ashland, VA
You have the square setting on one surface with the stand setting on another. Do you know for a fact they are co-planar? As in, did you verify they are both level? Or the same amount out of level?
I suggest you give them a call. Perhaps there's an easy way to determine if they are counterfeit. If not, ask them how close to perpendicular the upright should be. I would not accept those for the price of them.
P
palsor1
Austin, Texas
I thought about that. I did check it quickly with another square and it was really close to perfect. Plus, a couple of the posts are crooked enough that you can see it with just the visual reference of the table edge so I’m inclined to trust the squares. In any case, they’re sending new ones.
Crawlin
NC
I got a pair for Christmas and mine were square but one of the posts had some casting on the bottom and would not allow it to slide into the stand. I just sanded it off with my belt sander and they work great now. Seems their quality control ***** and the rubber smells like a Harbor Freight store lol
nh_yota
Seacoast New Hampshire
Ordered a pair of them a few weeks ago from Amazon and the top plates were crooked on both so I had Amazon send me a replacement set. The top plates on the replacements weren't as crooked but still not perfect. I used them for the first time this weekend on my Tacoma and they worked out great. The section of the Tacoma frame where you place the front jack stands is too wide for the saddles on regular jack stands but it's flat so these work perfectly.
Firebrick43
West central Indiana
Making mountains out of mole hills.
Making a weld like that square would be if cult in a production environment. Other than drilling a hole in the pad and turning a shoulder on the rod and pressing them together first will you eleminate most of the warping. Even then it will warp the top plate to a mushroom/domed shape and drastically increase cost. Heavy fixturing is posible due to access and heavy tacks can still be an issue.
Go lay a 36" straight edge several places on your floor and see the gaps under it. Going to rip up your concrete?
BDT/NWMN
Erskine, Mn
If a manufacturer isn't set up to weld two pieces together without being crooked; I would pass on any purchases.
I would rather not make up excuses for them when they shamelessly sell crooked jack stands; produced in the USA or not.
