Euro Tools Query
_brian_
Wisconsin, USA
Seems a lot more useful for 1/2" drive though (3/8 is still quite small...), but I'd definitely grab one if they sold them here (but I never saw anything like this here in Europe).
I see what I posted here I see mostly as 3/8 and then 1/4. I know they make some 1/2 sets of those, but they are not so common.
F-22
Coincidentally, up to about 20 years ago any 3/8" tools were a big oddity in Europe, and even today most workshops use solely 1/4" and 1/2" sets.
Dave455
Sussex, England
There are also some regular square drive ratchets with a hole through the anvil that allows you to slip a small allen key in. Proto makes some, not sure who else.
Those are for “Hi Lok” fasteners used in the aviation industry.
Basically they are a bolt without a conventional bolt head. To tighten the nut, you use an allen key in the bolt, and a wrench to tighten the fastener. They are used where access to both sides of the fastener is difficult.9D82811F-4F59-4274-9AD6-811A30E12B66.jpeg
Any maker catering for the aerospace industry offers these. Snap On, Stahlwille, KoKen certainly do.
_brian_
Wisconsin, USA
I have heard this from my father as well, but for the US when he was a mechanic when he was younger. Everything was 1/4 or 1/2 inch drive, there was no 3/8 even available. I am not a professional, so what I use really does not matter much. However, most of the professionals that I know all use 3/8 as primary or 1/4 inch when they can. It is talking to them that caused me to expand my 1/4 drive set to 15mm. There are many that do not even use 1/2 drive except for impact. YouTube also results in videos outlining for new people to the mechanics field that 1/2 chrome can often times be skipped over in the beginning as you can use 3/8 for most all non impacting needs.
I am one that never really used 1/2 drive in chrome, except when I could not or for other reason did not use my 1/2 impact. My reasining was the tools, especially the ratchet, are just too big for many things. I will say that I ordered a new short set of 1/2 sockets since I got that nano Astro 1/2 drive ratchet. My 3/8 set takes me to 24mm in both shallow and deep, so it is not often that I actually need 1/2 inch drive.
F-22
Yep, 3/8 does most stuff well enough for home and general automotive needs, and if I bought all my tools now I'd go that route. For farm equipment and trucks I'd probably still need 1/2 too, and i even have some 3/4 drive sockets that can be very useful.
_brian_
Wisconsin, USA
Still need the 1/2 drive stuff... axle nuts, suspension and frame bolts, etc will all do much better with 1/2 inch. I have a few 3/4 drive but it is an old Craftsman SAE set that has 1 inch and up sizes approaching 2 inch, so they dont get used much at all. I have been thinking of upgrading my axle nut set from 1/2 to 3/4 drive, but that would require me to also get a 3/4 impact and that makes for an expensive total upgrade cost with limited use for me.
As far as engines, I work mostly on passenger cars and trucks/SUVs, the occasional HD truck and small engines. I dont work on farm stuff, commercial type trucks, semi, etc, so that keeps me out of the 3/4 and 1 inch drive market.
silkman
Athens
Yup, the Audi ones are like these, only with threads in the whole bolt shaft.
Check this out from Bahco, not bad
Amazon uk has many options, search for pass through ratchet set
_brian_
Wisconsin, USA
That looks like a nice set. The set I have is old, one of the first ones introduced from Gearwrench (branded as GearRatchet). My set is nice, but it goes from 10mm to 19mm only... and has some SAE sizes which I never use. While the set covers most things, it would be nice to have the smaller and some larger sizes.
Some sets are interchangeable with others, meaning you can buy brand A sockets to go with your brand B set. However, this is not always the case. I mention that as I would recommend if you get such a set to get the most complete set you can. It is not like buying a regular socket set and having the ability to buy missing sizes from any brand you want. In some cases, like the Craftsman Maxx Access, they are discontinued making filling in gaps harder. The Gearwrench style, branded Vortex, seems to be the most common I have seen as far as other compatible brands. However, I must admit I have not looked too hard into the options. I am only looking for a larger ratchet with a flex head and find the Gearwrench one a bit too expensive for what it is.
On that topic, are there any Euro tools that are designed like the pass through ratchets, but having a 17mm hex opening and still having the retaining ring/clip inside? The Gearwrench has a size that seems like 17mm, but it is not a hex, this does not properly fit a true 17mm hex.
silkman
Athens
Hazet (and others) has a shock absorber set but its pricey, ratchet inside ring is 21mm.
Ratchet
Set
This is used for VW/Audi shock absorbers
dukefx
I still don't use any 3/8. It's either 1/4 or 1/2. I don't need anything bigger either. If I do then it's for plumbing and I use pliers wrenches (or adjustable wrenches if it fits better... like right next to a wall).
_brian_
Wisconsin, USA
I wanted to follow up on this thread. It has been a few months and I have used some BGS tools, so I can now have an opinion that matters. What is it exactly that causes the opinion of a lower quality tool? I understand they are rebranded and all of that, and that the quality is not at a level of Snap-On, Wiha, etc (all those top brands), but what are the issues people have experienced?
My experience has been mostly positive. I would take BGS e-torx sockets for example over Gearwrench, I have both brands of e-torx. Why? The reason is the fit and the reduced sizes. The Gearwrench e-torx sockets are bulkier than the BGS, and in return I do not see any advantage. Now, the cost... it does cost me a bit more as I need to import BGS whereas with Gearwrench they are often available on a nice sale price. But regardless, the cost of all I refer to is reasonable to me and comparable, if that makes sense.
Howe
I can understand what you mean with this. However, it is not a matter of just wanting European tool brands, but the tools. For example (and a poor one), you cannot find a 19mm spark plug socket here. Only way to get one is to import it. Yes, we have the 3/4, so it is a bad example, but it does illustrate the point.
I was needing a few items, such as E11 (external torx) and H11 (11mm hex) that are simply hard to find here.Our sets generally do not include these sizes. I have a "master hex set" with a good number of sizes, and 11mm is not one of them and is the only size I have ever needed the set did not have. When I look at European tools, this is not the case. These sizes are in the sets and kits, even the non top end brands. This is why I am looking at the tools. In the case of the E11 size, I was able to import a 5 piece set (which included the E11) cheaper than I could buy an individual E11 socket here. A few brands do carry them, but at a high price. Otherwise, the option is a generic non name set that includes the size, but that is not something I want. I prefer at least a brand that brands their tools, is recognized, at least has a web site, etc. The generics (Amazon brand and generic eBay stuff) is ok and can work but no of interest to me for most things.
Regarding shipping, you are 100% correct. I mentioned Amazon as the location I was sourcing these tools as they provide free shipping. It is those listings I look at only, although the majority require extra shipping charges. I am strictly looking at value, and when I can get European tools imported / shipped here at a better value than domestic tools, I go for them. The issue I query about here is just knowing the brands. Since the "free shipping" selections are small, I need to select from what is there vs a brand of preference. EXample posted here, Kasal's post of his KS Tools kit includes the E11 size. A sie not covered here in dedicated external torx sets, much less a tool kit like that.
I really appreciate the input from others on the brands. This is something that I can do easily with US brands, but with non US brands, my experience is much more limited. I only wish to avoid getting fooled into thinking that a tool is good quality when it is not.
What do you think of this?
Are these socket set good? Quite cheap in the online marketplace
f121
UK
Draper Expert are just another Taiwan/China rebrand, but they have a lifetime warranty and as long as your local tool shop will honour that then they’re a good buy. I beat on Draper Expert ratchets and sockets for about the first 20 years I was wrenching and have no complaints, particularly at the price point.
Howe
Draper is Taiwan made? I thought its COO is Britain. No wonder Draper socket only set , come around USD 37.5
f121
UK
Draper is a British family owned company, but as far as I know they don’t manufacture any tools in the uk. The vast majority of their stock is imported from Asia, not sure if it’s Taiwan or China, although I think Draper are also the UK importer for knipex.
Some history here:
tamaraw
Some history here:
I believe that they are the UK importer for Elora as well.
Howe
Some history here:
Confirmed, Draper Expert completely made in Taiwan, I asked the importer this evening.
