We change a lot of car batteries at work. I'm getting tired of the poor methods we're using.
Currently I'm using the wire brush two ended all in one tool but of course it's too tight for the positive terminal and too loose for the negative terminal, and it won't clean cables after it's done about four batteries.
I also put dielectric grease on the battery posts, clamp them down and then spray on battery protectant on everything.
Some cars have the newfangled wedge style clamp- I've seen them completely disassembled and greased up and that's awesome but I don't have time to do that.
I found a battery terminal spreader pliers via another post on here as well as the m12 port with the cig lighter, combine with a memory saver in a very compact package. I don't think the pliers are worth bothering with though.
I know of several different battery terminal cleaning tools, which one would you recommend using in a professional mechanic shop?
I like this one, have seen it in several different designs, but the commonality is that there is no wire brushes in it.
https://www.autozone.com/test-scan-...ing-tool/lynx-battery-cleaning-tool/96001_0_0
Thank you for your thoughts and feedback on the best way to change out car batteries.
