Excavator and hard Texas ground
930dreamer
Amarillo,TX and Stinnett,TX
I started to dig the trench for a new shop service with the mini excavator today. Easy digging until I get too this area and the Kubota won't bust through this ground. I can break it up with a sledge hammer!
LeeG
Phoenix, AZ
That reminds me of the caliche we have here in AZ when I worked on a pipeline crew. A big Case backhoe had problems with it although the big excavator didn't. If we had to "hand dig", it usually involved jackhammers.
larry_g
oregon
Is this a rental excavator? I've know a couple of places to turn down the pressure to keep renters from tearing up the machinery so much.
mcbane
California
If you can break it with a sledgehammer or dig it with a hand held breaker, something is wrong with the excavator or you are using the wrong bucket or digging technique.
In really hard soil or weathered rock, you want a narrower toothed bucket and rather than try to grab a full scoop, you want to use the teeth as if they were the blade of a wood plane. Taking light cuts at maybe a 20 degree angle tooth vs ground, even a mini excavator can go through some awfully hard material.
I usually rent a mini ex with a 12” and a 18” bucket, both with teeth. My soil is way too hard and rocky for the 24” toothless bucket to gum its way through.
Bert_
NW Iowa
That's a pretty small machine. Might be able to break it up with a frost took mentioned above.
ycgoat
S.E. Va
I rented a mini excavator for my shop service and ran out of time, mostly due to time management but I was disappointed with how slow it was. In the end I dug both ends where I needed room and came back with a trencher. Next time I will get a bigger machine.
Jackfre
N CA
I had a problem doing a ditch for a friends electrical service line to his shop. My BX-23 couldn’t touch it. We rented a bigger excavator with a 12” bucket and it had a difficult time as well. Once I got the hole long enough I reversed the machine putting it over the trench. I had better success breaking the dirt into the open hole as opposed to trying to cut into the fresh soil. We got it done but it took a while.
dcg9381
Austin, TX
Texas here. Same issue where I am. Anywhere from 6" - 18" of actual soil and then it's largely limestone. You CAN break it with a jackhammer, but I've had a contractor out with a 310L Backhoe and a 24" bucket who said "no" to trenching for us. You either get a rock hammer in there, then dig it out with bucket, or you get a rock saw - which is the way to do any major trenching around here.
When I rent equipment, I get the smallest tooth bucket that I can find. Even doing it that way, there are some "shelfs" of rock that you can't get under...
This is a 2" water line that I "sleeved" in gray electrical PVC in certain spots. Rock saw for a trench is the only way to do it here... 1645460631065.png
My Old Tools
Hamrick Lake, TX
When I put in a 1/2 mile of water line, I rented the biggest 4 wheel drive ride on trencher they had. When I hit the gray clay on the 4th of July I was in the lowest gear and it was jerking chunks out of the ground the size of basketballs.
dcg9381
Austin, TX
The rock saw I used had a "creep" dial, literally you could set it to do a few inches every few minutes. Still a beat down to ride on.
Renting one 2-3x more expensive than a trencher. But there is no way you could get a trencher here to do a 300' run through huge sheets of underground limestone.
My Old Tools
Hamrick Lake, TX
I believe you. That clay was like a terracotta pot, but nothing like limestone. Where we are now is iron ore country, a whole different problem.
rayra
Escaped from Los Angeles
crazy andrew camarata has a youtube vid of his buying such a machine and letting it creep a trench thru his shale moutainside, running with him not even on it.
/he's living the dream of any kid that played with Tonka toys.
TractorJeff
Elkhorn, WI
FWIW: Up here when I go to borrow a little machine like that. I ask if the "Shovel" is available? It isn't really any more powerful than a good man on a shovel. BUT! I am NOT a good man on a shovel, so I will take the powered "Shovel" any day! LOL!
