Exhaust Fan Ventilation - Intake
dblynch90
Hi everyone,
I just built a 30x40x16 spray foam insulated garage. I installed a 24” Exhaust fan on the far gable end. I noticed the fan did not like to run with the doors closed so I started installing some intake vents. I have 3 10” Round intakes, and I still have to open a door for the fan. I really don’t want to keep punching holes in the side of the garage, but am worried about burning out this fan. Any thoughts?IMG_3213.jpeg
PCustoms
VT
Air in needs to equal air out.
If the air you're pulling in is hot (or cold in the winter) it's not really accomplishing anything
ItsNemo
Canada
3 x 10" holes is around 240 square inches.
1 x 24" hole is around 450 square inches.
You have half as much intake area as you do exhaust....you either need a more powerful fan to **** the air through despite the restriction, or you need more intake.
CraigStu
Blacksburg, Va
How are you deciding that you need to open a door for the fan? I understand your concern but I am not sure having some restriction on the intake side will automatically cause a fan problem. Think about all the bath exhaust fans in houses that basically have no inlet and that do not burn out.
