Exhaust hanger removal tool from snap on
PoorOwner
CA
Manual calls for snap on ya3202.
Had to search to see what that looks like, does anyone know some similar pliers or ways to accomplish the same thing ?
Rlfd213
Usually I would spray penetrating oil on the hanger and in the hanger. Then use a pry bar to work the hanger out of the rubber.
FigureItOut
Bentonville AR
I'd bet that's easier, but I use something similar to this and it's easy enough. If they're stuck pretty good I spray a little water and twist 'em loose. I'm not 100% sure what different lubes would do to the rubber but I don't have to mess with those often.03f26001db228db30cba9ee0db3210a8.jpg
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
colin39
Spray oil and use ya hand , ive never used a tool of any kind on an exhaust rubber.
APEowner
Sunny, New Mexico
Sure you can get them off using other tools and techniques but the right tool works really well. I've used both brands and I don't have a preference
P
PoorOwner
CA
The thing is I am daunted whenever i see remove exhaust hanger
I don't have hulk strength finger like some of you guys and my palm get bruised etc
On old cars it may be easier but on a new car that is difficult especially one that's been a few years the rubber just started to harden a little more
Rosso
Scotland, UK
I've got a set of the Lisle pliers, work great.
Some rubbers are ******* tight even after spraying with oils etc.
P
PoorOwner
CA
Thanks for finding the Lang tool one it appears to be the oem for snap on / blue point
Stooge
South Shore, MA
I have the lisle plier tool and i would say its worth the $20 price, takes all of the frustration out of fiddling with the rubber hangers. I dont use it too often but im glad i have it
rlitman
Long Island
Probably nothing good.
I saw the Lisle tool, and needed something like that one night after the stores were closed. So I welded together something similar using rebar and a pair of broken groove joint pliers in the junk drawer.
That style tool works like a charm, needing no lubrication to take everything apart. Once apart, I re-lube with the same silicone grease I use on brake caliper pins (which also slide around in rubber, so it's got to be safe on the rubber), and it always goes back together like butter without needing a tool.
zdech123
SW Ohio
Pb blaster and a pry bar work great. For stubborn hangars with enough room to access those pliers do come in handy though.
Wamsutta
Amarillo, Texas
Would you give it 5 stars like the other people did?
Stooge
South Shore, MA
Sure, i have no complaints about it; works exactly as it is supposed to, saves time, makes life easier, was cheap enough to forget about what i spent on it and if i was in a situation where i didnt have one and tried someone else's, i would be convinced to buy one.
K-Dog
Millersville Maryland
Yup. The Lisle tool. Worth every measly penny. Its one of those tools, you never really know how completely cool it is until you have one.
Chris83
Langley, BC
I got a pair from Mac identical to the lisle pliers. Paid about $30 for them and like others have said I don't know how I went with out them for years.
JR 42
Sunny Seattle
I used dialectric grease, followed by elbow grease, when I was working on my truck's exhaust earlier in the year... the 15 year old exhaust hangers haven't rotted away since then, so far so good.
JR
bwringer
Indianapolis
I did not know such a thing existed, but now I must have one... damn you, Garage Journal!
Also, let's not forget the most powerful tool at all: a wallet. Most of the time, these stupid exhaust hangers are fairly cheap to replace, and new ones usually work a lot better. The only catch is that they can be a pain to find sometimes, so make sure you have the correct new ones in hand before you go hacking the old ones off.
sberry
Brethren, Michigan
If I need it on occasion wouldnt blink at the price of these. Sis a couple the other day with spray and Channelocks, put back on by hand but there is a time and place the 30$ would come back.
jn50308401
Yup, short pry bar, lube it up and pop it out. I hated exhaust work, in Michigan in the winter time when everybody's frickin' muffler decides to fall off!
Sent from my SCH-I545 using Tapatalk
bry@n
Ocean County, NJ
When I changed the mufflers on my first mustang I did it but laying on your back makes it a PITA. I saw this tool in the catalog and said, "I have to have it". made putting new mufflers on the second mustang a lot easier.
