Exhaust Manifold
onecheck
New York
I have an exhaust leak coming from the front exhaust manifold on my 1998 Chrysler Sebring 6cyl 2.5L coupe. I took the exhaust manifold out and there is 2 even cracks on the left and right side of the manifold (see picture below) Is this normal?:headscrat
84bimmer
Lawrence, KS
no pic. I'm not too familiar with Dodge, but there shouldn't be any cracks in a manifold. Maybe see if you can blow compressed air through.
84bimmer
Lawrence, KS
The cracks outside the bolt hole? I don't think that could cause a leak. It is after your gasket. Look for small hairline cracks, they can be very hard to see. How was your gasket?
O
onecheck
New York
The gasket was filthy around the top corners. Before I tool the manifold off I sprayed the manifold with soap and water and it was bubbling.
Theloniousmonk
Where the tall corn grows!
those are factory afaik...for expansion/heat reasons, ... you may just need a new manifold gasket and retorquing of fasteners (use new nuts if it's studded, or use new bolts, imo) did you know for sure the leak was coming from the head/manifold gasket area? edit: just read your update - probably just need a gasket - the expansion/contraction of the manifold on the gasket acts kinda like sandpaper and will wear the gasket out over the years.
O
onecheck
New York
Thank You:thumbup:
84bimmer
Lawrence, KS
I tried looking for pics of a new manifold. Couldn't find a new one in my quick search. But yeah, those are there for the heat expansion, so the bolt or stud doesn't become stuck to the manifold, or can be freed easily.
Don't clean or spread the soot, cleaner areas on the manifold where it should be dirty may indicate cracks. They can be hard to trace. I'd say if you don't see anything, throw a new gasket on, properly torque new nuts/bolts and check. If you still have a leak, hit the junkyard, as a new one may be hard to find for a reasonable price. I checked rockauto.com, napa, and autozone, they don't carry a manifold. Gasket at autozone is $11.
4000xt
I agree with Theloniousmonk. Clean that badboy up and new gasket. Hard to tell from pics if any issues. But looking at it and the build up it had to be leaking. Were you getting any ticking nosie when cold startup?
O
onecheck
New York
slight ticking sound but I did get P0420 Trouble Code "Catalyst System Efficiency Below Threshold (Bank 1)"Which can be caused by an exhaust leak.
84bimmer
Lawrence, KS
Identifix points towards the catalytic converter more than likely being bad. Possibly o2 sensors. I'm wondering why the right side manifold is $700 more than left side? What is so special about it? Replace the gasket bud, it may fix it all........
KU_MechE
factory slots that allow for thermal expansion without binding or distorting. If you have a leak, have your manifold surfaced by a machine shop
simplec6
Doesn't look like a stress fracture, so I'm voting they should be there for expansion/contraction like everyone else is saying.
jethro29
central delaware
it's been my experience that 9 out of ten times if you got a 420,you've got a bad cat.and chrysler's factory cats are junk.i've replaced them at 60 and seventy thousand.good luck.
csargents1546
Westminster CO
I agree that those slots are for expansion and contraction. Also take a good straight edge and check your manifold for warpage. If it has any warpage, take to a machine shop and have them plann it for you. Carquest up here charges 50.00 per manifold. They do a great job. The best way I have found to clean the head side is to use an air angle die grinder with 3m roloc pads. At work we use the yellow rolocs.roloc.jpg
O
onecheck
New York
I don't have access to air so I cant use the die grinder. Can I use carb cleaner, scraper then sand paper?
treasureseeker
I have used a fine flat file like Craftsman sells. I am suggesting using it to clean up the manifold not correct if it is extremely warped. I found out about the anti-seize at Roush which was their standard procedure on graphite exhaust gaskets that leaked
84bimmer
Lawrence, KS
I don't think your too concerned with the manifold having a crack. But, if you do take it to a machine shop for re-surfacing, you should have them check it for cracks. They should have the equipment to do so. It is common for cast iron exhaust manifolds to crack.
Greatbear
Columbia/Fulton, MD
The slots in the bolt holes are normal. They are for stress relief and allow the manifold to move around slightly to compensate for expansion/contraction.
Lay a straight-edge across the flange. There should be very little to no warpage. Always use new mounting hardware when reinstalling.
