I have an exhaust leak coming from the front exhaust manifold on my 1998 Chrysler Sebring 6cyl 2.5L coupe. I took the exhaust manifold out and there is 2 even cracks on the left and right side of the manifold (see picture below) Is this normal?
those are factory afaik...for expansion/heat reasons, ... you may just need a new manifold gasket and retorquing of fasteners (use new nuts if it's studded, or use new bolts, imo) did you know for sure the leak was coming from the head/manifold gasket area? edit: just read your update - probably just need a gasket - the expansion/contraction of the manifold on the gasket acts kinda like sandpaper and will wear the gasket out over the years.
slight ticking sound but I did get P0420 Trouble Code "Catalyst System Efficiency Below Threshold (Bank 1)"Which can be caused by an exhaust leak.
If you have a leak, have your manifold surfaced by a machine shop
mitsubishi junk
I like the 4 cylinder Mitsubishi's. I have just used a flat file on exhaust manifolds like that. If it uses the graphite gasket you can coat it with the grey anti-seize to help seal it .
