Expendables - am I atypical?
Steve_P
I have multiple spare new drill bits in all sizes up to 1/4" as I occasionally break one; so I buy a bunch of Norseman bits at one time to keep the indexes full. Above that I only have a few spares as I have multiple full sets, and a Drill Doctor for sharpening. I've got thousands of new spare screws, bolts, washers, plumbing fittings, wire nuts, terminals.... I had a friend that saw my tool and hardware selection and he said something like, "I'm hoping to live long enough to go to the estate sale" 😆
bwringer
Indianapolis
I keep a pretty large stock of metric fasteners on hand, because for some damn fershlugginer reason, in the year 2024, when every last vehicle (aside from Harleys and other farm machinery) has been metric for decades, it's still a giant ridiculous pain in the *** to find metric nuts and bolts.
You'll find rows upon rows of gleaming, untouched, mostly useless inch **** in every hardware store, and only a few desperately pawed-through and nearly empty hidden drawers of metric.
And if you need JIS stuff for Asian brand cars and motorcycles, it's even more of a pain in the ***.
So even though I live in a large industrial city, I keep a large stock of metric fasteners on hand.
Sandpaper, who cares... I can get sandpaper, paint, plumbing fittings, quarter inch bolts and other such mundane commonalities in five minutes.
Sumboodie
AK
I've had the same main drill bit set since around 2005. Have replaced a couple, either broke or got too short from sharpening.
Can't remember the last time I needed a sheet of sandpaper. Proberly been 10-15 years. I use 36 or 40 grit on the orbit sander. Maybe 120 for finish work.
Keep some stuff on hand, but have to not get crazy.
Should I stock $500 in sizes of bolts and nuts that I might need every few years. Sure it's probably way overpriced from Napa, plus my time, but still.
Plus these days can have most things shipped in 4-5 days, so not the end if the worldto wait.
Dave455
Sussex, England
No - you’re not the only one, I’m pretty much the same. Only way to do it.
Various reasons -
Time and convenience - I live in the country in southern England. I’m only 5 or 6 miles from the nearest town. But… if I had to go there every time I needed something thats 10 - 12 miles minimum. That’s time, and hassle, and inconvenience.
Availability - If I make the trip above, they might have what I want, or might not. If they don’t, I now need to make a 12 mile journey, in the other direction…
Quality - If I drive 20 miles I can visit a drill bit specialist with pretty much anything I want. But, if I buy locally I can only get what’s available. It might be acceptable, it might not.
Price - buy a bottle of milk from a local shop and you pay more than from a supermarket. Same with consumables. It’s a false economy to buy one cut off disc locally when I can get two for the same money if I order in advance.
Keeping stocks of consumables is the only way to go.
Interestingly, the sort of things I stock are very similar to the O.P’s
Drill bits, centre drills, lathe tools and tool blanks for my machines. Stashed in a “store” in my house.
More drill bits, auger bits, forstner bits, SDS bits, saw blades, sanding pads etc for my power tools. All stored in colour coded boxes,
Every variety of cutting disc, grinding disc, flapwheel, cup brush etc for my grinders - buy ‘em on offer and they’re a fraction of the price locally.
Nuts, bolts and screws. Use ‘em all the time.
Woodscrews and wall plugs. Same.
Crimp terminals, connectors, wire and cable. Buy ‘em from an electrical factor and you get top quality for less money than the DIY shop ****.
gahrajmahal
Cincinnati, Ohio
Less and less I am “stocking” for something. I was pleased the other day when I looked in my auto supplies and saw I had a set of spark plugs for my Chrysler.
“Time” can be expensive. Last week my Honda Ridgeline wouldn’t start while finished at the gas pump. AAA came out and towed it back home for me to diagnose the problem. Since we had planned to take it on a road trip the following day I had to buy a refurbished starter at Auto Zone for $240. A new starter on Rock Auto would have cost $140 but I had to have it the next day, but that’s not the type of thing you would typically keep on hand
bwringer
Indianapolis
This may be a whole 'nuther topic, but I keep a stock of a lot of common and small-ish motorcycle parts and supplies on hand so I don't have to de-rail a planned trip or other work for something minor. For most brands you have to wait a week or so to get OEM parts in hand, and there's little aftermarket, so I keep a stash of...
- Fasteners, as noted above
- Wheel bearings; if I find a bad wheel bearing while changing tires, I can deal with it then and there without waiting. Motorcycle wheel bearings are mostly standard metric sizes, so the dozen or so sizes I have on hand cover a lot of bikes.
- Brake pads - they're small, and so I watch for sales and keep the next set on hand long before they're needed.
- Chain and sprockets - I keep an eye on prices, and often buy replacements long before they're needed.
- Steering stem bearings
- Fork seals and fork oil.
- OEM brake crush washers, drain plug crush washers. Why doesn't ANYONE else ever replace these?
- Set of spark plugs, at least for bikes with oddball plugs.
- OEM Oil filters; I order them in batches when I order other parts. OEM filters usually cost the same or less than aftermarket, and are much better quality.
- Spare sets of one-time use fasteners, like sprocket nuts, clutch nuts, etc.
- Gaskets; for example, valve cover gaskets, clutch and stator cover gaskets, etc.
- OEM clutch and throttle cables
- Water pump "kit" for water cooled bikes. (These are usually not sold as kits; you usually have to chase all the parts for a water pump rebuild through two or three parts diagrams.)
- Radiator hoses get replaced at around 10 or 12 years
- Spare grips and/or grip covers
- Fairing and body fasteners - when I acquire a bike, I often begin my stewardship by replacing ALL the assorted fairing and body fasteners, cushions, grommets, etc. with fresh OEM bits. I'm not sure why, but from the evidence I'm the only rider on the planet who uses the proper tools for these fasteners rather than sharp rocks, chisels, and nail files, and who is capable of keeping track of the parts removed and putting them back. Nothing freshens up a bike and quiets shakes and rattles like replacing tired and missing rubber bits, and installing fasteners that actually work, in the correct sequence. Any old fasteners that seem usable get tossed in a baggie and kept.
- For my older bikes, I have spare stators on hand, as well as spare regulators because these are common failure points.
Old Man Roger
Palm Coast Florida
By the gallon... and it's warming GEL... less likely to drip off.
I stand corrected, we’re lucky to have a pro around here.:lol_hitti
Ooooook... uhm... yea... hmmmm... I'd rather not commit at this time. Perhaps after the apocalypse... Sounds good?
Look at you being all shy and demure. Playing hard to get?
MongoTA
CT
Having a well stocked stash works wonders for efficiency. You just have to have the space for it. I'm running out of space!
I got lucky in that a few years ago I hit an unattended auction and got hundreds of bins of hardware and tooling. I'll never use most of it, but when I need something, amazingly it's there. I'd guess there's close to 700 or 800 drawers. All sizes and thread counts of nuts/bolts/washers. All sorts of bolt heads. Reamers, mills, bits, roller pins, gaskets, vents, all sorts of hardware. My avatar is a photo of a drawer of a drawers of one of my kennedy boxes that holds most of my larger drills. While I have letter and number, I mostly use fractional. I have maybe 3 or 4 sets of fractional. I sharpen my bits myself by hand. It was a few hours over a couple of sitting on a stool in front of a grinder to get that technique down. Smaller drills usually snap or get burned if misuse them, so they get replaced.
So hardware? Check. I love my stash, and it's a damn large stash. I easily have 3500-4000 lbs of hardware.
Drills? Check. And with drills I have to keep myself in check. I almost bought a few hundred more not too long ago.
Abrasives? For woodworking I keep a lot of sheet paper for hand sanding and 5" rounds for the ROS. Usually not more than 50-100 sheets/discs in each grit for wood. Flap disks for metal I only have 60 and 80 grit, and I only buy a replacement cylinder when the one I'm using gets below half. Cutoff or grinding disks I have 25-50 on hand. Abrasives belts and discs for metal I only keep a few 6x48 belts and 12" discks for metal on hand. I don't use the belts or rounds up too quickly so I don't want the belts to go brittle. Nothing like pressing metal against a belt and having the glue joint let go. Depressing.
Adhesives, yup, I buy by the gallon. I usually have 3 gallons on hand.
I sharpen my own saw blades (table/circular/chop saw) so I generally only have a couple of each different tooth count on hand.
Chainsaw, I have quite a few loops. I bought chain in a 100' reel and make my own loops. I have 18", 24", 28" and 36" bars.
I keep excess cans of starter fluid, PB Blaster, Kroil, brake clean, WD40, and 3-in-1 oil on hand.
I have multiple gallons each of acetone, mineral spirits, denatured alcohol, and boiled linseed oil.
I think that's about it. For me, it's an efficiency thing. I live 20-30 minutes from hardware/box stores/lumberyards.
Stevettt
I love flea markets and junk stores and consequently stock up on random items.
For example, I was at garage sale, digging through a giant tub of sandpaper looking for some wet/dry.
I pulled out about a few sheets and asked the guy. "How much?"
He says ten bucks for the whole mess, tub included, so I took it.
Spent a night sorting while I watched a movie, probably 500 sheets in every grit imaginable (good brands, too).
I bought a dozen brand new 12" Freud carbide-tooth miter saw blades at the flea market for a buck apiece.
I'll never use them all, but I can't seem to walk away from a bargain.
When I can buy USA-made files for a buck apiece, or drill bits and USA-made hacksaw blades at a buck per fistful, I can't resist.
Only problem is, I have to sort through a bin of China junk to get to that fistful of good-quality bits or blades.
I know, time is money, but I'm semi-retired and I enjoy the hunt.
rancherbill
Foothills County, Alberta, Canada
I guess that approach is why I'm astounded that I see people here pre-occupied with warrantying a cheap screwdriver they bought 15 years ago. Or whether they can get a dealer to replace a worn out drill or tap or extractor or similar because it was expensive when they bought it. Or asking how to extend the useful life of an expendable that they don't want to replace. Or how to refurbish/resharpen some item that only costs a few dollars.
Am I the only one who approaches shop expendables this way?
I 100% agree with all of your post. Tools are a consumable - end of story. Some guys end up working for Snap-On part time to pay for their tool bill. Apprentices probably are giving 20+ % of their salary.
In my garage I have a "tool room", "Parts Room", and "Supplies area". I don't have close to what you have, but I do buy replacement assortments on drill for example. This is one I like, Good underlying steel, good coating, and the most important is they have a great / proper grind from the factory. I used to re-grind with a drill doctor. These ones go on sale twice a year 50% off. I have lots of stuff and when they have the Estate Sale there will be lots.
PFSard
Mesa, AZ
I doubt you're the only person who manages expendables similarly. I'm a homeowner (not running a business). So your system would probably be overkill for me. If I were a business, I would be more watchful for obvious reasons. You know how often you are running out of these items. And how much time you save by stocking what you consider to be adequate for your needs. The balance between time and money changes over time, so ...............
I stocked my garage over an 8-10 year period with estate and garage/yard sale consumables et al. Last year I ordered online what I considered holes in inventory for drill bits, etc.
Home Depot is a five minute bicycle ride for me, although I can't remember the last time I was there for that category. Just bigger ticket items like a water heater, stove, paint, etc.
As far as screwdrivers and the like (tools) warranties, It's not worth my time now. I bought a lot of Craftsman tools in my day from Sears (great warranty). When Sears was still a thriving business, I would warranty some items when I was in the mall for something else. Although I rarely had to. Now, I just toss them into one of my junk drawers for later abuse or possible repurposing.
dr_clyde
Holland, MI
In any situation where time is money, keeping an inventory of commonly used consumables/wear items is wise.
Commonly used fasteners, drills, inserts, milling and turning tools, electrical and plumbing fittings, abrasives tape, chemicals, adhesives connectors and stuff like that are all good things to keep on the shelf because you use them on most every job in some form or fashion.
However, there is a line you cross where eventually your stuff owns you, and where it costs more time and money to manage the stash than the stash is worth. Every square foot of shop space has a cost, and if you eat it all up storing **** for the “you never know” moments, you waste a lot of money in oppertunity cost. A machine tool makes me way more money per square foot than a cabinet full of miscellaneous stuff I use once in a while.
McMaster-Carr, MSC, Amazon and any number of local supply houses can get me what I need in a matter of hours or overnight. It’s just not worth the real estate and organizational headache to inventory stuff that is a phone call or email away. I let them warehouse all the stuff I only need occasionally and try to toss or donate superfluous stuff so it doesn’t get in the way.
Robinson1
Kentucky
I live seven miles from the nearest thing that can realistically be called a hardware. I try to keep spares also.
Heck that would be like living down town for me!
42 miles to the nearest Lowe’s. Got 2 Ace hardwares within 20 miles although separate directions and a farm store that’s like walking into a time capsule. Napa and tractor supply within 20 miles as well
southalabama
Brewton AL
I received three packages of 12 each drill bits today in the mail. My wife was puzzled, and asked "why would you ever buy 12 bits the same size? Do you really need 12?" I told her I was restocking the cabinet; I periodically go through and note the sizes that are down to only a couple, and re-order and restock. I did say that I stock 115 sizes of bits up to 1/2", in addition to having larger bits. I stock from 2 to 20 each of the smaller 115 sizes, and typically 3 of the larger sizes. She asked how in the world someone could ever use up 115 bits, much less 12 each of 115 sizes. She guessed that a normal amount of drill bits to go through a year might be 2 or 3 or 4.
I have probably 10 to 20 index sets of bits. One or two of alpha sizes, 3 or 4 of number, and 6 to 10 of fractional. One set of fractional and one of number by the drill press. One fractional by the cordless drills. Several fractional indexes on workbenches and numerical on one bench where I do tapping frequently. A couple fractional in portable tool sets. Sets of all by the mill and lathe. I have a small drawer cabinet for each of the three series with spares to refill the sets. Another fractional cabinet near one workbench to refill easily there (not near the other work areas). Every time I dull a bit, I go to the cabinets, replace it, and throw the dull one in the used bit bin. I used to sharpen, now I just accumulate 5 or 10 pounds, and ebay them to someone else who likes to sharpen bits. I don't unless I have to. I may go through 50 or 100 bits a year, never kept track. Sometimes I go weeks without ruining a bit, sometimes I ruin 5 in 10 minutes.
I approach all other expendables the same way.
I stock 20 to 100 sheets of every grit of sandpaper/cloth from 30 to 1000.
I stock cutoff wheels, grinding discs and flap wheels by the dozens in different grits.
I stock 2x72 belts in about a half dozen grits, 3 or 4 belts of each.
I stock a few thousand dremel type grinding wheels, cratex, sanding drums, diamond burs, rolocs, etc.
I stock a few hundred 1/4" screwdriver insert bits in about 80 to 100 types.
I stock a few spools of weld wire, a few 5 or 10 pound cans of each type of welding rod.
Reciprocating saw blades about a dozen of each type, for maybe 150 total.
Sabre saw blades a huge assortment, maybe 250 total.
Wood saw circular blades, 2 or 3 of each type.
Hacksaw blades, a few dozen.
Taps, 5 or 10 of each size in different types (plug, bottoming, taper)
Carbide inserts for lathe and mill tooling, stock by the dozens to 20 pieces of each size and type.
End mills, about 400 in different sizes, types, configurations.
I stock gallon cans of most common chemicals and solvents, where I can use that much before it goes bad. I refill smaller containers.
I buy gallon cans of Titebond, and refill smaller containers from it.
I buy pound size containers of epoxy.
I buy gallon cans of cutting oils, refill smaller cans.
I stock a few thousand small screws, machine screws, washers, o-rings, lock washers, cotter pins and similar hardware. Stuff that's hard to get down at the local store or that I go through continuously.
I let the local store stock common bolts for me, they take up too much room and you never have an adequate quantity of a size. I do have a few divided bin organizers of small common sizes.
I have a few hundred wire nuts, connectors, crimps, etc in a wide range of sizes.
I have assortments of all kinds of ring and spade terminals in sizes for many different wires, probably a few thousand overall.
Electrical tape comes by the dozens of rolls at a time.
One or two of each paint color/type that I commonly use; buy individual colors as I need them for bigger jobs but like to have stuff for incidental use on hand.
I never worry about the cost of individual items on a job. I make the decision and pay for it up front to have a fully stocked shop. When I run low, I just restock. I don't want to be thinking about economizing on expendables or being careful to not ruin the one single item I have on hand to do the job. I want to do the job, use up what supplies/expendables are needed to do it fast and efficiently, and go on with life. I got to this stage slowly, buying what I could afford and building stock when I had a job that would stand the expense. After I got fully stocked, the occasional resupply pieces are pretty low cost in the big scheme of things.
Tell her you are the boogerman and you booger them up.
I admire your organization.
