Extendable handle ratchets?
What is your take on extendable ratchets?
  • Yes, they are worth owning.
    Votes: 13 72.2%
  • No, total gimmicks.
    Votes: 5 27.8%
  • Total voters
    18
unslow1
Illinois
I thought the HF extendable was a gimmick until a guy I work with bought one. After I tried it a couple of times I bought two for myself. They sit in the trunk of each vehicle with the proper socket for the lugnuts.
MJK
Tucson, AZ
I have a Mac 1/2" breaker bar with an extendable handle. It is great for shrinking down small enough to fit in a travel tool bag.
Never felt the need for any others.
darkzero
SoCal
I thought they were gimmicks. I bought the older green/black handle ones from HF (I swore that I would never buy ratchets & sockets from HF). I have the 1/2 & 3/8, I rarely use them but the times I have I put some decent torque on them & neither have broken yet. Thought the heads would break before the extending part. The 3/8 ratchet was double ended (I think they're still like that today), had 1/4 on the other end. That annoyed me so I machined the 1/4 anvil off.
Recently I bought a Husky extendable breaker bar (Apex, same as tbe GW but 1/2 the price) to keep in my truck so I can put my nice one back in the tool box. I haven't used it yet but it seems like it will be perfectly fine for lugnuts.
Mr_B
Reading
mike93lx
Richmond, VA
I have the HF 1/2. It's been quite handy and saves some time swapping between breakers and ratchets. It is bulky and heavy, so it isn't my first choice but it's nice to have and wasn't expensive
dnschmidt
Phoenix, AZ
The best I've used is TOPTUL's. They make 1/2" and a monster 3/4" or 1" drive version that goes out to 800mm (31 inches). Here's the link to each:
What's different about them is that they can be extended to any particular length and not just to where there are detents. You twist the handle to either lock or release it and then position it to whatever length you want.
mrjaw14
Nashville, TN
I have a Husky 3/8" extendable locking flex head that I've beat the hell out of when I was younger. It rides in my truck now because i want a flex head and sometimes you need a short one, and sometimes you need a longer one. Great for vehicle tool kit. My opinion is get one sourced locally so if it breaks you can warranty it since it'll likely be used in a...less than ideal way ;)
Crazyjake8493
Upstate NY
Absolutely worth having. The 1/2" version from Harbor Freight for $20 has served me well for 6+ years and I've really abused that thing at times. Lifetime warranty but if not I'd still buy another one immediately if I broke mine.
I also have their dual 1/4"-3/8" version and it's great as well, though I wish they were separate ratchets since the head is a little bulky.
gtae07
Fayetteville, GA
I have a Kobalt 3/8 one from a white elephant exchange a few years ago. It's gimmicky, but it has one feature that's actually come in handy a few times--if you twist the handle it drives the head. That's made a couple specific bolts a lot easier to deal with.
Dave455
Sussex, England
Absolutely worth having, for one reason in particular, which is carrying in a road box or other portable tool box.
Most of us have got one, and you can’t fit any sort of long handle tool in there, but you will probably need to take off at least a 3/4“ wheel nut at some point, which you will struggle to do with a short handle ratchet.
As CGarage says though, it needs to be quality. Haxet spring to mind (I’ve used these and they are decent) as do Facom. Facom offer one in 3/8“ drive.671554F8-AF80-45DB-A737-502278246F9D.jpeg44386BFC-CC92-496E-95D4-294E0B6C7E4A.jpeg
Qualitytools
SOCAL
I have a 3/8 Stanley 92-645 Extendable and flex-head ratchet that I use often. It comes very handy especially when you need to break something loose that is a bit tight and you need the leverage.
Professional Tool User
BC
I have the made in Taiwan blue handle locking flex head limited quantity ones from Princess auto. They are a bit bulky, but are great if you want multiple ratchet lengths in one and allow you to extend the handle quickly for extra leverage when needed.
