ishiboo
What idiot is saying that? Are you arguing with yourself?
Your very comment:
There's only one way you'll get a decent solid network and that's with a cable.
Let's not resort to name calling, but that idiot was you.
There are probably a thousand ways to rig up a satisfactory wireless solution.
S.
I ran cat 5 from my router out to my garage. What product do i need out there to throw a strong wifi signal?
Right now im in no man's land. Too far for good wifi, but close enough for it to keep trying!
I was going to hardwire a sonos for music, but want a strong wireless signal for face timing the folks.
Add one of these attached to the wired network inside the garage. Program it with same ssid and WPA2 key as the house and stuff will switch back and forth automatically as you walk back and forth.
http://www.amazon.com/dp/B00O4UJHCO/?tag=atomicindus08-20
U apparently have never setup high speed microwave wireless links- both high powered and low powered.
About a year and half ago I installed an 11Ghz microwave link for google that spanned 10miles. It ran at a solid 500Mbps and google was throttled at 250Mbps for their internet.
About a year ago I setup a 45mile wireless link with ubiquiti AirFibers. This was on 5Ghz and had a solid 100Mbps full duplex!
And more recently, i finished an AirFiber P2P ring with 12 AirFibers operating on 24Ghz at over 1Gbps. This network has auto redundancy built-in so that if one AirFiber goes down, the traffic goes in the opposite direction from both sides.
To say you can't get a "decent" connection with wireless is ********.
One of what?
An airFiber?
U can buy them on amazon as well as other places.
http://www.amazon.com/gp/aw/d/B00LV...s=airfiber&dpPl=1&dpID=41nnkb0S6AL&ref=plSrch
But theyre for long distance links.
If u used it for a couple hundred foot link at your shed, u would have to turn the power all the way down and they may still be overloaded.
A nano station or rocket m with an omni would suit u better.
No mate. You can’t be selective with quotes with me, or change history. You said:
So let me ask again; which bullshitter is saying you can’t get a decent connection with wireless, apart from you?
When I say:
That is NOT the same as your insulting comment above. Would you like me to draw a venn diagram?
S.
S.
I am talking directly to the OP who I assume (perhaps exclusively in this forum) is not a networking guru. You want to run a decent, solid network connection to a shed/workshop then unless you're one of the (many) networking geeks on here, you're going to be better off with a wired connection.
What is the difference between the two solutions? One is a length of copper, plug it into your router, job done. Switch off, switch on at either end and the connection is always going to be there.
With a wireless solution, you have to introduce a secondary system into that otherwise simple connection. That fact alone means more complication, which equals less reliability. Also with a WiFi connection, the IP address routing is invariably now handled by a different system to your home router, meaning complex setup to achieve a nice easy static IP for say a bunch of IPTV cameras you want to access via the www. I may be clutching at straws here but I also assume welding and/or noisy machinery motors are going to play havoc with a WiFi or radio bridge.
Anyhow, I am genuinely interested in the answer: if I rip out my lovely solid and reliable CATV cable and replace it with a WiFi/radio bridge, is my connectivity going to be better?
S.
Haha. Busted. Yes I am the idiot referred to in the above.
In my defence, I was many years ago a BBC broadcast engineer and
Haha. Busted.
When you refer to static IP, I remind viewers any installation at the shed end will most likely involve a secondary router which must be carefully configured to avoid the issue of DHCP allocation being confused between the two routers.
In my defence, I was many years ago a BBC broadcast engineer and whenever we ran a network or an ethernet bridge it was over CATV. In the above post I actually used the "V" as a "5". It's been years since I had to engineer any of that stuff myself.
Finally I have no doubt you can "get a faster connection" with wireless. Question is; where are you going to get that from? At some point (in the home) your local network is going to present itself on a regular CAT5/RJ45 connector and you can either (a) plug your shed into that directly with a cable or (b) introduce another system to form a wireless bridge. Such a bridge cannot possibly make a "faster" or "better" connection than copper because the source is the limiting factor and the source is (typically) wired.
All of this tech nonsense because I made a simple statement that (in my opinion) in the context of a typical shed user wanting to run a network from their home (router) out to a shed (within 150 feet) they would be much better off with cable.
But yes, it's been years since I had to work with this stuff and even when I did, it was in the television industry and I am not a network engineer (though I could probably find a fair few certificates to suggest that I am qualified LOL). So my opinion on this matter is, as you suggest, somewhat reduced.
