exterior pvc trim
billconner
Thousand Islands NYS
Can I mill PVC trim, like round over an edge or add a flute? and leave it unpainted? I've never used it and considering in place of some vinyl siding style lineal trim.
Motown
You should be able to router it. Make sure your have a sharp bit, otherwise you may have some melting from heat. It it flattens the gloom of the surface, you may be able to use a heat gub to bring some gloss back.
Monza Harry
Windsor ON
I've never tried a heat gun for this but a small torch usually will restore the gloss of many plastics [propane, butane, even a cigarette lighter, size of the part dependant). The melt point of most are in the low to mid 400° range but they start becoming "plastic" in the 200-250° range [where your "magic" will start to happen, move the heat quickly, to heat as evenly as possible] if you get to 400° for pvc, polyethelene, polypro, etc you will have a puddle. Nylon is a 600° melt material. These are rough range estimates, each "flow" (material) in a given group can vary enough to cause problems so practice on a very similar sacrificial specimen. Harry
PCustoms
VT
It machines great, but I have found that the edges get really dirty quickly due to not being smooth. Haven't tried a heat gun on it
I'm not impressed by it much due to the texture/porosity. Seems like it collects dirt immediately, and with how damp it is around here gets mildewy.
Should it always be painted?
About 5 years back I bought some PVC beadboard 8' lengths from HD, stuff was dead smooth and solid when cut. They stopped carrying it, but I wanted some more to patch in where a door became a window and the material that cost 2x at the lumberyard is super rough and looks terrible 4 years later.
