extra deep sockets
slowpoke
Tulsa OK
I need a deep socket that is 1 3/4" deep as opposed to the standard 1 1/2". Is there such a thing, and where? Thanks, Joe.
S
slowpoke
Tulsa OK
Thanks, I will look there. I went thru my deep sockets, several of which are Craftsman. The only one broached [todays education] all the way was a very old one. All others were 1 1/2". joe
S
slowpoke
Tulsa OK
Went to Sears today. They do have deep sockets broached to 1 3/4", but not all the way to the bottom. Lucky for me, 1 23/4 is what I need. I was surprised to see that Sears is accepting donations for military families. I was pleased to add mine. Joe
S
slowpoke
Tulsa OK
Not bad info at all. If you had not responded I would not be in possession of a socket that will work for me. The only ones that I have found to be more than 1 1/2" deep are the Craftsman. Joe
OccupantRJ
Eastern North Carolina
If you ever want a special depth deep socket, take a socket and cut it into, then weld each piece onto the end of a piece of pipe. You can make a socket as deep as you want like this. It is an old millwright trick for special applications. I also happen to be a machinist, so I take sockets and mill 6 flats around the top of them to create sockets that can be used with a box end wrench to get to bolts where other tools just don't work. An example of this is used on some spark plug sockets.
rsanter
visalia ca
snap on makes some extra deep sockets
I have a 1'' impact socket that we used for the racecar that is extra deep
bob
