csp
x2 on those NOCO chargers. I'm very happy with the Genius 10 and have brought back two batteries that were headed to the scrap place.
No problem at all. I sometimes doubt myself when faced with a situation where there's so much electronics involved (ECM). What hurt me the first day is I was doing everything I could to not remove the supercharger as though it was saving me time...I could have found it without removing it maybe. Turns out that it was good practice for just plain ol' trouble shooting. Never a dull moment.Glad to see you got it figured out Matt. Sorry I didn't respond sooner as I just saw your message this morning. I should have read this to see that you already have it sorted out.
Mike would have found it in an hour or less. It took me 2 days. I am left with a sense of accomplishment but only now that I've found it and I'm up and running.Matt, that's some Mike level troubleshooting. Nice work!
The internet is truly a magical place. I didn't find the answer there, but I was given a bunch of ideas some of which ultimately helped me narrow in on the actual problem Had I not decided to test continuity of the injector pig tails I'm not sure I would have noticed the retracted pin in the connector. Either way, I'll take it!!Nice work on resolving the wiring issues. It can be difficult to be able to step back and consider the 'other side' sometimes.
Thanks Mike! The plastic interior parts have a slight textured finish on them.Amazing work as usual Matt. Are you going to paint it matte black so it blends in or keep it raw aluminum after metal finishing?
Can I ask what brand of gauge this is? I have a small one that's similar but it is made of plastic and I really like yours that I am assuming is made of aluminum with nicely knurled thumbscrew.
Love it! Really like the 3D printed game, just struggling to get into something else to learn. I had planned on 3D printing mine as well even bought a printer kit to print it but the assembly was a son project that went south and then became quickly forgotten. Anywho…That switch box is going to look nice up there.
I don't have your capabilities so I had to print one for a Yota build. The bottom cover plate has a recessed LED rock light for a center dome light. Paired with an LED rock light under the dash at each end the cab gets pretty well lit. I was able to source some dual position switches (off-on-on) to match the (off-on) switches so they are all "off" in the down position. The double switches can be activated by the high beams (front lights) or reverse (back up lights), or simply turned "on". Makes it nice if you are on legal roads so you don't forget to turn off the lights with oncoming traffic.
Ah, I’ve seen this one in the store.
The angle finder is made by CCKL Creator and is stainless steel. I’ve had it since before I started the business. Probably 20-ish years now I’m guessing.
<snip>
Looks like you can still get both of them today.
CCKL Creator, Angle Finder Kit, Protractor, Design and Layout Tools
Save! on this combo that will measure almost any inside or outside angle up to 360 degrees! Includes the Angle Finder II and Angle Finder IIIwww.trick-tools.com
that's sweet. I'm friends with the president of Magnuson. Nice looking rig.Diagnosing a problem is fun, stressful, confusing, and always a learning moment. A recap on my situation - after starting the Jeep for the first time after the Magnuson supercharger install, i was getting 5 different codes. Three were injectors 2, 4, and 6 weren’t getting voltage, the cooking fan wasn’t getting voltage, and a throttle position sensor error. Oh, and the serpentine belt was too long just a bit.
Reseating the throttle body plug cleared the throttle position sensor error. Almost felt like a freebie. Next the cooling fan. Chases the relay and found I missed hooking it up to power. Another freebie. Next the injector errors. I was able to get (what I thought was) #2 and #4 disconnected and snuck in the ohm tester to make sure the injectors themselves were good. They were. I was struggling to get to (what I thought was) #6 so I removed the batteries, fuse box, battery tray, and intercooler reservoir.
As I tried to get access to (what I thought was) #6, it occurred to me that it’s really unusual for all 3 to be affected by a plug or injector issue. It needs to be something up stream. My first thought was that there’s a ground I missed somewhere. Seemed reasonable and after rooting around, I stumbled across a ground I’d missed which connects directly to the wiring harness.
Well hell, that has to be it right? I put everything back together and the entire time I was mentally preparing to do a victory dance. So happy…until I cleared the codes, fired it again, and the codes returned. Frustrated, I called it a night.
First thing in the morning, wanting a quick win to start the day, I went chasing a smaller serpentine belt. This time I bought the next three smaller belts as to avoid needing to take a bunch of trips. The 103 7/8” belt ended up the winner. Next, back to the injector issue. I was told that with key on the injectors should have voltage…but they didn’t. Back to the internet. I tried a bunch of things to no avail. Super frustrated, I somehow ended up on a JL thread where the topic was about the wiring harness and within was a picture of the JK’s cylinder numbering. Up until now, I’d used this pic as my frame of reference for cylinder mapping -
2, 4, 6 are in the passengers side right? This is what I saw in the JL/3.6L thread -
I felt SO dumb. The entire time I’ve been diagnosing the wrong side of the motor. I actually had a moment of happiness tho - I now had a lead…until I realized I can not access
Any of the injectors, they’re completely hidden by the supercharger. So it’s gotta come out and sonic does.
With it off, I have complete access to all three injectors so I quickly test them. All three test good.
Now to the injector pigtails. According to the internet, they frequently go bad. The question is, how do I test them?
The plan was to test the injector wires for continuity back to the plug upstream.
As I went to test the first one, I noticed this…a single pin in the connector had been pushed back into the plug. There’s NO WAY that isn’t a problem. That said, it’s a single pin and my issues were with all 3 injectors.
Since it’s a non-trivial task to put everything back together I figured I’d proceed with continuity testing all the injector plugs. The first one tested good. The second one tested good EXCEPT…the #4 pig tail also relied on the retracted pin!!! Excited now, I tested #6 and it also shared the retracted pin. I freakin found the issue. Back together the supercharger went.
The keys quickly found the ignition and vroom!! Fired right up and idled very smoothly. Tapped the throttle and it whined beautifully. Took it for a spin just as the sun was going down. Needed to hurry, the headlights aren’t hooked up at the moment. It runs good.![]()
Thanks. Like the SC a lot. Install wasn’t bad otherwise other than it was the first time so I went SLOOOOOW. If I did another one I could probably do it in half the time. That’s not his fault though.that's sweet. I'm friends with the president of Magnuson. Nice looking rig.
It really has been. I wish I could quantify how much it’s cost and how much I’ve saved. Just in bolts/hardware alone - meaning when I used to do a build I’d always buy all new hardware because it looked nicer. Now I’ll only replace it if the threads are damaged. Otherwise everything but the threads get sand blasted and coated.You being able to do your own powder coating is a game changer!
The attention to detail is fantastic Matt.
Sorry to hear you had to step back down to 37's. Oh the humanity.......![]()
It takes a big man to be able to step down to 37". Sounds like it does solve many issues and has some other upsides (lower Cog, lower effective gear ratio, less weight...).
Son-of-a…
6061 sway bar links can’t handle a burnout I guess…notice they failed where I cut flats for a wrench which also happens to intersect with where the link end thread shank stops. Hm, didn’t think about that. The weakest link, bye bye.
years later I bought a longer one in aluminum. Each have their place but the short one gets used 4x more I’d guess.
I guess it is a fuse (of sorts) just way too light.So.. it's a fuse of sorts?
Ordered the combo deal for both of these from Trick Tools. Layout tools are invaluable, and not straight forward to find. I appreciate you continuing to share your methods!
Oh I wouldn’t be so sure. LOL…found out that my sway arms are just barely running downhill too much. When my shocks are fully extended, the links can invert. The links are just barely too short. Guess I’m making another set. Have some tube ordered.Nice job on the new links Matt. You shouldn't have any issues with those.![]()
I’d buy a set but their shortest link is 7”.
