Face panel separating from garage door
hans109h
Upper Midwest
I've noticed that the inside metal facing on the inside of my insulated Wayne Dalton (40 year old) bottom garage door panel, is loose and starting to fall out. I decided to remove one of the panels and the foamboard insulation to see what was going on, what I found is that the outside face of the panel has separated from the "stud" of the door.
Photo 1: Door with inside face and insulation removed:
Photo 2: Close up of panel (white) pulled away from galvanized structural component:
Pretty clear that the construction adhesive has failed while allows the insulation to move and the inside panel to become loose. I can pinch the panel and bring the face tight to the stud, so I could re-glue it, but wondering if it would be better to drill a few holes and rivet the panel to the stud to prevent future failure.
This appears to only be happening on the bottom panel, so for now I'd like to see if I can keep this door rather than replace it. Any suggestions?
Thanks,
Hans
firebirdparts
Kingsport, TN
It's really light construction and this is what you get. I think rivets would hold for a while but I'd use glue too, rivets or not. If they wiggle they will come apart much faster than 40 years, I think. The reason they don't do that at the factory of course is the looks and also water getting in when it rains.
H
hans109h
Upper Midwest
I went with Loctite PL 3x and wide 3/16" rivets. Seems to be holding well, and the rivets, even with the wide heads they are barely noticeable.
Hans
