Faced batt insulation and plastic vapor barrier?
191185
Hello,
Looks like I'm going to try to insulate the garage myself.
right now I'm only talking about the walls. ignore the ceiling for now.
Live in Minnesota. Garage is attached, down to the studs.
I was going to do faced batt insulation, then do the plastic air barrier.
Someone at work said not to, then I will have TWO vapor barriers ?
I thought the face was only a vapor retarder ?
If I want to use faced batt insulation on the walls, do I need to do plastic after that ?
garage was built in 2003 is attached to the house, built same time as house, normal Minnesota construction should be assumed.
Copymutt
Colorado
I agree, faced ins. Is not sealed do to stapling gaps. If taped maybe till the tape deteriorates. High humidity locations, barrier goes outside studs. Low humidity, inside studs.
pattenp
Virginia - USA
Faced insulation is a vapor barrier. Either use unfaced with plastic for vapor barrier or faced without the additional plastic.
kTHREE
MN
Your shared walls to the house should already be insulated and have vapor barrier on the house side of the studs.
Are you only talking about the un shared walls?
191185
Yes. I am only talking about the 3 unshared walls. the shared wall is already finished and insulated and everything, I assume from when the house was built.
the other walls are on their own..
So if I buy the faced insulation, not vapor barrier like plastic is needed, not even for Minnesota ?
Mick56
Janesville Wisconsin
I'm in Wisconsin, so pretty similar to your location. I bought my house with an attached, unfinished, garage 25 years ago. I used faced insulation stapled to the studs, and then drywalled it. It has been fine ever since.
DFB
Southern VT/Western Mass
I would just stick with using the Kraft then simply cover it with your rock. It's how I did my house and garage bay in VT we get some pretty cold winters and some seriously crappy humidity in the summers.
I've seen the full plastic vapor barrier done over kraft faced insulation but slitting the paper so your not trapping any moisture between the two surfaces. Only thing gained in that scenario is the convenience factor of using the stapling edges to install your insulation vs messing with the hassle of fitting up unfaced in your wall cavities
rayra
Escaped from Los Angeles
'Stapling gaps'? wth are those?
bugnut
Central Ohio
central ohio some do and some don't. I wanted to insure no air infiltration trough the torn kraft facing and the gaps, I added the plastic. no issues, my .02 $, ymmv,
steves_001
Southern MN / Northern MN
From what I have been told by inspectors, Faced insulation should not have plastic, unfaced should. I've always just put up the faced stuff and dry-walled right over it. Never had an issue.
pudgybear
Brooklyn Michigan
I always thought that if you put plastic over kraft faced insulation that it would cause moisture to build up between them, So I have never used plastic, now you are saying it is ok - will it help with the heating bill ?
Prospecter
Maine
Midcoast Maine. Some do. Some don't. If you are still in the planning stages, though, have you considered other technology. Hi density cellulose would give you more R factor. A layer of foam would give you vapor barrier AND more R factor. Even for a garage, it's both less energy, less heating equipment, and quicker heat up of garage.
dfiler2
NW Minnesota
We started using both back in the late 70's because during remodeling projects we were finding friction fit insulation that had slid down from the top and it was a fairly consistent 6 inches. The main purpose of the poly was air infiltration and moisture. I have never seen any condensation problems between poly and the kraft faced insulation, the moisture doesn't make it that far.
CombatNinja
The kraft paper is a vapor "retarder", not a "barrier" per se. Lots of people use the terms interchangeably but they are not really the same thing. Whatever you call it, you don't want to create a situation where you are sandwiching the insulation with barrier/retarders on both sides. Unless you live in some strange part of Minnesota that I have never experienced, I would not worry about any vapor barrier and just do the kraft faced just as your wall shared with the house is already done. And just as an FYI, doing the walls without doing the ceiling is a waste of time. Due to the chimney effect, the vast, vast majority of your heat loss will be upwards through the ceiling.
dfiler2
NW Minnesota
I agree if the OP is only talking about the shared wall, it seemed to me he was talking about the three outside walls. I would assume the shared wall is done.
LS6 Tommy
Northern NJ
I apologize if I'm wrong, but with the small screen on my phone, it looks like that insulation is not properly installed. The flanges are to be stapled to the inside faces of the joists, not on the outside edges.
Tommy
CombatNinja
Tommy
No, that is the correct install. Stapling them inside compresses the insulation too much and it loses R-value. Stapling to the faces of the studs allows you to overlap edges, creating an infinitely better seal as well. You always see it done the other way because it makes installing drywall easier--you don't have to deal with the odd staple sticking out and you will never hit a staple with a drywall screw. It is the easy way, not the best way.
DFB
Ya agree that's the way its meant to be done, not folded on the inside for all the reasons given in the post above. I remember I worked for one guy who had a fit when I started doing a wall the other way tucked in to expose the studs (though that is the way I have done for years) **** I was doing the wall covering too, so it was really for my convenience but lapped all the folds instead. Will give a better air seal for sure
Just looks nicer the other way :lol_hitti
My house is done that way :beer:
YMMV
Though insulation is meant to be covered by code and not left exposed for fire safety oh man I have seen a lot of walls and ceilings with just insulation especially in camps and garages but doesn't make it right.
jetpilot2112
Central OH
Central Ohio here, too...
Not to hijack this thread, but do I want plastic between faced insulation and interior liner panels? The metal will form condensation before drywall would. (I have no vapor barrier on the outside, only metal attached to wood side girts)
Sent from my SM-N960U using Tapatalk
LS6 Tommy
Northern NJ
Then how come every inspection I've ever been involved with failed when insulation was installed that way and the Owens Corning training videos state to do it the way I posted?
It's also NOT easier to staple on the inside face of the stud instead of the edge facing out. Insulators don't give a **** about what he sheetrocker has to deal with.
:lol_hitti
Tommy
DFB
:lol_hitti
Tommy
Tommy I obviously I don't know anything about the inspections you mention but I am curious about them. Was it being failed only on the insulation install or maybe because that the wall framing was covered up and the inspector couldn't see it :dunno:
191185
Thanks guys, one last question,
Do I need to go around with caulk, and expanding foam to seal where the 2x4`s meet the plywood ?
Or can i just start insulating?
I'm only going to hear the garage 2 to 3 days in the winter, when I'm changing oil or fixing something.
191185
Like these cracks ?
191185
I'm going to do the ceiling next, just trying to figure out the walls first. Looking to start today.
Do I need to caulk / foam the cracks where the sheathing meets the 2x4's ?
191185
Was thinking of using rock wool for the walls ?
CombatNinja
:lol_hitti
Tommy
Just checked the Johns Manville install guide. They picture it being overlapped on the face of the studs. They not it can alternatively installed on the inside edges to make drywalling easier.
I frankly don't give a **** what Owens Corning or any "insulation guy" says. The vapor retarder is going to give you maximum benefit and the best possible air sealing when overlapped on the face of the studs. The only reason to do it the other way is because you are a)stupid or b) you want to make drywalling easier.
191185
Does anyone know if I have to seal the cracks where the 2x4's meet the sheathing?
Do i need to use caulk/ foam, or does it not make a difference and i can skip it? Looking to start today.
Only going to heat the garage 3 days a month in the winter...
Thanks!
LS6 Tommy
Northern NJ
The insulation job itself failed. The framing is a separate inspection that is done before the insulation can be done.
Tommy
LS6 Tommy
Northern NJ
I wasn't going off something I was told by an "insulation guy". I was going off the manufacturer's instructions from a training program I had to take and what multiple, unrelated inspectors had failed jobs for.
In any event, since the training I got was a long time ago, I looked up the O-C installation manual. It allows for face or inset stapling, so I guess things have changed. I also looked up ASTM C1320. Interestingly enough, that standard said face stapling may be required by code in some areas and it also said high performance insulation like R13, R15, R21, R22, R30C, or R38C may not require stapling because the density of the batts is sufficient to hold them and that there is no measurable loss of moisture protection of the vapor retarder.
My previous experiences may very well have been because the inspectors used outdated local codes in the areas I've worked or were just set in their ways.
Anyway, I'm always willing to admit when I'm wrong and learn. :beer:
Tommy
DFB
Tommy
Thanks for saying. Ya even though framing is supposed to be inspected before moving on I seen enough to know that don't always happen so I had to ask.
A few years ago my boss hired an out of state contractor who took a building thru the drywall stage ended the job and left never called for an inspection once not even the concrete work...needless to say the local building inspector was quite rabid :D I had to cut open walls to view framing, replace and resize support columns, reframe certain areas to meet ADA and do the stairs treads and risers over. Second floor framing didn't meet certain specific commercial sizing requirements and the final permit was only issued with load stipulations
Insulation was the least of his worries :lol:
191185
Can anyone help answer my question ?
Do I need to caulk / foam where the 2x4 meets the sheathing?
DFB
Do you feel any air draft there?
Also check between the double plates and around window headers for air infiltration.
What did you decide to do...Rock wool and poly?
Kraft and poly?
Kraft only?
191185
Kraft and poly?
Kraft only?
I don't feel a draft, house was built in 2003, everything seems "normal" ... so should I not worry about it? How much would it really matter ?
Well, rock wool comes to about $350 for just the walls.
Kraft faced batts I figured about $130 for just the walls
I was thinking either one? What would you recommend?
DFB
Well this is what I did on my own house and on any jobs I got paid for :D
Definitely seal any cracks or gaps where you even "think" cold air may be getting thru, Its not gonna hurt at all also consider your outlet boxes too they easily leak cold air as many installers usually don't get much insulation behind them.
IMO if your going with Kraft (what I have) or Foil Face and you might consider that too but it more money than paper. Get it up and in good and tight to the plates and studs cover up the wall and be done with it.
If you chose the rock wool option obviously your gonna need poly.
Its a garage and air exchange will be at maximum and wouldn't be like inside the house where you are introducing lots of water vapor with cooking showers etc.
dfiler2
NW Minnesota
I agree, I don't think you can go wrong by sealing as much as you can, if you're willing to do it, go for it. Also, I think the rock wool is a great choice.
tjpavlov
Providence, RI
I ran a bead of caulk between the sill plate and the foundation and into any cracks. Look for where you may have two vertical studs.
Check out Matt Risinger on YouTube. Lots of good sir sealing videos.
I would use Rockwool despite the extra cost. Way easier to work with in my experience.
